When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
101 registered members (2whlgeezer, 2015_PSD, 53' Stude, 2012AccentSE, 13 invisible), 2,150 guests, and 59 spiders.
Topics286,160
Posts4,903,317
Members67,569
Most Online2,967
Mar 10th, 2019
Better engine break in with a manual transmission? #4656701
02/05/18 10:14 AM
02/05/18 10:14 AM
Ontario, Canada
heyleescomet Offline OP
Ontario, Canada
Do you think manual trans vehicles have their rings broken in better due to the more significant engine braking or something along those lines.
My Dad and sister both have Dodge Neons, Dads being an 01 r/t 5 speed with 250k that will consume visibly no oil through a 10k oil run, sisters an 05 base model with 150k that takes about 1L per 5k driven.
Same goes for my truck with a 4.6L/manual, no oil loss in the 4k ive driven it. While my moms 02 f150/4.6L/auto uses also around 1L per 5k driven.
just a thought, Since these vehicles I believe to be common oil users. but maybe its just the upkeep of the owners.
2003 F-150 4.6L, 5 speed, PP 5w30
1962 Mercury Comet 200ci, Shell 15w40
Re: Better engine break in with a manual transmission? [Re: heyleescomet] #4656734
02/05/18 10:37 AM
02/05/18 10:37 AM
NY
demarpaint Offline
demarpaint  Offline
NY
It is easier to do compression braking, and hold gears longer with a stick during break in. But in all honesty you can get similar results with an automatic transmission if you give it some thought during the break in period. Having said that, there are many people who believe a modern engine requires no real break in. And another set of people believe the lot boys moving new cars around dealerships prior to delivery to the customer beat the [censored] out of them, and did the break in before the owner even sees the vehicle.
God Bless Our Troops
Re: Better engine break in with a manual transmission? [Re: heyleescomet] #4656745
02/05/18 10:48 AM
02/05/18 10:48 AM
Canuck living in California
KrisZ Online content
KrisZ  Online Content
I think it does. Why? Because wit a manual tranny, just by driving normally, the engine will see higher RPM and compression braking. No extra thinking is required from the driver.
With automatic transmissions, as demarpaint pointed out, the driver has to be aware what need to be done to get higher RPM and compression braking, which means you are aware of engine break in, most people aren't.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: Better engine break in with a manual transmission? [Re: heyleescomet] #4656762
02/05/18 10:58 AM
02/05/18 10:58 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Engines almost can't help but breaking in. The gas pedal has the most influence helping with the breakin process.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Better engine break in with a manual transmission? [Re: heyleescomet] #4656785
02/05/18 11:18 AM
02/05/18 11:18 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
If auto-trans drivers would learn to use the shift lever and downshift once in a while, they'd engine brake too! It's the nut behind the wheel that will make some small difference ...
But, unless it's a "new" 1950's engine (or earlier), the rings are seated by 500 miles no matter what.
Now, for those that don't ever wind and engine, the ring ridge may be formed too low ... So the next owner may pop a top ring when he/she buys it used, and starts driving it for real oilburner
Re: Better engine break in with a manual transmission? [Re: heyleescomet] #4656797
02/05/18 11:24 AM
02/05/18 11:24 AM
New England
madRiver Offline
madRiver  Offline
New England
Nope. It is one variable in about 100.
Biggest influence is owner over entire period then the engine design.
Re: Better engine break in with a manual transmission? [Re: heyleescomet] #4656815
02/05/18 11:45 AM
02/05/18 11:45 AM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
One could argue the opposite as well (AT's better), but I don't see any data to show that one or the other does a better job at Rin-In.
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Better engine break in with a manual transmission? [Re: heyleescomet] #4656849
02/05/18 12:19 PM
02/05/18 12:19 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
Manual may not get stuck rings as easy.but thats about it. My Mazda has 50k and uses a quart of oil every 3k Miles or so. It has a manual transmission. My truck has a manual and uses no oil with no oil loss over an oil interval and it has 248k.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: Better engine break in with a manual transmission? [Re: heyleescomet] #4656854
02/05/18 12:21 PM
02/05/18 12:21 PM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
OP, I was of the opinion that cars with manual transmissions burn more oil because of the engine braking, and it certainly has been my experience. And now you post this... just when I thought I had it figured out.
1997 Maxima 197k, Castrol GTX Synblend 5W-30, FL400S
2004 Corolla 197k, VWB + SSS + Rislone cocktail, MGL51516
Re: Better engine break in with a manual transmission? [Re: heyleescomet] #4656884
02/05/18 12:46 PM
02/05/18 12:46 PM
Indiana
Indydriver Offline
Indydriver  Offline
Indiana
No doubt.
2014 Camaro 2SS/RS LS3 Vert 14,000 M1
2012 Sienna 85,000 M1
2007 Tahoe 155,000 M1
Re: Better engine break in with a manual transmission? [Re: heyleescomet] #4656897
02/05/18 01:07 PM
02/05/18 01:07 PM
Ontario, Canada
Ontario, Canada
So many things factor into it I guess one could never really be certain. Interesting to read other folks views and experiences.
Re: Better engine break in with a manual transmission? [Re: CT8] #4656935
02/05/18 01:53 PM
02/05/18 01:53 PM
PimTac Offline
PimTac  Offline
This one.
Some modern automatics downshift to use engine braking though its not as obvious as when done with a manual. My Mazda downshifts all the time when slowing.
Cannot see signatures any longer so it doesn’t matter.
Re: Better engine break in with a manual transmission? [Re: heyleescomet] #4657021
02/05/18 03:07 PM
02/05/18 03:07 PM
New automatics may downshift like manuals, but unless kept in a manual or sport mode, will do it at very low RPM. You want moderate to high RPM acceleration and deceleration using compression.
Re: Better engine break in with a manual transmission? [Re: heyleescomet] #4657039
02/05/18 03:22 PM
02/05/18 03:22 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
I dont think it matters.
FWIW the subaru FB25 engines that had oil burning.. the MT vehicles were a way higher % with the issue vs the auto
The op's question is like asking what is the best oil to get my engine to 1 million miles when the rest of the car falls apart at 150000 miles.
Its an answerable question but not super relevant to real world.
Re: Better engine break in with a manual transmission? [Re: zorobabel] #4657868
02/06/18 12:01 PM
02/06/18 12:01 PM
Wash, DC
circuitsmith Offline
Wash, DC
The OP theory does not conflict with your opinion.
Engine braking can cause a broken in engine to use more oil AND engine braking can help the break in process.
2017 Hyundai Tucson SE FWD
SuperTech synth, 5w-30, 5000mi/12mo OCI
