White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
23 registered members (Char Baby, BretK, ChrisD46, billt460, c502cid, DaleRider, 4 invisible), 801 guests, and 35 spiders.
Topics296,866
Posts4,960,388
Members66,982
Most Online2,688
Jan 19th, 2019
Today's turbos #4655236
02/03/18 07:54 PM
02/03/18 07:54 PM
MA.
Camprunner Offline OP
MA.
Are today's turbos installed on say Ford Ecoboost motors, The new Honda Accord, say most Europen cars water cooled oil cooled or both? The turbos seem to last longer then cars in the 80's or 90's with turbos.
Re: Today's turbos [Re: Camprunner] #4655242
02/03/18 07:58 PM
02/03/18 07:58 PM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
Ford's are water cooled, as is I believe most others.
Re: Today's turbos [Re: Camprunner] #4655251
02/03/18 08:02 PM
02/03/18 08:02 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
They're typically water and oil cooled, and made better than ever. Some OE turbos are ball-bearing.
"Vintage" turbos will last forever too if a quality oil is used.
It helps to let your oil come up to temp before putting your big boot down on the gas pedal, and it also helps to not park your car and walk away with the turbine glowing red-hot. True for all turbos.
"Zed's dead baby, Zed's dead."
Re: Today's turbos [Re: Camprunner] #4655269
02/03/18 08:23 PM
02/03/18 08:23 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Might be next to impossible to find a non-water cooled turbo on a gasoline engine right now
There's no replacement...'scosity for natural viscosity
Re: Today's turbos [Re: Camprunner] #4655270
02/03/18 08:23 PM
02/03/18 08:23 PM
New England
madRiver Offline
madRiver  Offline
New England
Turbos have nearly 30 years of time to make superior materials and construction. Also most turbos have natural convection design built into cooling system to maintain coolant and or oil flow on shut off which was hard on them. Lastly engine control and boost control was very primitive. And oil is superior now.
Re: Today's turbos [Re: Camprunner] #4655275
02/03/18 08:27 PM
02/03/18 08:27 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Anyone remember the turbo Corvair? Air cooled engine and GM. 1965 to 1966 !!
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Today's turbos [Re: CT8] #4655325
02/03/18 09:27 PM
02/03/18 09:27 PM
NH
supton Offline
supton  Offline
NH
Slightly before my time (heck my dad was a kid!).
I managed 255k on my diesel turbo before it quit. I guess it was oil cooled? wasn't water cooled for sure. Have a tough time believing that they can't go the distance today.
2011 Toyota Camry, base, 2.5L/6MT, 176k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 145k, ours
1999 Toyota Camry LE, 2.2L/4AT, 199k, his
Re: Today's turbos [Re: Camprunner] #4655381
02/03/18 10:34 PM
02/03/18 10:34 PM
USA
slacktide_bitog Offline
USA
Do they still use turbo timers? I heard of them being used on 80s turbos, that keep the engine running for 30 seconds after you turn the car off. These should be required for all turbos.
Todays's turbos are probably worse, with DI, the LSPI, turbos engaged almost all the time rather then only when you need the extra boost power, and saying it's ok to use regular 87 octane and 0w20 crzy
They are water cooled
Re: Today's turbos [Re: Camprunner] #4655386
02/03/18 10:42 PM
02/03/18 10:42 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Turbo timers are still used by some people. When I had a turbo car, 2004 Volvo S60R, I would try to either let the car idle for a minute before shutting off or at least try to avoid boost for a bit before parking.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Today's turbos [Re: Camprunner] #4655389
02/03/18 10:45 PM
02/03/18 10:45 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Turbo timers are pointless unless you make a habit of drag racing to your parking spot.
Modern cars with electric water pumps will continue to circulate water after being parked if certain parameters for ambient and component temperature are met.
Re: Today's turbos [Re: Camprunner] #4655407
02/03/18 11:20 PM
02/03/18 11:20 PM
Minneapolis
antonmnster Offline
antonmnster  Offline
Minneapolis
My 335 has an electric water pump. You might hear it whiring for 10 minutes or so after a 400-mile summer drive.
Re: Today's turbos [Re: rooflessVW] #4655408
02/03/18 11:21 PM
02/03/18 11:21 PM
Alaska
AlaskaMike Offline
AlaskaMike  Offline
Alaska
You're looking at it from the perspective of someone drives a car. A diesel truck or SUV towing 10,000 lbs will have a red-hot turbine even when the driver is as gentle as possible. In a case like that a turbo timer is extremely convenient.
That said, I don't have one on my diesel truck--I just make a point to start coasting as early as possible before I pull into a parking space. More often than not my exhaust temp gauge reads less than 300 degrees F and I'm able to immediately shut down the engine. Very rarely do I need any idle time to cool the turbo when I'm not towing or hauling anything.
Re: Today's turbos [Re: Camprunner] #4655437
02/04/18 12:26 AM
02/04/18 12:26 AM
New Zealand
Silk Offline
Silk  Offline
New Zealand
Turbo timers were the in thing in the 90's and early 2000's, but I hardly see them these days - I think people realised there wasn't much point. Unless you switch off right after full load, normal driving will cool the turbo down. By the time I've come off the open road and driven though town to my place, there is not much point in letting it run for another minute or so. I've got a couple of old timers lying around, I don't see the point of fitting them to my current turbo car.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Today's turbos [Re: Camprunner] #4655444
02/04/18 12:46 AM
02/04/18 12:46 AM
Massachusetts
VeryNoisyPoet Offline
Massachusetts
Even my late 90s car has a water cooled turbo, and the tech has only gotten better. I still make sure I drive gently for the last bit of a trip and let it idle a minute or so if I need to stop suddenly after a hard run.
The advantage of the water cooling is that water continues to circulate even after the pump stops (thermosiphon). This absorbs and carries a great deal of heat away from the turbo bearings and the oil within. Here's a white paper talking about this more in detail with images of heat damage and oil coking on abused or improperly plumbed turbos. https://www.turbobygarrett.com/turbobyga...ter_Cooling.pdf
1998 V70 GLT / 195k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Today's turbos [Re: Camprunner] #4655516
02/04/18 06:57 AM
02/04/18 06:57 AM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
I think a turbocharger is oil-cooled by its nature - but I believe, especially on gas engines, water-cooling is pretty much universal now. My Cruze is - 109K and counting on 5K OCI's of Synpower, baby!
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
