Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
78 registered members (Alfred_B, 2010Civic, Ama0787, ABCarr, 69GTX, 2015_PSD, 8 invisible), 1,503 guests, and 61 spiders.
Topics286,215
Posts4,904,411
Members67,579
Most Online2,967
Mar 10th, 2019
Avalanche 4wd #4655062
02/03/18 05:21 PM
02/03/18 05:21 PM
out there
spasm3 Online content OP
spasm3  Online Content OP
out there
Used my 4wd in last in december, i remember it was slow to engage. It will not engage now. the 4wd light just blinks. I checked cleaned and reinstalled the ground bolts behind the drivers front wheel well. That made no difference.
Do i need to replace the transfer case actuator motor? When i press the 4wd or 4wd low button, i don't hear anything change no sounds.
I know little about 4wd systems. The wiring connectors all look good.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Avalanche 4wd [Re: spasm3] #4655093
02/03/18 05:49 PM
02/03/18 05:49 PM
wv
krismoriah72 Offline
wv
I have an 03 suburban..mine did the same thing. I found a broken wire near the transfer case..
Re: Avalanche 4wd [Re: spasm3] #4655237
02/03/18 08:56 PM
02/03/18 08:56 PM
Pittsburgh
SkipsterPA Offline
SkipsterPA  Offline
Pittsburgh
Could be your switch or motor. The motor on my 04 went a couple years ago. There's some good info on the forums at Chevyavalanchefanclub.com. It's apparently a common issue with this body style. I think the solder joints in the switch tend to fail but can be easily reflowed though.
2003 Sable
2004 Hyundai XG350
2004 Avalanche
2016 Elantra
Re: Avalanche 4wd [Re: SkipsterPA] #4655995
02/04/18 03:21 PM
02/04/18 03:21 PM
out there
out there
Thanks! I saw some posts about what you mentioned. So i'm pulling the switch and i will try the re-flow of solder!
Re: Avalanche 4wd [Re: spasm3] #4656068
02/04/18 04:37 PM
02/04/18 04:37 PM
out there
out there
That did not work, so i'm going to replace the transfer case motor.
Re: Avalanche 4wd [Re: spasm3] #4656288
02/04/18 08:42 PM
02/04/18 08:42 PM
Pittsburgh
SkipsterPA Offline
SkipsterPA  Offline
Pittsburgh
If you can get the driveshaft off, it's easier. I did mine without dropping it but it was a pain. Kind of tight quarters but do-able.
2003 Sable
2004 Hyundai XG350
2004 Avalanche
2016 Elantra
Re: Avalanche 4wd [Re: SkipsterPA] #4656297
02/04/18 08:52 PM
02/04/18 08:52 PM
out there
out there
Thanks! I was planning on dropping it. But since you did it around it, i will try that first!
