AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
63 registered members (2003f7, Aero540T, 2010Civic, agpatel, Aichiguy, 5 invisible), 1,279 guests, and 61 spiders.
Topics286,439
Posts4,908,173
Members67,622
Most Online2,967
Mar 10th, 2019
chinese 3125xr8 atv oil question #4654936
02/03/18 03:01 PM
02/03/18 03:01 PM
oklahoma
hyperscion Offline OP
oklahoma
do i need reg oil or motocycle oil for this thing? its 125cc engine thats all i know and pretty new.
how to keep this thing running good? any mods?
I dont have much money so the chinese 3125 xr8 is what I got. But no info on the machine? its automatic im gueissing cvt trans.
But I dont know the proper oil specs...?
Re: chinese 3125xr8 atv oil question [Re: hyperscion] #4654941
02/03/18 03:07 PM
02/03/18 03:07 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Is there any kind of brand name attached to it?
If you want the job done right......do it yourself.
Re: chinese 3125xr8 atv oil question [Re: hyperscion] #4654943
02/03/18 03:10 PM
02/03/18 03:10 PM
Basehor, KS
JayhawkRoy Offline
JayhawkRoy  Offline
Basehor, KS
15W40, per Wholesale Motorsports, who sells them.
Re: chinese 3125xr8 atv oil question [Re: hyperscion] #4654954
02/03/18 03:25 PM
02/03/18 03:25 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Looks like it doesn't have a wet clutch. So the oil only lubes the engine.
In that case, you can use any 30 or 40 weight. I would use cheap store brand 15W40. Its cheap, and it works.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: chinese 3125xr8 atv oil question [Re: Snagglefoot] #4654959
02/03/18 03:29 PM
02/03/18 03:29 PM
oklahoma
oklahoma
coolster. only gears f and r . thanks
Re: chinese 3125xr8 atv oil question [Re: bubbatime] #4654965
02/03/18 03:35 PM
02/03/18 03:35 PM
oklahoma
oklahoma
i think it is cvt trans. but share oil? between oil and trans? I dont know?
either way would t6- 5w-40 work for both?
I have no money,,,and less cents....
Re: chinese 3125xr8 atv oil question [Re: hyperscion] #4654976
02/03/18 03:45 PM
02/03/18 03:45 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I ran my Suzuki VZ800 Marauder to 84,000 miles on cheap plain 15W-40
Re: chinese 3125xr8 atv oil question [Re: hyperscion] #4654992
02/03/18 04:06 PM
02/03/18 04:06 PM
Reunion Island
Superflan Offline
Superflan  Offline
Reunion Island
Itís not a shared sump with transmission. The centrifugal clutch is located at the end of the CVT assembly, before the final drive, chain drive, and rear axle.
Use any 15W40, 10W40, or 5W40 with API SL or better ACEA A3/B4 oil. Only use W30 oil if climate is below freezing.
Do the first drain early and donít forget to clean pickup screen. These engines tend to throw a lot of metal flakes on first run.
Peugeot Partner 1.9 D, 5W40 C3, 245000 Km, running on WVO
Wife's Mitsubishi Outlander PHEV, dealerís overfilled, 16000 Km
Re: chinese 3125xr8 atv oil question [Re: Superflan] #4655084
02/03/18 05:44 PM
02/03/18 05:44 PM
oklahoma
oklahoma
thank you.
where is pickup screen? and what to change out trans with???
I want the chinese [censored] lube,oil out,, thanks
Re: chinese 3125xr8 atv oil question [Re: hyperscion] #4655202
02/03/18 08:23 PM
02/03/18 08:23 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
These are a wet centrifugal clutch drive. Gas-n-go. "Transmission" shares the engine oil. I had one for my kids for a few years, but it was a 110cc model. They come with regular 10w30 and is typically what the manufacturer will recommend, but 15w40 is a better choice. No effect on the clutch.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: chinese 3125xr8 atv oil question [Re: JTK] #4655435
02/04/18 01:20 AM
02/04/18 01:20 AM
Reunion Island
Superflan Offline
Superflan  Offline
Reunion Island
Chances are thereís some final drive that is in oil, maybe 85W140 EP, 0.1 liter. Send some pics and Iíll tell you what engine it is.
The pickup screen would be in a cover under the engine, openable with a 14mm or 17mm socket.
The oil drain is usually on the left side of the engine, 14mm.
Engine oil capacity is generally less than 1 liter.
