Best additive in oil to clean sludge?
by ffgb
06/21/18 02:19 PM
Who is a Dirt Track regular?
by thooks
06/21/18 01:39 PM
eco plug oil plug video is restricted
by edwardh1
06/21/18 01:27 PM
Political comments
by ridgerunner
06/21/18 01:23 PM
My Ford orange turned pink
by BeerCan
06/21/18 12:45 PM
Any plants/garden experts?
by maverickfhs
06/21/18 12:43 PM
Internet Sales Tax O.K.ed by Supreme Court
by doitmyself
06/21/18 12:23 PM
Brake fluid for a '03 Volvo S60
by earthworm
06/21/18 11:22 AM
Oil Weight Change - Mid Production Cycle
by PolarisX
06/21/18 11:20 AM
Kia ATF - OEM, Eneos, Maxlife - TDS - DIFFERENT!
by Spddm0n
06/21/18 11:19 AM
Dillon Precision Is Simply The Best!
by 2015_PSD
06/21/18 11:17 AM
First OCI - 156k miles Prius
by Greg L
06/21/18 11:11 AM
Brake Squeal on Rear Discs
by BlitzPuppet
06/21/18 11:10 AM
Coolant leak.
by LeakySeals
06/21/18 11:05 AM
Looking for a Home Depot coupon 10% off?
by GravelRoad
06/21/18 10:59 AM
Which is more important for low wear HTHS or ZDDP?
by Building3
06/21/18 10:40 AM
Valvoline DuraBlend 80W-90
by dogememe
06/21/18 10:34 AM
Lifter Tick
by Delta
06/21/18 10:28 AM
I Got Locked Up Today
by Zee09
06/21/18 10:24 AM
GM new 2.7 turbo pick up motor
by ZZman
06/21/18 09:45 AM
wil892, Spddm0n, ronw1309, Suth31, yamahaboy125
65286 Registered Users
108 registered (04sierrashortbed, 2015_PSD, 853okg, 14ecocruze, 28oz, 4WD, 10 invisible), 1532 Guests and 54 Spiders online.
65286 Members
67 Forums
285715 Topics
#4655800 - 02/04/18 11:28 AM Transmission filter question.
littleant Offline
Loc: Vermont
Motorcraft FT140 screen media & WIX 58898 Automatic Transmission Filter synthetic media. ATP not sure. Do you think the wix would be better or more restrictive. Ford trans 5r55s (pita no dip stick). Ford recommends 100,000 service (that's not happening) Severe service 50,000 (not happening either). My first D&F was when purchased at 55,000. Second was at 66,000 third will be at 73,000 (3 drain and fill). Then I will be following a 20-30,000 mile drain. Motorcraft Mercon V fluid. Should I stay with the motorcraft ? Vehicle 2010 mountaineer 4.0 71,200 miles. Thank you
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
#4655830 - 02/04/18 11:55 AM Re: Transmission filter question. [Re: littleant]
Kestas Offline
Loc: The Motor City
The second and third drain seem too quick after the first. I recommend doing a cooler line fluid exchange for the first time, then every 30K to 50K.
I'm not sure about the filter media. Which one is specified?
#4655841 - 02/04/18 12:01 PM Re: Transmission filter question. [Re: Kestas]
littleant Offline
Loc: Vermont
Owners manual Says Motorcraft
#4655854 - 02/04/18 12:12 PM Re: Transmission filter question. [Re: littleant]
i_hate_autofraud Offline
Loc: Canada
In nearly all trannies, the filter is on the "suction side", meaning any restriction, by design or partial
plugging it can be a problem especially for GM trannies, resulting is slow jarring shifts that cause damage.
In an engine oil filter, the filter is on the output "pressure side" of the oil pump, so a 'restrictive' filter has
little effect unless you're racing and redlining the whole time.
A tranny filter is a glorified rock catcher since it can't catch typical wear metals and does only a fair
job at picking up clutch plate wear materials. That said, I add magnets to the oil pan and or the filter intake
where it is metal to pick up as much wear metals before they jam up the shift solenoids or the pressure control
solenoid which is on all the time. A GM TSB admits that wear metals are attracted to the PCS and is a problem.
So I pick an OEM equivalent filter knowing GM 4T65E is sensitive to semi-restricted AFT flow.
#4655869 - 02/04/18 12:27 PM Re: Transmission filter question. [Re: littleant]
bmwtechguy Offline
Loc: South Carolina
For the sake of continuity and staying on spec, why not stay with the Motorcraft Mercon V, as you are planning to? You're doing better than 95% of the rest of the population as far as taking care of your transmission. I would say that sets the odds in your favor for a 200-300k mile transmission life possibility.
#4655894 - 02/04/18 12:48 PM Re: Transmission filter question. [Re: littleant]
CT8 Online   content
Loc: Idaho
Fords manual wouldn't say AC Delco.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4655906 - 02/04/18 12:56 PM Re: Transmission filter question. [Re: bmwtechguy]
littleant Offline
Loc: Vermont
bmwtechguy sounds like a plain. Thank you
#4655910 - 02/04/18 12:58 PM Re: Transmission filter question. [Re: CT8]
littleant Offline
Loc: Vermont
No it would not smile
#4656076 - 02/04/18 03:42 PM Re: Transmission filter question. [Re: littleant]
CT8 Online   content
Loc: Idaho
I used motorcraft oil and filter when I did a trans service on my 2015 Ford F150.
Geoff Metcalf
#4656164 - 02/04/18 05:28 PM Re: Transmission filter question. [Re: CT8]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Infiniti and Nissan manuals mention Dexron, specifically Dexron VI, but that's another matter. wink
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
#4656764 - 02/05/18 09:59 AM Re: Transmission filter question. [Re: littleant]
Whimsey Offline
Loc: The Garden State
I have a 2005 Explorer with the 4.6 and the 5 speed auto. ONCE my mechanic used a non Motorcraft transmission filter and something happened and the vehicle had to be towed back, his expense. After that it has only seen Motorcraft transmission filters. It had transmission fluid exchanges and drop and fills approx every 25-30,000 miles. It now has 194,500 miles on it and the original transmission still shifts like new. The cost of the maintenance is a lot cheaper than replacing the transmission wink.
Whimsey
#4656777 - 02/05/18 10:12 AM Re: Transmission filter question. [Re: Whimsey]
littleant Offline
Loc: Vermont
Whimsey
100% Agree Whimsey
