Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
104 registered members (69Torino, 2012AccentSE, 2010Civic, 69GTX, 1978elcamino, 8 invisible), 1,805 guests, and 51 spiders.
Topics286,112
Posts4,902,848
Members67,565
Most Online2,967
Mar 10th, 2019
1993 Mercedes 300D problems shifting 2nd-3rd #4655279
02/03/18 09:31 PM
02/03/18 09:31 PM
Stewartstown PA
spiderbypass Offline OP
Stewartstown PA
I purchased a 1993 Mercedes 300D about a year ago. Car has always shifted quirky in that if leave it in drive it will go from second to fourth missing third. I “rectified” that issue by keeping it in D-3 and when it gets to third have put it in drive to go to forth gear. I have driven car about 40000 miles total-and within last few months the car shifts fine from second to third when it is cold and in the initial stages of warming up. As the car gets to operating temperature I have to rev car to 4000-4500 rpm and then let foot off pedal slightly for it to shift into third gear then it shifts perfectly from third to fourth. A few times it would not shift even with revving method. Money has been tight but know need to bring it to independent shop that would work on these cars. Wondered if anyone has ideas about the nature of the problem.
Insecurity with overcompensation are the root of evil deeds.
Re: 1993 Mercedes 300D problems shifting 2nd-3rd [Re: spiderbypass] #4655284
02/03/18 09:37 PM
02/03/18 09:37 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Changed the transmission oil yet? It will likely solve the problem, or would have.
Sounds like a sticky valve body.
"Zed's dead baby, Zed's dead."
Re: 1993 Mercedes 300D problems shifting 2nd-3rd [Re: spiderbypass] #4655298
02/03/18 09:49 PM
02/03/18 09:49 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
I'd try that question on Benzworld.org or MBworld.org.
Re: 1993 Mercedes 300D problems shifting 2nd-3rd [Re: spiderbypass] #4655318
02/03/18 10:15 PM
02/03/18 10:15 PM
ME
eljefino Offline
eljefino  Offline
ME
There are springs in the valve body, K1 and K2, something like that. One is broken or tired. If you can drop a pan you can change these-- just hiding behind a flat head screw.
Re: 1993 Mercedes 300D problems shifting 2nd-3rd [Re: spiderbypass] #4655340
02/03/18 10:37 PM
02/03/18 10:37 PM
Stewartstown PA
Stewartstown PA
Have changed fluid and filter twicesince bought car. I will look up the K spring set thing. II guess because it is older and bought cheaply for 3000 did not think to join a Mercedes Benz forum. It is daily driver has 245000 on it now and have used mainly 229.5 oils in it and runs strong-not fast and iwith no leaks. Appreciate the quick responses.
Re: 1993 Mercedes 300D problems shifting 2nd-3rd [Re: spiderbypass] #4655409
02/04/18 12:22 AM
02/04/18 12:22 AM
Michael_P Offline
Michael_P  Offline
Check the bowden cable. Sounds stretched or mis adjusted. Some might say this is not the case because the symptoms change with the temperature changing. But I have seen this problem before. Valve body is a great suggestion. I figured start with the bowden cable because its external.
Re: 1993 Mercedes 300D problems shifting 2nd-3rd [Re: spiderbypass] #4655492
02/04/18 06:07 AM
02/04/18 06:07 AM
FL
mcrn Offline
mcrn  Offline
FL
I had an 83 that did something similar and it was a vacuum leak......vacuum system was huge on the 83....not sure how much that system controls on the 93's.
2012 Nissan Rogue
Re: 1993 Mercedes 300D problems shifting 2nd-3rd [Re: spiderbypass] #4655515
02/04/18 07:53 AM
02/04/18 07:53 AM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
From some quick digging it appears the transmission in your car is a non-electronic 722.4 which is pretty similar to the 722.3 used in the W123's ten years prior. If "722.4" and "W123" are gibberish to you, I highly suggest you join a MB forum and change that - these cars can be great but are not simple or intuitive compared to anything domestic. Everybody preaches "kickdown, vacuum, and fluid pressure adjustment" but they do so for a reason. I'd bet money once you get on to an enthusiast group the first questions they'll ask is if you've checked those three things ^ and if not, "it may be (X) but you need to adjust it to spec first then dig deeper." Enjoy...
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: 1993 Mercedes 300D problems shifting 2nd-3rd [Re: spiderbypass] #4656155
02/04/18 06:13 PM
02/04/18 06:13 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
A little OT, but the fact that you were able to put 40K in a year on a car you bought at 24 years from build speaks very well of the quality that Mercedes built into the W124.
I still prefer the W123 as a driver, but the 124 was apparently a very well built machine.
They also don't rust as badly as the 123s.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: 1993 Mercedes 300D problems shifting 2nd-3rd [Re: fdcg27] #4661552
02/10/18 03:53 AM
02/10/18 03:53 AM
FL
mcrn Offline
mcrn  Offline
FL
What about the 123 do you prefer as a driver?
2012 Nissan Rogue
Re: 1993 Mercedes 300D problems shifting 2nd-3rd [Re: spiderbypass] #4661637
02/10/18 08:28 AM
02/10/18 08:28 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
