Time for a new Generator... Wisdom desired!
by webfors. 09/24/18 06:36 AM
flat roof weight bearing support
by henni. 09/24/18 06:29 AM
ADD A MARBLE - Make Life Easier
by MasterSolenoid. 09/24/18 06:17 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
Direct Injection Valve Cleaning Maintenance
by RayCJ. 09/24/18 05:20 AM
Chattanooga tn ,cycling
by CourierDriver. 09/24/18 04:42 AM
Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
64 registered members (Brad_C, Bailes1992, Best F100, aquariuscsm, BeerCan, Boomer, 6 invisible), 1,151 guests, and 44 spiders.
Topics290,929
Posts4,852,606
Members66,055
Most Online3,590
Jan 24th, 2017
silverado heater issue.. #4655759
02/04/18 12:04 PM
02/04/18 12:04 PM
Indiana
OtisBlkR1 Offline OP
Indiana
So, yesterday my 2006 "garage queen" Silverado did something new. I warmed up the truck, turned on the heat and drove a few miles with the heat working. I noticed I was getting cold air out of the driver side vents after about 5 miles, its equipped with the dual zone temperatures. well the passenger side worked correctly however the driver side blew out cold air. I turned the heat off/on several times with no good results. after I made a stop and restarted the truck after a few hours it was working as it should again. this is the first time this has ever happened. extremely well maintained/over maintained truck. 92,xxx on the clock. any ideas ?
Also on a side note.. likely unrelated, the battery gauge on my truck usually reads right about/above 14 and the battery is 2 years old. I hook up a trickle charger about once a month to keep the "garage queen" topped up on juice.. I have noticed the last two outings in the truck that the gauge has been reading at a higher level than usual. even after 20+ minutes of running.. I can account for a higher read as its topping the battery up after sitting for some time. Ive owned the truck since 2006, second owner and like to think I know its behavior fairly well.
again, ideas ?
06 Silverado 92,xxx Mobil 5-30
11 Honda Accord 38,xxx Mobil 1
06 Milan 69,000 Mobil 1
12 Ranger 800XP & 14 TRX 450R
Re: silverado heater issue.. [Re: OtisBlkR1] #4655766
02/04/18 12:09 PM
02/04/18 12:09 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Blend door motor is going bad. Its plastic gears strip.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: silverado heater issue.. [Re: Chris142] #4655775
02/04/18 12:15 PM
02/04/18 12:15 PM
Indiana
Indiana
that crossed my mind, so with dual zones, the trucks going to have two blender doors ? are these both on the same unit ? like if I get it replaced does it cover both sides.. I don't know much about this topic im afraid.. two years ago the blender door on my Milan did the same thing.. $245 the car was happy again..
Re: silverado heater issue.. [Re: OtisBlkR1] #4655802
02/04/18 12:29 PM
02/04/18 12:29 PM
Chris142 Offline
Chris142  Offline
No there are 2 motors and 2 doors.
Re: silverado heater issue.. [Re: Chris142] #4655811
02/04/18 12:39 PM
02/04/18 12:39 PM
Indiana
Indiana
so just have them done as needed ? (are they easy to access ? shop job labor ) or do them both in one shot ? thanks for the input
Re: silverado heater issue.. [Re: OtisBlkR1] #4655881
02/04/18 01:35 PM
02/04/18 01:35 PM
Ontario Niagara region
Drosselmier Offline
Drosselmier  Offline
For a good understanding of GM charging system, Check out this site.
http://www.agcoauto.com/content/news/p2_articleid/350
Re: silverado heater issue.. [Re: OtisBlkR1] #4655932
02/04/18 02:16 PM
02/04/18 02:16 PM
Specific Ocean
Kibitoshin Offline
Kibitoshin  Offline
Specific Ocean
Here's a video to help understand GM's dual zone climate controls and various blend doors and how to get to them.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L - 170k mi
02 Chevy Silverado C1500 V8 5.3L 154k mi
Re: silverado heater issue.. [Re: OtisBlkR1] #4655989
02/04/18 03:17 PM
02/04/18 03:17 PM
Colorado
AntsinmyEyes Offline
Colorado
if the air temperature was low outside then the pcm probably increased the charging voltage.
1987 mazda rx7
2004 mazda rx8
1995 miata
2005 dodge ram
Re: silverado heater issue.. [Re: OtisBlkR1] #4656191
02/04/18 07:21 PM
02/04/18 07:21 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
My 2006 Silverado does the same thing once or twice a year, The left temperature blend door will swing out of it's calibrated range.....Shutting the engine off & restarting will correct it.
It's done this for years.....I'm still on the original blend door actuators at over 370,000 miles.
Unless it's starts doing it often....I would leave it be!!!
2001 Chevy Camaro L92/4L80E
2010 Toyota Corolla 2ZR-FE/Auto
Re: silverado heater issue.. [Re: OtisBlkR1] #4656581
02/05/18 07:24 AM
02/05/18 07:24 AM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
I've seen the actual controls on the dash go bad too. I wouldn't just assume it's a blend door.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: silverado heater issue.. [Re: OtisBlkR1] #4656922
02/05/18 01:40 PM
02/05/18 01:40 PM
stl
MarkM66 Offline
MarkM66  Offline
stl
Re-Calibrate before even looking under the dash.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwj4mceLto_ZAhVuplkKHTKkCocQtwIIKTAA&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DgrF8aRtgu1I&usg=AOvVaw2fziVjuNHdmzftWGfrlYfD
I have a Traverse that was acting up. Thought it was a bad blend door actuator. But resetting the controls fixed it.
Re: silverado heater issue.. [Re: OtisBlkR1] #4661759
02/10/18 10:50 AM
02/10/18 10:50 AM
Indiana
Indiana
good input, ive got the truck out 3 times this week and its not acted up again .
