Brilliant payback for package thieves
by SirTanon. 12/18/18 01:22 PM
Calling all Ford Owners
by dogememe. 12/18/18 01:01 PM
2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
110 registered members (14Accent, 4WD, 53' Stude, 25ring, 28oz, 13 invisible), 2,140 guests, and 39 spiders.
Topics295,222
Posts4,930,323
Members66,716
Most Online2,553
Oct 27th, 2018
MTF in 2012 Nissan Versa #4655677
02/04/18 09:59 AM
02/04/18 09:59 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
What fluid would you use in a 2012 Nissan Versa Manual Transmission? It has the 1.8 and the Amsoil site says:
Manual Transmission,N/A (6-SPD)......GL-4
All TEMPS......75W-80
No AMSOIL Product Recommendation
So I'm guessing I better stay with Nissan OEM??
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 60K
Amsoil in all engines, transmissions and differentials
Re: MTF in 2012 Nissan Versa [Re: Gebo] #4655695
02/04/18 10:13 AM
02/04/18 10:13 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Good luck finding something that is "75W80". It's a manual transmission, not the Space Shuttle. Redline makes something that will work fine as do others, even if it's not exactly a 75W80.
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: MTF in 2012 Nissan Versa [Re: Gebo] #4655697
02/04/18 10:14 AM
02/04/18 10:14 AM
South Carolina
bmwtechguy Offline
bmwtechguy  Offline
South Carolina
Redline has a product that would work. I have heard of people mixing Amsoils MTF and MTG to get close to the required viscosity, but I have no idea if this is a good idea. If needed, I would probably try it on my own car or an older car that was out of warranty since I keep both of these products in stock.
Re: MTF in 2012 Nissan Versa [Re: Gebo] #4655709
02/04/18 10:27 AM
02/04/18 10:27 AM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
Any of the following would qualify as a 75W80:
C. The next higher viscosity MTL group is in the 8.0 cSt to 8.9 cSt Range would be:
1. Castrol Syntrans V FE (8.0cSt)
2. Redline DCTF Dual Clutch Transmission Fluid (8.1 cSt)
3. The next higher viscosity would be BG Synchroshift II (8.2 cSt)
4. RAVENOL PSA
D. The next higher viscosity MTL group in the 9.0 to 9.5 cSt range is (SAE 75W80):
1. Mopar Type MS-9417 MTL 9.0 cSt
2. Valvoline MTF Part Number 811095 9.2 cSt
3. Pennzoil Synchromesh 9.3 cSt
4. RAVENOL PSA 9.5 cSt
5. RAVENOL SSG 9.5 cSt
E. The next group of MTLís are in the 9.6 to 10.X cSt range (SAE 75W80):
1. Redline MTL 75W80
2. Amsoil MTF (9.7 cSt)
3. GM Synchromeshís
4. Volvo MTF 645
5. Fuchs TITAN SINTOFLUID SAE 75W-80 synthetic MTF (Carries a GL-5 rating as well)
6. Lodexol (Morris Lubricants) MTF
7. Motylgear 75W-80
Recommendation: Buy a quart of the Nissan fluid and have it analyzed for its viscosity @ 100C and we can narrow down the recommendations.
If you look at the ridiculous SAE viscosity range of a 75W80 it can mean a large range in viscosities.
https://www.bobistheoilguy.com/viscosity-charts/
Scars remind us of where we have been, but do not have to dictate where we are going.
Re: MTF in 2012 Nissan Versa [Re: Gebo] #4655710
02/04/18 10:28 AM
02/04/18 10:28 AM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
Viscosity chart
Any quality MTF in the 8-9 cSt at 100c should work ok. Check out Molakule's Transmission oil listing for GL4 ratings...there are a number of choices. First thing that comes to mind would be the Pennzoil/GM synchromeshes. 75w-80 actually covers a pretty wide range.
note: looks like Molakule beat me by a minute.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: MTF in 2012 Nissan Versa [Re: Gebo] #4655829
02/04/18 11:55 AM
02/04/18 11:55 AM
Texas (south)
FermeLaPorte Offline
Texas (south)
I got a Versa and i changed the MTF. I think you should use the Nissan OEM Fluid.
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: MTF in 2012 Nissan Versa [Re: Gebo] #4657602
02/06/18 06:02 AM
02/06/18 06:02 AM
Richmond, VA
DNVDMAX Offline
DNVDMAX  Offline
Richmond, VA
I used pennzoil synchromesh with great success in my 2012 1.6 Versa. It performed well in 100+ degree Georgia heat and Alaskan -40F weather. Shifting was butter. FYI in case you havenít changed it before the drain plug on my Versa was an 8mm square drive, picked up a whole set of square drives for about $10 at Harbor Freight.
06 GMC 2500HD DMAX EFILIVE M1 TDT 5w-40 FRAM Ultra
91 GMC K1500 5.7L 5w-30 Quaker State HM Bosch D+
72 Nova 350 SBC 74mm AirWerks Turbo 15w-40 HDEO
Re: MTF in 2012 Nissan Versa [Re: Gebo] #4660133
02/08/18 04:25 PM
02/08/18 04:25 PM
Salt Lake City Utah
sirgerman Offline
sirgerman  Offline
Salt Lake City Utah
Re: MTF in 2012 Nissan Versa [Re: FermeLaPorte] #4682469
03/02/18 04:16 PM
03/02/18 04:16 PM
Perpetual Winter USA
Smash209 Offline
Smash209  Offline
Did you end up with 75w-80 or 75w-85? It seems Nissan changed what they are stocking/re-branding. I have a Sentra and am now on the fence between the new "oem" fluid or something that better matches the original spec.
Re: MTF in 2012 Nissan Versa [Re: Gebo] #4682564
03/02/18 05:42 PM
03/02/18 05:42 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
75-85
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 60K
Re: MTF in 2012 Nissan Versa [Re: Gebo] #4694681
03/14/18 02:00 PM
03/14/18 02:00 PM
Smash209 Offline
Smash209  Offline
Got any of that Nissan 75w85 left to run a VOI on?
