Which Exhaust Manifold Should I Buy
by Miller88. 12/14/18 08:10 AM
Rotella T5 10w30 Ford 6.7L anyone?
by sw99. 12/14/18 07:49 AM
Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
captobvious, pgrkcs, 4Doors4Life, 780Ari, kayumb
66677 Registered Users
86 registered members (andyd, 1foxracing, 2004tdigls, Anthony, AndyB, AandPDan, 11 invisible), 1,126 guests, and 42 spiders.
Topics295,048
Posts4,926,853
Members66,677
Most Online2,553
Oct 27th, 2018
Generic ATF+4 #4655552
02/04/18 07:52 AM
02/04/18 07:52 AM
Australia
supercity Offline OP
Australia
As far as I can tell, there are no ATF+4 licenced lubes available in Australia other than genuine and I'm not even going to bother asking for a price.
Most local marketers here recommend their multivehicle lubes for ATF+4, these are typically synthetic recommended for Dex/Mercon, Mercon V, MV, T-IV, SP-III etc. I've used one in a T-IV application with good results. I'm thinking about using the same in a 6 speed Dodge Journey. Any experiences?
Re: Generic ATF+4 [Re: supercity] #4655563
02/04/18 08:00 AM
02/04/18 08:00 AM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
I have a Dodge Grand Caravan. This is my first vehicle using an ATF+4.
In other vehicles I've used a multivehicle ATF like Maxlife ATF or Mobil 1 ATF, with good results.
However, with the Caravan I will only be using an ATF+4. IMO these transmissions are too finicky. I've also read that the old Dodge/Chrysler Trannys had failures when people used the wrong fluids in them.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Generic ATF+4 [Re: supercity] #4655566
02/04/18 08:01 AM
02/04/18 08:01 AM
SD
zrxkawboy Offline
zrxkawboy  Offline
SD
Compatibility seems to be hit-or-miss with the MV ATFs and Chrysler transmissions. To be safe, I'd stick with ATF+4.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Generic ATF+4 [Re: supercity] #4655591
02/04/18 08:23 AM
02/04/18 08:23 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
I'm afraid MV ATF may not be suitable in applications calling for ATF+4.
Re: Generic ATF+4 [Re: supercity] #4655607
02/04/18 08:44 AM
02/04/18 08:44 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Australian Amazon?
Certainly the dealer could hook you up with some bulk?
I wouldn't run a non ATF+4 fluid.
03 Jeep WJ 4.0 202k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Generic ATF+4 [Re: supercity] #4655653
02/04/18 09:36 AM
02/04/18 09:36 AM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
What year is your Dodge Journey? There are 2 6 speed autos that came in those. Chrysler has a lot of transmissions. Many are not Chrysler trans but others with their name on it so the Mutli vehicle syn fluids work ok in those.
Like the NAG1 is a Mercedes 722.6 and Valvoline maxlife works fine in those for example.
If yours has the 62TE then I would use a fluid that meets ATF+4. Those are picky.
If you have the Getrag Mps6 DCT those I don;t think take ATF+4 but a different dual-clutch manual fluid.
yup
Re: Generic ATF+4 [Re: supercity] #4655670
02/04/18 09:50 AM
02/04/18 09:50 AM
Lima, Ohio, USA
earlyre Offline
earlyre  Offline
Lima, Ohio, USA
here is the official licensed list:
http://www.centerforqa.com/chrysler-brands-print/
many of the brands are indicated as "global" do any of those ring a bell?
Mine:
09 Mercury Sable : 6qts AutoQuest(Meijer/Warren) 0w20, WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts VWB 5w30,WIX 51394
Re: Generic ATF+4 [Re: supercity] #4655684
02/04/18 10:05 AM
02/04/18 10:05 AM
Lima, Ohio, USA
earlyre Offline
earlyre  Offline
Lima, Ohio, USA
huh...even on the Castrol Australia site, for that car, and it's fiat twin, under transmission it just says refer to dealer..
Mine:
Mine to Maintain:
Re: Generic ATF+4 [Re: zrxkawboy] #4655700
02/04/18 10:19 AM
02/04/18 10:19 AM
northern NY
Driz Offline
Driz  Offline
northern NY
Yea, you dump any Dextron3 in there and itíll very soon be shifting funny and you will be doing it all over again . Just donít do it . The higher grades may be compatible though but make sure because Chryslerís trannyís are fussy...
Re: Generic ATF+4 [Re: supercity] #4655705
02/04/18 10:26 AM
02/04/18 10:26 AM
South Carolina
bmwtechguy Offline
bmwtechguy  Offline
South Carolina
I have had very good success in 4 speed Dodge FWD with Amsoil universal ATF. But the newer 6 speeds, I have no experience, and the cost might be as high as dealer fluids there? I think Redline makes a Chrysler-specific ATF+4 fluid.
Re: Generic ATF+4 [Re: supercity] #4655707
02/04/18 10:27 AM
02/04/18 10:27 AM
Sask, Canada
BrianF Offline
BrianF  Offline
Sask, Canada
I used a PAO based fluid that was "suitable for use" with ATF+4 in my 2011 Ram 1500 with the 545RFE. It ran just as good as the factory fill while heavily loaded and unloaded.
I realized that the transmission did not care one bit.
2006 Trailblazer LT. QSUD with Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30 with Hastings LF608.
1993 GMC 1500. QSAD with Fram PH5
Re: Generic ATF+4 [Re: supercity] #4655718
02/04/18 10:33 AM
02/04/18 10:33 AM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
It might help to actually list what else is available, give some links, etc.
Various musings: http://hangfire.net
Re: Generic ATF+4 [Re: supercity] #4655962
02/04/18 01:56 PM
02/04/18 01:56 PM
USA
slacktide_bitog Offline
USA
If you can get Red Line C+ in Australia, go with that. Even though it's not licensed, the C+ is by far the best ATF for transmissions calling for ATF+4. It uses the same add pack as licensed ATF+4, but with a Group V ester base stock (which is why Chrysler won't license it--they are way to strict about the group III they require)
Re: Generic ATF+4 [Re: slacktide_bitog] #4656445
02/04/18 10:26 PM
02/04/18 10:26 PM
FT Hood TX
dave1251 Offline
dave1251  Offline
FT Hood TX
I don't believe it's ester based. It has been confirmed thier motor oils are only 10% ester. I would not have concerns using it but it would have to be price competitive for me to use it.
don't use.
Re: Generic ATF+4 [Re: supercity] #4657389
02/05/18 07:53 PM
02/05/18 07:53 PM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
I do not own any Chrysler products, nor have I used Redline C+, but I have used Redline D4 and it is the best "butt dyno" transmission fluid I have ever used.
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi
2009 Scion tC Manual (Daily Driver) 165k mi
