64846 Members
68 Forums
282306 Topics
#4655943 - 02/04/18 01:33 PM
My 1st Cut and Post FL400S
Loc: LOUISIANA
#4655947 - 02/04/18 01:40 PM
Re: My 1st Cut and Post FL400S
[Re: CajunLariat]
Loc: Great Lakes
Looks like media is torn in one place. Did this happen in service or as a result of your cutting?
'02 530i (Edge HM 10W-40) '15 Q5 3.0T (Edge 5W-40)
#4655948 - 02/04/18 01:42 PM
[Re: CajunLariat]
Loc: OH
What are your thoughts on the filter after cutting it open?
2012 Toyota Camry 72k-Idemitsu 0w20,OEM filter, RT43s. 2005 Toyota Matrix 135k miles - VWB 5w30 conv, Valvoline oil filter. Nokian eNTYRES.
#4655958 - 02/04/18 01:56 PM
[Re: CajunLariat]
Loc: Katy, Republic of Texas
Any idea on how many miles it was in service for?
1994 Honda VT1100C: Peak 15w-40/TG/2500 mile OCI 2002 Ford F150: GTX HM 5w-20/EcoGard Syn/1yr OCI 2012 Scion xB: QSUD 0w-20/CQ Blue/5k OCI
#4655974 - 02/04/18 02:04 PM
[Re: SatinSilver]
Loc: LOUISIANA
What are your thoughts on the filter after cutting it open? I don't know. What am I looking for? I just was doing what every body did here.
#4655975 - 02/04/18 02:05 PM
[Re: Quattro Pete]
Loc: LOUISIANA
Looks like media is torn in one place. Did this happen in service or as a result of your cutting? What place? I put the filter in the trash but can go get it back. Where are you talking about?
#4655978 - 02/04/18 02:06 PM
[Re: blupupher]
Loc: LOUISIANA
Any idea on how many miles it was in service for? I asked pops and he said he didnt even know it waqs in his shed.
#4655982 - 02/04/18 02:10 PM
[Re: CajunLariat]
Loc: Great Lakes
Looks like media is torn in one place. Did this happen in service or as a result of your cutting? What place? I put the filter in the trash but can go get it back. Where are you talking about? 6th photo - right side. Maybe it's just a light reflection playing tricks on me?
#4655994 - 02/04/18 02:21 PM
[Re: CajunLariat]
Loc: Westfield, Ma.
Look's like a hole to me...
Pete. 97 Ford Expl. 4.0 ohv 4wd 5spd  182k miles Last Change; Penn. Plat. HM 5w30 Supertech ST8 (wix), Fram CA8141
#4656008 - 02/04/18 02:34 PM
[Re: CajunLariat]
Loc: Outer Banks, NC
Nice job. Looks like a classic tear to me.
"What is it, the first hole I dug?" 2017 Honda Odyssey SE 2013 Honda Accord LX 2007 Honda Ridgeline RTS 2007 Infiniti M35
#4656028 - 02/04/18 02:54 PM
[Re: Quattro Pete]
Loc: US-WA
Looks like media is torn in one place. Did this happen in service or as a result of your cutting? What place? I put the filter in the trash but can go get it back. Where are you talking about? 6th photo - right side. Maybe it's just a light reflection playing tricks on me?  The 'hole' has a reflection. That's oil pooling, probably atop glue. Though the same my first glance.
95 Cherokee 190K DELO 10W30,XG8 07 IS250 96K FB ?w??,FULL 04 YZF-R1 18K DELO 15w40,XG7317 99 HD XL1200S 18K 76 20w50,1515 14 RX450h 30k PP 0w20,NAPAG
#4656049 - 02/04/18 03:17 PM
[Re: CajunLariat]
Loc: Oregon
Good job on your first c&p  Yes not a tear, just a pool of oil at the seam. The FL400s is the best of the Motorcraft filters.
Master the 1000 yard stare Mobil 1
#4656071 - 02/04/18 03:38 PM
[Re: MrQuackers]
Loc: Houston, Texas
Good job on your first c&p  Yes not a tear, just a pool of oil at the seam. The FL400s is the best of the Motorcraft filters. +1 Agreed, a good C&P. Good on you for doing a cut & post. I look for holes or tears in the media, damaged ADBV, damaged or in operative bypass valve. How well the media was glued. The integrity of the end caps. Excessive pleat distortion that might lead to a failure under slightly different operating conditions. Anything out of the ordinary. I look at what the filter trapped to decide on future maintenance. I view this as an opportunity to see what is happening in the engine without having to remove a valve cover or the oil pan. Was rust present in the can. I probably left something out but this is a start. Enjoy the habit.
2004 Ford Ranger 4.0L V6 NAPA Full Synthetic 5W30 + Fram Tough Guard
#4656422 - 02/04/18 10:02 PM
[Re: CajunLariat]
Loc: Waco, TX
In the aviation business, we always cut open filters to look for metal bits. You could save a life.
Lycoming piston pin plug wear results in long slivers of aluminum in the pleats. When you see that, you know you'll be pulling cylinders off soon.
"The evidence demands a verdict". (Re:VOA)"it's nearly impossible to actually know the particular additives that are in there at what concentrations."
