Toyota factory pink mixed with zerex coolant
by Rohan. 04/21/19 04:48 PM
Schaeffer 204SAT and 205A
by Gebo. 04/21/19 04:32 PM
Oil for old Chevy TBI 350
by RonRonnster. 04/21/19 04:19 PM
2012 chevy equinox transmission fluid
by krdoss. 04/21/19 03:50 PM
How Often Change Fuel Filters?
by Gebo. 04/21/19 03:17 PM
New Hyundai Elantra tell me all I need to know
by DONWATERS. 04/21/19 02:28 PM
How much balance weight is too much
by Hitman70. 04/21/19 02:02 PM
bought steel cut oats by mistake
by andyd. 04/21/19 01:50 PM
Mobil1 Synthetic Lubricating Spray
by EvanR. 04/21/19 01:01 PM
List of cars you've owned
by SLO_Town. 04/21/19 12:30 PM
Email Notice
by borgward. 04/21/19 12:14 PM
Why would 10w burn more than 5w?
by D1dad. 04/21/19 11:57 AM
02 Silverado 5.3L, LT, Low Oil Pressure
by Gito. 04/21/19 11:54 AM
0 to 60 in 1.9 seconds...
by JeffKeryk. 04/21/19 11:16 AM
Luxury Car Owners Switching to Pickup Trucks
by SubLGT. 04/21/19 11:05 AM
Easiest Way to Gravity Bleed Brakes
by jims5600. 04/21/19 10:55 AM
Newcastle Brown Ale replacement?
by Reddy45. 04/21/19 10:31 AM
Easter Sunday
by gman2304. 04/21/19 10:17 AM
Old Buick Century Question
by GrtArtiste. 04/21/19 10:03 AM
Texas72, RamblerReb, rchapin, js1956, krdoss
67865 Registered Users
94 registered members (alphadog, andyd, 2dogs, 53' Stude, 2015_PSD, 240_Ed, 12 invisible), 1,891 guests, and 26 spiders.
Topics287,853
Posts4,935,596
Members67,865
Most Online2,967
Mar 10th, 2019
2002 Silverado 5.3 Starter #4655068
02/03/18 05:31 PM
02/03/18 05:31 PM
CA
Gito Offline OP
Gito  Offline OP
CA
2002 Chevy Silverado
Need a new starter from a reputable manufacture
Any recommendations is greatly appreciated.
Re: 2002 Silverado 5.3 Starter [Re: Gito] #4655073
02/03/18 05:37 PM
02/03/18 05:37 PM
Michigan
khittner Offline
khittner  Offline
Michigan
New lifetime warranty Remy: $95 at RockAuto. New Remy Starter Motor
Re: 2002 Silverado 5.3 Starter [Re: Gito] #4655112
02/03/18 06:21 PM
02/03/18 06:21 PM
MN
14Accent Offline
14Accent  Offline
MN
Nothing from anywhere outside the country. They're ALL trash.
See if someone local still rebuilds with quality parts. Take yours in and swap for one of those.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: 2002 Silverado 5.3 Starter [Re: Gito] #4655120
02/03/18 06:38 PM
02/03/18 06:38 PM
Loganville GA USA
odotb Offline
odotb  Offline
Loganville GA USA
Better yet, get your original rebuilt and reinstall it. No fitment headaches that way.
Re: 2002 Silverado 5.3 Starter [Re: Gito] #4655131
02/03/18 06:57 PM
02/03/18 06:57 PM
CA
Gito Offline OP
Gito  Offline OP
CA
Well first time my original starter went out I sent it out to a reputable shop to get rebuilt. Failed within 4 years.
I have a lifetime warranty on it but need to find the receipt or they will not honor it.
Re: 2002 Silverado 5.3 Starter [Re: Gito] #4655206
02/03/18 08:27 PM
02/03/18 08:27 PM
MN
14Accent Offline
14Accent  Offline
MN
4 years out of a decent rebuild or 4 months out of a Chinese or Mexican unit? I know which one I would have.
Re: 2002 Silverado 5.3 Starter [Re: Gito] #4655324
02/03/18 10:24 PM
02/03/18 10:24 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
ACDelco 12617229 GM Original Equipment Starter..... HERE
Solenoid Pigtail (Metripack/sealed)..... HERE
Optional Starter Heat Sheild..... HERE
You will need 3 bolts to mount the heat shield to the stater......M5x0.8mm-10mm long.
This is a brand new GM Original Equipment starter for 2010-2015 Camaros. It will fit your 2002 5.3L by simply splicing the above pigtail to you solenoid wire. I recommend the Heat Shield but it's not mandatory.
2001 Chevy Camaro L92/4L80E
Re: 2002 Silverado 5.3 Starter [Re: Gito] #4660504
02/09/18 12:00 AM
02/09/18 12:00 AM
CA
Gito Offline OP
Gito  Offline OP
CA
Replaced starter and problem solved.
Was not able to find receipt for lifetime warranty so I had to suck it up and buy a starter from Auto-zone.
Hoping it will last a few years.
Re: 2002 Silverado 5.3 Starter [Re: Gito] #4660654
02/09/18 09:02 AM
02/09/18 09:02 AM
Kansas
Kruse Offline
Kruse  Offline
Kansas
Did you buy new or rebuilt? Just for the sake of being curious here, but did your rebuilder guarantee that the whole starter would be good for a lifetime or ONLY WHAT THEY ORIGINALLY REPAIRED?
Seems a lot of shops have a way of sidestepping the lifetime warranty.
The wiring and insulation on any starter or alternator is affected by heat. While I'm all in favor of rebuilding the OEM starter/alternator, chances are it won't last as long the second time around.
Edit: Saw in your original post you wanted it new.
Re: 2002 Silverado 5.3 Starter [Re: Gito] #4661492
02/10/18 12:15 AM
02/10/18 12:15 AM
Cajun Country, La.
BlueOvalFitter Offline
Cajun Country, La.
It's been years, but I have always rebuilt my own starters. And, if I were to buy from a local parts store it would be NAPA. Online, ROCK AUTO.
2007 F150, 4.2 V6
Havoline HM 5W20, NAPA GOLD FIL-1516 MC FL-400S
"One Box, One OCI!"
Re: 2002 Silverado 5.3 Starter [Re: Kruse] #4661681
02/10/18 09:28 AM
02/10/18 09:28 AM
CA
Gito Offline OP
Gito  Offline OP
CA
Rebuilder of the original OEM starter stressed that need receipt to honor lifetime warranty.
Couldn't find receipt so I had to buy a new starter at Auto-zone. Napa was closed (Sunday) and needed my truck by Monday.
AutoZ did tell me that if the starter went bad on me that I could return it for a full refund within one year.
I hesitated but then AutoZ is local so I took it because of convenience and because I had no other choice (on a Sunday).
The reputable starter/generator rebuilder in my book is no different than AutoZ. The starter didn't last very long.
I'm starting to believe that most rebuilders also sell junk, just like most stores.
Re: 2002 Silverado 5.3 Starter [Re: Gito] #4661774
02/10/18 11:00 AM
02/10/18 11:00 AM
Indiana
OtisBlkR1 Offline
OtisBlkR1  Offline
Indiana
find yourself a local shop that rebuilds.. most do it for less than the price of a cheap replacement, and do it better.. if you have a spare car, id go that route.
06 Silverado 92,xxx Mobil 5-30
11 Honda Accord 38,xxx Mobil 1
06 Milan 69,000 Mobil 1
12 Ranger 800XP & 14 TRX 450R
Re: 2002 Silverado 5.3 Starter [Re: OtisBlkR1] #4661822
02/10/18 11:31 AM
02/10/18 11:31 AM
Cajun Country, La.
Cajun Country, La.
This is a good route to go as well.
My dad owns an 06 LTC. The alternator went out and he had a local shop that only rebuilds starters and alternators, rebuild his. That was almost 4 years ago. Rebuild, remove and install, $150+tax.
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: 2002 Silverado 5.3 Starter [Re: Gito] #4662043
02/10/18 03:38 PM
02/10/18 03:38 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Did you get the Duralast Gold new starter? I have seen them and cant say anything bad about the fit and finish of them and they seem to last okay.
I suspect they come from the same company who makes them for Remy, Car Quest, Cardone select and probably quite a few others worldwide.
Like it or not (I don't but I live with it) the Chicoms are owning this manufacturing game and doing a better job of it all the time.
I bought some Dorman (God forbid) non sealed hubs for a VW that only needed to last a year for a rat, year 3 is coming up and they look like new inc the tone ring. This is a high precision part with close tolerances and requires fine machining.
OE is $185 per side the Chicom under $16 and the cheap SOB is very good no debate, its still true and rust free in the salt belt.
Re: 2002 Silverado 5.3 Starter [Re: Trav] #4662134
02/10/18 05:32 PM
02/10/18 05:32 PM
Cajun Country, La.
Cajun Country, La.
Christmas Eve 2010, I had gone to AZ to buy a bottle of #9 Meguiars swirl remover for a job I was doing on the side. I get in my truck to leave, turn the key, NOTHING! I had to put out $111 for a DURALAST battery. It lasted until 2014. It had a 5 yr. warranty. The one they installed currently (NO CHARGE) only has a 3 yr. warranty and is still going. But, I'm sure its day is coming, soon!
2007 F150, 4.2 V6
"One Box, One OCI!"
