Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Ericbrooks, Japanese, lordcheeto, WondrousBread, slickoo9
66672 Registered Users
46 registered members (Bud, Anthony, BrandonT, 4WD, alarmguy, bullwinkle, 4 invisible), 1,056 guests, and 42 spiders.
Topics295,047
Posts4,926,806
Members66,672
Most Online2,553
Oct 27th, 2018
Probably, Gonna Need to Change Oils & Need Advice #4656918
02/05/18 12:35 PM
02/05/18 12:35 PM
Mississippi
Speak2Mountain Offline OP
Mississippi
Situation:
07 Lexus IS (DI engine) 136000 trouble-free miles. Oil changes since 120K Valvoline MaxLife 5w30 (per Lexus).
OCI's every 6000 miles
Changed after Christmas and noticed oil on dipstick down by little over half. No leaks so obviously its being burned.
None or very little smoke from tailpipe
Never a thrown code for carbon buildup
So, 1) Where's the oil being burned?
2) What oil weight and brand would y'all suggest?
I live in MS so there's no concern heavy oils
I drive alot, in fact. January I drove 3800 miles
As usual, thx ahead.
Re: Probably, Gonna Need to Change Oils & Need Advice [Re: Speak2Mountain] #4656921
02/05/18 12:39 PM
02/05/18 12:39 PM
South Wales, UK
Bailes1992 Offline
Bailes1992  Offline
South Wales, UK
Overhaul the PCV system, top the engine up to the max mark and measure how much it's using over what distance.
Consider moving up to a 5w40 or 0w40 A3/B4 synthetic oil. Look for manafctuer approvals when you choose, not just 'meets or exceeds...".
'13 Suzuki Jimmny - '16 Dacia Duster 1.5DCi 4WD
'96 LR Defender 300TDi - '12 BMW 320d
Engine Oil - Fuchs Titan XTL GT1 5w40
Gearbox Oil - Fuchs Sintofluid 75w80
Diff Oil - Fuchs Sintopoid 75w90
Re: Probably, Gonna Need to Change Oils & Need Advice [Re: Speak2Mountain] #4656925
02/05/18 12:41 PM
02/05/18 12:41 PM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
Lexus used direct injection back then?
Re: Probably, Gonna Need to Change Oils & Need Advice [Re: Speak2Mountain] #4656940
02/05/18 12:57 PM
02/05/18 12:57 PM
Massachusetts
VeryNoisyPoet Offline
Massachusetts
It takes way more consumption than what you have to see any visible smoke during normal operation, though it may appear on an emissions test. Are you seeing a puff of blue on startup after it sits a few hours? Leaking valve seals could account for some consumption in an engine of that age, but generally will not cause smoke other than right at startup.
Not sure what range your dipstick shows, but probably 1 to 1.5 qt between full and low marks. Half to 3/4 of a qt in nearly 4k miles is not bad at all. Did this consumption suddenly start or get worse? Have you been driving it harder than usual? Highway trips and thrashing the engine will use oil faster than gentle in town trips.
1998 V70 GLT / 195k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Probably, Gonna Need to Change Oils & Need Advice [Re: Bailes1992] #4656945
02/05/18 01:00 PM
02/05/18 01:00 PM
Ontario, Canada
newbe46 Offline
newbe46  Offline
Ontario, Canada
Do you mean just replacing the PCV valve?
2003 E46 M3 Convertible
2004 Odyssey EX-L
2004 Impreza TS Wagon
Re: Probably, Gonna Need to Change Oils & Need Advice [Re: Speak2Mountain] #4656950
02/05/18 01:05 PM
02/05/18 01:05 PM
Pittsburgh PA USA
Milkman Offline
Milkman  Offline
Pittsburgh PA USA
So, this car used 1/2 a qt in 4000 +/- miles ? I'm not sure that I would worry too much.
2018 Dodge Charger R/T 5.7 Hemi (Mine)
2010 Chevrolet Malibu LT (Hers)
Good cars...
Re: Probably, Gonna Need to Change Oils & Need Advice [Re: Speak2Mountain] #4657007
02/05/18 01:55 PM
02/05/18 01:55 PM
Central Coast California
RedOakRanch Offline
RedOakRanch  Offline
Need to drive quite a bit more to monitor, could be an isolated event. My wife's Outback oil level never moved in the first 45k, then burned half a quart. It was due to a 6 hour drive at 80mph, got to love the southwest! Hasn't burned a drop since.
1994 Ford Crown Vic 207k-Frankenbrew 0w20,30,40!
2005 Chevy 1500 Crewcab 4X4 180k-BC 0w30 $2/qt
2016 Outback 2.5 Limited 60k-shop brand?
Re: Probably, Gonna Need to Change Oils & Need Advice [Re: VeryNoisyPoet] #4657095
02/05/18 03:15 PM
02/05/18 03:15 PM
Mississippi
Mississippi
Yes, consumption only began when I had the big driving month, last month. I've topped off some last 10k miles, but not like this.
Re: Probably, Gonna Need to Change Oils & Need Advice [Re: Bailes1992] #4657099
02/05/18 03:16 PM
02/05/18 03:16 PM
Mississippi
Mississippi
Thx I've been considering a new PCV
Re: Probably, Gonna Need to Change Oils & Need Advice [Re: Bottom_Feeder] #4657100
02/05/18 03:17 PM
02/05/18 03:17 PM
Mississippi
Mississippi
Yes, I blv it was Toyota's first, may have been the first Japanese car w/DI
Re: Probably, Gonna Need to Change Oils & Need Advice [Re: Speak2Mountain] #4657156
02/05/18 04:00 PM
02/05/18 04:00 PM
Florida
Artem Offline
Artem  Offline
Florida
Engine is aging a bit and consumption increased slightly. What's the big deal?
Isn't this why the average Joe trades in a lightly used 36,000 mile vehicle just after the warranty expires to not ever worry about oil consumption as the car gets older? LOL
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: Probably, Gonna Need to Change Oils & Need Advice [Re: Speak2Mountain] #4657252
02/05/18 05:42 PM
02/05/18 05:42 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
New PCV if you wish, but I'd carry on.
03 Jeep WJ 4.0 202k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Probably, Gonna Need to Change Oils & Need Advice [Re: Speak2Mountain] #4657342
02/05/18 07:14 PM
02/05/18 07:14 PM
out there
spasm3 Offline
spasm3  Offline
out there
Change pcv valve, check for leaks. Do nothing else, that's not much consumption for that mileage.
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: Probably, Gonna Need to Change Oils & Need Advice [Re: Speak2Mountain] #4657362
02/05/18 07:29 PM
02/05/18 07:29 PM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
Not bad consumption rate at all. I service a lot of IS 250/350 with heavy oil consumption. A lot of owners don't know how to check the oil level or are too lazy. They come in 2 or 3 quarts low at 5,000 miles. Most of these examples are between 100,000 to 200,000 miles.
For your particular car, I would recommend the full synthetic maxlife 10w30, or stick with the red bottle blend in 10w30 or 10w40. Your oil consumption is very mild and I would recommend just checking and topping off half way between services.
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi
2009 Scion tC Manual (Daily Driver) 165k mi
Re: Probably, Gonna Need to Change Oils & Need Advice [Re: Speak2Mountain] #4657416
02/05/18 08:35 PM
02/05/18 08:35 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Definitely not wink
Scambling for solutions is a hopelessly futile endeavour and potentially dangerous, without first coming to a solid, personal understanding of the problem. Beware riding the ideological hobby horse.
