PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
122 registered members (2015_PSD, 01rangerxl, 2K2AcuraTL, 13 invisible), 2,002 guests, and 59 spiders.
Topics286,162
Posts4,903,349
Members67,569
Most Online2,967
Mar 10th, 2019
Should I go 0w40? #4656296
02/04/18 08:51 PM
02/04/18 08:51 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
Sorry for the slightly trollish title but I was just thinking. Been running mostly 5w20 in my truck although sometimes I will go with 0w20 in the colder months. Approaching 100k and I do burn about 1qt every 3k miles. Running M1 most of the time and she is smooth and quiet. I have seen a ton of discussion on the truck forums and many people run xw30 in these trucks. Pretty much the same engine as the Boss which specs 5w50. Would there be any benefit to bumping to a 0w30 or 0w40 over my M1 5w20? I'm not thinking the cold performance would be a factor as I'm already plenty covered with the synthetic 5w in my locale but what about running at full temp on the highway or even light duty towing?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Should I go 0w40? [Re: buck91] #4656301
02/04/18 08:53 PM
02/04/18 08:53 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Try it and see what happens. Its not going to hurt anything and may reduce your consumption
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Should I go 0w40? [Re: buck91] #4656329
02/04/18 09:21 PM
02/04/18 09:21 PM
Indiana
Indydriver Offline
Indydriver  Offline
Indiana
I have a similar issue in my Tahoe 5.3 with 125,000 miles. Ive had good luck going to M1HM 5W-30. AFE 0W-30 burns off twice as fast.
2014 Camaro 2SS/RS LS3 Vert 14,000 M1
2012 Sienna 85,000 M1
2007 Tahoe 155,000 M1
Re: Should I go 0w40? [Re: buck91] #4656411
02/04/18 10:51 PM
02/04/18 10:51 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
In a 5w20 engine I'd go to 5w30 before 0w40.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Should I go 0w40? [Re: Alex_V] #4656449
02/04/18 11:30 PM
02/04/18 11:30 PM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
Why ?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Should I go 0w40? [Re: buck91] #4656504
02/05/18 01:07 AM
02/05/18 01:07 AM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
Similar high calcium, higher moly/boron in the M1 and PP 0w-40. Both are in the hths 3.5-3.8 range. Last I checked the add pack in the M1 is a bit stouter. The 0w-40 Edge is a lower calcium, moderate magnesium blend. As far as Euro mfg specs the Edge has more than M1. Some of the PP 0w-40 brews (like SRT) have the fewest mfg approvals. They all go on sale at some point during the year. Let any bottle of motor oil sit long enough and it will probably have some of the add pack settle out.
The recent version of Mobil 1 0w-40 FS starts off with a 12.8 cSt visc at 100 deg C...really in between a 30 and 40 grade just after a little usage. Considering that some of the M1 and Edge 30 grades are in the 11.8-12.5 range....not much different than a 0w-40. Even plain old M1 5w-30 is at 11.1.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Should I go 0w40? [Re: buck91] #4656559
02/05/18 06:15 AM
02/05/18 06:15 AM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
Switch to 5W30 after another 50K mi.
Re: Should I go 0w40? [Re: buck91] #4656561
02/05/18 06:17 AM
02/05/18 06:17 AM
South OZ
KL31 Offline
KL31  Offline
South OZ
M1 0w40 is close to a thick 30 grade. I'd try it just to see if the consumption lessens.
95 MX-3 2.5L|Shell Helix Ultra 5W40|Wix 51356
04 Focus 1.8L|Wesfil Cooper WZ63|Valvoline MST 5W30
05 Kluger 3.3L|Wesfil Cooper WZ418|Magnatec 10W30 Semi Syn
Re: Should I go 0w40? [Re: buck91] #4656586
02/05/18 07:31 AM
02/05/18 07:31 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Might be useful to tell everyone the year, make, and engine for your truck, but generally if youve burning a quart every 3000, miles, going up one weight might help.
If you want the job done right......do it yourself.
Re: Should I go 0w40? [Re: Snagglefoot] #4656690
02/05/18 09:56 AM
02/05/18 09:56 AM
PA,US
HemiHawk Offline
HemiHawk  Offline
PA,US
From his signature... 2011 F150 4x4 5.0L.
Burning a quart every 3k miles? Seems excessive for a 5.0. Try 5w30 or 0w40, but my guess is that won't help much.
2016 Nissan Frontier Pro4x
2017 VW GTI sport
1995 Mustang GTS
Re: Should I go 0w40? [Re: buck91] #4656705
02/05/18 10:15 AM
02/05/18 10:15 AM
Mahzurrah!
KCJeep Offline
KCJeep  Offline
Mahzurrah!
Yet another Ford that's been run on 5w20 it's whole life that now has consumption. From what I saw with Crown Vics, consumption will go through the roof by 120k.
Try a run with 0w40, won't hurt a thing, I am betting you will like the way it starts and runs and consumption is likely to go down as well.
I got my Lincoln at 76k I'm sure it had 20 grades from new as well, it uses a little oil (not much, but the only car I have that uses any including a 191k Chevy). I'm hoping I got to it soon enough that it won't increase much.
2018 VW Passat GT VR6 - 6k - Valvoline MST 5w40 - VW OEM filter
2012 KIA Sedona 96k - PP HM 10w30
2009 Ford Focus 135k - Supertech FS HM 5w30
2004 Jeep Grand Cherokee, gone but not forgotten.
Re: Should I go 0w40? [Re: SilverFusion2010] #4656722
02/05/18 10:27 AM
02/05/18 10:27 AM
lllinois
salesrep Offline
salesrep  Offline
lllinois
High quality Specialized Lubricants pay for themselves!
Re: Should I go 0w40? [Re: buck91] #4656736
02/05/18 10:39 AM
02/05/18 10:39 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Sure, why not ... smile
Re: Should I go 0w40? [Re: KCJeep] #4656740
02/05/18 10:43 AM
02/05/18 10:43 AM
US
JLTD Offline
JLTD  Offline
US
My thought also.
From my reading on Fords, there should be no issue/damage from changing grades. (agreeing with the Boss reference above)
I thought there another guy on here that was using 0w40 in a similar truck....
I use the overseas owner's manual to choose my oil.
Using AMSOIL
Hers: 2008 Jeep Liberty 143k, SS 5w30/Amsoil
His: 2015 4Runner 51k, OE 5w30/Wix
Re: Should I go 0w40? [Re: KCJeep] #4656741
02/05/18 10:44 AM
02/05/18 10:44 AM
NY
demarpaint Offline
demarpaint  Offline
NY
It makes you wonder doesn't it? I made the change from 5W20 to 5W30 in both my Jeeps, and I'm not looking back, even after all the 5W20 success stories I read from time to time here.
OP-Give 0W40 a shot, you have nothing to lose.
God Bless Our Troops
