1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
115 registered members (4WD, AndyB, 2009Edge, 240_Ed, 2015_PSD, Altima2, 8 invisible), 2,238 guests, and 65 spiders.
Topics286,399
Posts4,907,608
Members67,614
Most Online2,967
Mar 10th, 2019
Page 1 of 5 1 2 5
Fram Ultra flow restrictive? #4656522
02/05/18 02:09 AM
02/05/18 02:09 AM
Tennessee, United States
ZraHamilton Offline OP
I am wondering if the extreme efficiency of the fram ultra (99% @ 20, 94% @ 10, and I even heard someone say 80% @ 5 microns) would create a large pressure differential and cause it to bypass often. The bypass valve is extremely flimsy and easy to push because of the weak spring and plastic valve. This seems like the biggest weakness of the ultra. If it bypasses often, that 99%+ becomes 0% lol.
Also, wouldn't the Wix XP have the lowest pressure differential of nearly any filter? (with fiberglass media and 50% @ 20 micron efficiency). If so, you get the filtering efficiency of many OEM filters, but with excellent flow, and the toughest construction.
Re: Fram Ultra flow restrictive? [Re: ZraHamilton] #4656524
02/05/18 02:11 AM
02/05/18 02:11 AM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
No, the media is microglass, so the flow is higher AND more efficient than cellulose. The fram rep has posted flow charts before for specific part numbers and they are pretty much good enough to use for race applications.
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Fram Ultra flow restrictive? [Re: ZraHamilton] #4656525
02/05/18 02:18 AM
02/05/18 02:18 AM
Race applications without bypassing?
Re: Fram Ultra flow restrictive? [Re: ZraHamilton] #4656527
02/05/18 02:20 AM
02/05/18 02:20 AM
And isn't microglass just another way to say fiberglass spun into filter media?
Re: Fram Ultra flow restrictive? [Re: ZraHamilton] #4656530
02/05/18 02:28 AM
02/05/18 02:28 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Does your car's oil pump put out over 15 GPM? If not, don't worry about it.
Re: Fram Ultra flow restrictive? [Re: 901Memphis] #4656565
02/05/18 06:26 AM
02/05/18 06:26 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Yet a filter made specifically for racing uses a Synthetic-Polymer/Cellulose-Fiber blend media.
https://performanceparts.ford.com/part/CM-6731-FL1A
popcorn
Re: Fram Ultra flow restrictive? [Re: ZraHamilton] #4656573
02/05/18 06:56 AM
02/05/18 06:56 AM
Central Florida
Mr Nice Offline
Mr Nice  Offline
Central Florida
No worries about oil flow.
Of course engineers at Fram tested before manufacturing millions of Fram Ultra filters.
Re: Fram Ultra flow restrictive? [Re: ZraHamilton] #4656574
02/05/18 06:57 AM
02/05/18 06:57 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
1) oil filters RARELY go into bypass; read Jim Allen's trials please
2) oil filters flow well more than the oil pumps put out; show me any data to prove otherwise
3) the Wix/NG and Wix XP are rated at same flow volumes for equivalent applications; go check their website
4) what makes you think the BP valve is "extremely flimsy and easy to push because of the weak spring and plastic valve" (As opposed to the bazillions of others just like it in other brands?) What makes the plastic "flimsy" and the spring "weak"?
This thread is just a new version of the old (unfounded) complaint regarding the PureOne filters being "too restrictive"; a totally uneducated view that if it's efficient, it must also be too restrictive because one's brain cannot conceive that the product can be both efficient and flow well
Where do some of you get these ridiculous ideas, anyway? crzy
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Fram Ultra flow restrictive? [Re: dnewton3] #4656589
02/05/18 07:39 AM
02/05/18 07:39 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Originally Posted By: dnewton3
.......one's brain cannot conceive that the product can be both efficient and flow well
In a nutshell, what's been said about K&N air filters for years.
18 KIA Sportage 2.4 AWD
M1HM 10W30, OEM
ST SYN 5W30, ST9688 (next)
13 Hyundai Santa Fe Sport 2.0T
PPeL 5W30, OEM
M1HM 10W30, OEM (next)
Re: Fram Ultra flow restrictive? [Re: wemay] #4656590
02/05/18 07:41 AM
02/05/18 07:41 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Only UOA data posted here typically shows increased wear metals using K&N air filters.
God Bless Our Troops
Re: Fram Ultra flow restrictive? [Re: dnewton3] #4656591
02/05/18 07:43 AM
02/05/18 07:43 AM
MN
oil_film_movies Offline
MN
Its OK to question if something with great efficiency has too high of a flow resistance. Thats not a stupid question.
Intuitively, you might think a filter is more restrictive the smaller the flow path porosity is.
Flow any liquid into a smaller pipe and you'll see the pressure drop go up, of course.
In this case, the Fram Ultra isn't too restrictive at all. It can hold more dirt than most other filters.
The physical reality of smaller, more consistently sized synthetic fibers is what makes the Ultra work.
Re: Fram Ultra flow restrictive? [Re: ZraHamilton] #4656600
02/05/18 07:58 AM
02/05/18 07:58 AM
Coastal South Carolina
edwardh1 Offline
edwardh1  Offline
maybe k and k just does not filter much
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Fram Ultra flow restrictive? [Re: oil_film_movies] #4656606
02/05/18 08:06 AM
02/05/18 08:06 AM
SD
zrxkawboy Offline
zrxkawboy  Offline
SD
Nah, we allow questions here. We just jump all over a newcomer who asks questions, as opposed to politely answering them like you just did. What were you thinking??
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Fram Ultra flow restrictive? [Re: ZraHamilton] #4656608
02/05/18 08:06 AM
02/05/18 08:06 AM
MN
MN
That is possible. No evidence it flows more.
Actually, pressure drop is rarely a problem with properly engineered oil filters anyway.
Any difference between brands would be small. Oil pumps are positive displacement, meaning they would consume a little more power in a more restrictive flow path, yet still deliver about the same mass flow rate anyway.
This could be important in a racing application where you don't want parasitic power losses in the oil pump at high RPMs when it counts. Data would be needed on oil filter restriction in that case.
Re: Fram Ultra flow restrictive? [Re: ZraHamilton] #4656611
02/05/18 08:11 AM
02/05/18 08:11 AM
Rockwall, Texas
Old Mustang Guy Offline
Rockwall, Texas
I think it is a concern. That's one reason I like OE.
Page 1 of 5 1 2 5
