Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
27 registered members (BigShug681, bmod305, 08z06, A1O, 53' Stude, billt460, 3 invisible), 529 guests, and 51 spiders.
Topics286,220
Posts4,904,513
Members67,579
Most Online2,967
Mar 10th, 2019
Pour point vs. W rating....questions... #4656861
02/05/18 12:24 PM
02/05/18 12:24 PM
NY
TurboTravis Offline OP
NY
Hey guys,
I have learned a ton here over the years without starting to many threads, but I can't seem to find an answer to my question. A friend brought up this subject yesterday and I was not able to add too much to the discussion..
Anyway, why/how is there such a variance in the pour point with a given weight of oil? Is there a minimum pour point that must be met for each weight? (Is this the same as the coldest temp the weight is rated to?) He is interested in finding the 'best' oil for cold starts in very cold weather (we are in very far Upstate NY). Is the pour point the most important spec when determining this?
To me, it seems like the pour point and viscosity can be related, but not always (meaning that a thinner oil typically has a lower pour point, but not always?)
Hope this makes sense.
-Travis
Re: Pour point vs. W rating....questions... [Re: TurboTravis] #4656869
02/05/18 12:31 PM
02/05/18 12:31 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Originally Posted By: TurboTravis
Hey guys,
-Travis
The reason that Pour Point was abandoned for determining an oil's cold temperature performance was due to its unreliability. It was so bad that they came up with two entirely new tests: CCS and MRV, to properly gauge it.
An oil with a ton of PAO in it will have a wickedly low pour point because PAO has no wax in it that will crystallize at low temperatures. However, it still thickens as temperature drops. PPD's and VII treat in a lighter base oil blend that doesn't consist of PAO can still outperform it at the temperatures the tests are performed at, the wildcard is if you are using an oil below that range; below the temperature acceptable for the grade.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: Pour point vs. W rating....questions... [Re: TurboTravis] #4656942
02/05/18 01:58 PM
02/05/18 01:58 PM
Jupiter, FL
thescreensavers Offline
Jupiter, FL
For example 10W40 full synthetic maxlife has a lower pour point than its 0W20..
CCS taken at different though, temps 0W20 at -35 vs -25 for 10W40
https://sharena21.springcm.com/Public/Do...12-ac162d889bd1
2017 Camaro SS 1LE (Motul 8100 X-clean 5W40)
1997 Jeep XJ 4x4 (15W40 HDEO Maxlife)
Re: Pour point vs. W rating....questions... [Re: TurboTravis] #4656962
02/05/18 02:21 PM
02/05/18 02:21 PM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
Look at the CCS. 5W-30 is good for a -30 C (-22 F) start. The all time low for Syracuse, New York was -13 F on New Year's Day. Not a problem for a 5W-xx oil. If you'd like to have an even more dependable start 0W-xx would make it a non-event. I'm speaking from experience. Used to live in Edmonton, Alberta, Canada.
SF
If you want the job done right......do it yourself.
Re: Pour point vs. W rating....questions... [Re: OVERKILL] #4657127
02/05/18 04:31 PM
02/05/18 04:31 PM
San Francisco, CA
Flying_A Offline
Flying_A  Offline
San Francisco, CA
Hey guys,
-Travis
This.
No one seems to understand and too many walk away thinking an oil with a lower pour point is a better product or is made up of more PAO. As I've said before anyone can just pour a bunch of VII and it appears to look quote good on paper vs a product with substantially more PAO content in it.
2008 Maserati Gran Turismo: Motul 300V Trophy 0W40
2017 Audi A3 etron: Motul X-clean FE 5W30/300V Sprint 0W15
Re: Pour point vs. W rating....questions... [Re: TurboTravis] #4657673
02/06/18 08:49 AM
02/06/18 08:49 AM
UK
weasley Offline
weasley  Offline
UK
It's not that simple though. You can't just pour ppd and VII into an ordinary base oil and expect to hit CCS and MRV numbers as well as KV100. Not to mention the secondary impact on API and ACEA bench and engine tests.
2017 SEAT Leon 1.4 EcoTSI 150 FR Technology DSG
2018 Volvo XC60 D4
2011 KTM 990 SMT
Re: Pour point vs. W rating....questions... [Re: TurboTravis] #4658078
02/06/18 03:18 PM
02/06/18 03:18 PM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
Travis,
the pour point (or the more modern "Youtube Bottle Glug") test inherently feel like they are applicable to low temperature starting, and for a long, long time, the "W" rating was based on it, or factors like it.
Testing identified that the brookfield viscosity was a better correlation to how long it took things to get to the top end in test engines.
And later yet, they found that there were specific cooling rates, that occurred one winter causing engine carnage encouraged the wax crystals to grow regardless of the actual temperature extreme that was reached (so neither pour point nor straight viscosity applied).
The MRV test has the "perfect storm" of cooling rates, designed to show any weakness in wax formation, with the viscosity limit of 60,000mPa-s (600P), and importantly not to have a "yield" stress, or "jello" like phase.
This test is about whether when the pump starts pumping, the oil is capable of
a) being sucked up the feed tube (OVERKILL's analogy); or
b) "falling" back in around the pickup tube to replace the oil that has been pumped into the engine.
(CCS is about how well the engine cranks, and therefore starts).
So in order
* pick a "W grade" that suits...assuming that he wants 0W.
* pick one with a smaller MRV (for example GM has a limit of 40,000MPa-s on dexos oils, 2/3 of the absolute limit.
* if you want to flavour it with Pour point, do so, but it's last on the list.
Re: Pour point vs. W rating....questions... [Re: Shannow] #4658127
02/06/18 04:18 PM
02/06/18 04:18 PM
Virginia
Tom NJ Offline
Tom NJ  Offline
Virginia
Exactly. The pour point test is not part of motor oil specifications because it fails to predict an oil's low temperature performance in an engine due to its low shear rates and an inappropriate cooling rate.
The CCS test is a higher shear test that correlates well to an oil's ability to be pumped.
The MRV test uses a slow cooling rate to promote wax crystallization and correlates well to an oil's ability to flow back into the pick-up tube cavity.
Tom NJ/VA
Re: Pour point vs. W rating....questions... [Re: Snagglefoot] #4658147
02/06/18 04:38 PM
02/06/18 04:38 PM
upstate NY
dustyroads Offline
dustyroads  Offline
upstate NY
SF
Just for the record smile -13f was the coldest new year's day on record...not coldest day ever. At one time -26f was the record low in Syracuse, not sure if it has gone lower than that or not.
Northern NY (OP's location) is a whole different story. I saw -34 in my brief travels up there this year. I live a little southeast from Syracuse where it's down right balmy compared to the north country. Somebody in Quebec keeps leaving the door open, allowing the Arctic air to drift straight down into northern NY.
2013 F150 XLT 5.0 4X4 104k miles
Edge 5W-30 / Fram 10575
Re: Pour point vs. W rating....questions... [Re: Tom NJ] #4658641
02/07/18 02:37 AM
02/07/18 02:37 AM
'Stralia
'Stralia
Tom, the CCS is specifically related to the cranking speed, and the ability of the engine to start.
The flow velocities in the galleries are still low shear.
Re: Pour point vs. W rating....questions... [Re: TurboTravis] #4658919
02/07/18 11:15 AM
02/07/18 11:15 AM
Virginia
Tom NJ Offline
Tom NJ  Offline
Virginia
Yes, it measures viscosity under high shear which in turn relates to cranking speed, which is essential for pumping the oil.
Re: Pour point vs. W rating....questions... [Re: TurboTravis] #4659143
02/07/18 03:08 PM
02/07/18 03:08 PM
'Stralia
'Stralia
Yes, if the engine won't start, it won't pump, but if it won't start it doesn't need to pump.
CCS is about cranking speed and starting...not pumping.
CCS
https://www.researchgate.net/publication...nd_Fuel_Economy
the relationship between viscosity and engine performance
MRV
http://www.tandfonline.com/doi/abs/10.1080/10402000601105540
The MRV ensures that every revolution the Positive Displacement pump makes it stays filled and delivering.
Because the engine needs to turn to deliver oil mechanically, does not make CCS any determinant of ability to pump oil...other than getting the engine running of course.
