Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
114 registered members (2012AccentSE, 2K2AcuraTL, 69Torino, 1leater, aircooled, 13 invisible), 2,127 guests, and 175 spiders.
Topics286,196
Posts4,903,998
Members67,576
Most Online2,967
Mar 10th, 2019
Lubeguard Red in T-IV or DW-1 #4654751
02/03/18 12:07 PM
02/03/18 12:07 PM
Rochester
Drew1987 Offline OP
Drew1987  Offline OP
Rochester
Hey all
I was told lubrguard red is a great product. I run very fresh (3x drain/fill since 11-2017) T-IV aka Mobil 3309 in my 2002 Lexus with a U150e and 108,000 Miles. There is somewhat fresh (its on my todo list) DW-1 in my 2009 Honda Odyssey 5spd ect. I was thinking of using the Lubeguard Red for its conditioning/protective aspects. Any info on the product?
Thanks all
Re: Lubeguard Red in T-IV or DW-1 [Re: Drew1987] #4654759
02/03/18 12:15 PM
02/03/18 12:15 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I would add it esp to a fluid like T-IV. I know a guy from another Honda forum that works on cars for a living. This was the only additive that he recommended. One of the best trans shops by him would always add a quart to the trans after a rebuild.
Although prob not needed for an HM full synthetic atf like Maxlife fyi.
Re: Lubeguard Red in T-IV or DW-1 [Re: Drew1987] #4654766
02/03/18 12:19 PM
02/03/18 12:19 PM
Rochester
Drew1987 Offline OP
Drew1987  Offline OP
Rochester
Funny you say that about Maxlife. Almost switched to it from T-IV but for $5/qt I just will drain and fill more often with T-IV. I get nervous about mixing the maxlife with the T-IV and also don’t like the idea of doing flush with the cooler lines and buckets with a 16 year old transmission.
As for great Honda, I very well may switch to Transmax or Maxlife and that tranny is prolly going to grenade anyway so maybe one of the full synthetics can add some time
Re: Lubeguard Red in T-IV or DW-1 [Re: Drew1987] #4654767
02/03/18 12:20 PM
02/03/18 12:20 PM
USA
slacktide_bitog Offline
USA
The Lubegard will work fine with no problems, but you'd probably get better results by just using a full synthetic ATF such as the popular Maxlife, or Castrol's Full Synthetic ATF, which is currently on sale at Autozone, 2 quarts for $10. The sale is on for 5 more days. The sale price is valid for any multiple of 2, with no limit.
The Castrol Full Synthetic ATF is good on all Toyota automatic transmissions, and is also a good choice for your Ody smile
No need to flush any transmission, especially since both of yours have a drain plug. If you want to flush, simply do the 3x drain and fill. But even a single drain and fill using the mfr-suggested intervals is sufficient smile
The T-IV/3309 will mix with other fluids with no problems
Re: Lubeguard Red in T-IV or DW-1 [Re: SatinSilver] #4654781
02/03/18 12:29 PM
02/03/18 12:29 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
What's your basis to add it to a modern fluid like T-IV?
Re: Lubeguard Red in T-IV or DW-1 [Re: Drew1987] #4654802
02/03/18 12:49 PM
02/03/18 12:49 PM
Rochester
Drew1987 Offline OP
Drew1987  Offline OP
Rochester
So if both cars got, say, 4 drain/fills within a week, the quart or so that would be left of the original stuff is fine?
The U150e just acts lazy. But that’s how they were new. lubeguard promises to improve shifts. I don’t want to feel them, but they need to be faster. I also want 350,000 miles out of it OR Have a lift to change it. The former is better regardless and the latter isn’t in my near future.
As for the ody, those transmissions suck any way, and it’s been acting a bit wierd. I’m committed enough to the vehicle (I’ve disabled VCM, done the timing belt, done the axels, am about to do motor mounts) so an $800 used tranny if the same/less money to DIY rebuild mine makes sense
Re: Lubeguard Red in T-IV or DW-1 [Re: Drew1987] #4654810
02/03/18 12:56 PM
02/03/18 12:56 PM
USA
USA
correct thumbsup
Re: Lubeguard Red in T-IV or DW-1 [Re: JHZR2] #4654814
02/03/18 12:59 PM
02/03/18 12:59 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Not sure how modern it is. Maybe compared to an older MB's atf it's modern. It's not a full-syn atf either as mentioned. There seems to be many benefits by using it. The info on the Amazon ad sounds promising. LINK
I remember years ago you bought some and offered it for free on here. Apparently, not seeing a need for it. smile
Re: Lubeguard Red in T-IV or DW-1 [Re: Drew1987] #4654818
02/03/18 01:05 PM
02/03/18 01:05 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Wait a minute, so you just did 3 df's back in November? Prob the best thing for it would be a pan drop to replace the filter. Top off with approx. 4 qts atf and 1 qt LGR. thumbsup
Per the instructions add final qt of LGR with engine running and trans in park.
Re: Lubeguard Red in T-IV or DW-1 [Re: Drew1987] #4654822
02/03/18 01:08 PM
02/03/18 01:08 PM
Rochester
Drew1987 Offline OP
Drew1987  Offline OP
Rochester
I believe their WS is an improvement, but t-iv isn’t “special” I just trust it from being in so many 300,000 mile dealer serviced Toyota products, you know? Sat in a 502,000 mile LS400 once. T-IV all the way. Doesn’t mean something new isn’t better, but I tend to be an “old dog”
Re: Lubeguard Red in T-IV or DW-1 [Re: Drew1987] #4654829
02/03/18 01:14 PM
02/03/18 01:14 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
You can call them and ask for help. They're an American family-owned company that makes very good products. They don't over promise and are very realistic about how to use their products.
Re: Lubeguard Red in T-IV or DW-1 [Re: Drew1987] #4654837
02/03/18 01:30 PM
02/03/18 01:30 PM
Rochester
Drew1987 Offline OP
Drew1987  Offline OP
Rochester
Lubeguard you mean, right?
Re: Lubeguard Red in T-IV or DW-1 [Re: Drew1987] #4654845
02/03/18 01:36 PM
02/03/18 01:36 PM
Austin, TX
MaximaGuy Online content
MaximaGuy  Online Content
Austin, TX
Usage of Lubegard is 1Q ATF with 1oz Lubeguard. If the transmission capacity is 8-10Q, then dump the entire 10oz bottle and get done with it.
Now any transmission will like the Lubeguard Red and is can be used with syn and sem-syn fluids.
Having said that in no way is T-IV inferior that by adding Lubeguard will make it superior. That is simply nonsense.
2018 MB GLE350
2011 Lexus ES350
2006 Toyota Highlander 4WD
Re: Lubeguard Red in T-IV or DW-1 [Re: Drew1987] #4654880
02/03/18 02:10 PM
02/03/18 02:10 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Check it out from the maker. Too many arm chair quarterbacks giving advice.
http://www.lubegard.com/~/C-112/LUBEGARD+Automatic+Transmission+Fluid+Protectant
The "thinking" man's friend.
Re: Lubeguard Red in T-IV or DW-1 [Re: Drew1987] #4654883
02/03/18 02:11 PM
02/03/18 02:11 PM
Rochester
Drew1987 Offline OP
Drew1987  Offline OP
Rochester
When I was a kid, I used to drain and fill every 20,000 and substitute one qt of ATF with Lucas. I beat the [censored] out of that
Car and it shifted great when I sadly sold it at 147,000. There may be something to the added packages aftermarket contains. That said, perhaps the Transmax will go in the ody. I think Walmart sells a gallon for under $20. 3 or 4 of those should do it.
Speaking of trannies, can anyone speak to dipstick unreliability? The u150e shows “full/hot” after an hour of driving. Shut it off and the next day, when Ice cold, NOTIING shows on the dipstick. 0.6 qt and it’s at the lower side of “full/cold” there are others with the same trans that have the same issue. I run it on the “safe” side and measure when cold
Can’t even find tne “right” way to check the ody. Running and hot is what I do, 4
Quarts came out, 4 went in and the stick shows
Full
