Employer Exit Interview.
by JustinH
1 minute 7 seconds ago
Ceratec vs. Archoil 9100
by Phishin
4 minutes 43 seconds ago
Acclaim radiator ?
by urrlord
6 minutes 57 seconds ago
Understanding Idle Control Circuit
by artbuc
54 minutes 58 seconds ago
Annual drain on Mobil1 5w20 high mileage?
by ryan2022
Today at 07:36 AM
Best Oil For Late Model Toyota V6 Engines ?
by ChrisD46
Today at 06:58 AM
Ford 4.6L Durability?
by Auae85
Yesterday at 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
Yesterday at 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
Yesterday at 10:01 PM
Fireworks Stores
by Warstud
Yesterday at 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
Yesterday at 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
Yesterday at 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
Yesterday at 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
Yesterday at 08:49 PM
My FIL in hospice
by fdcg27
Yesterday at 08:41 PM
Spraying Polyurethane
by Texican
Yesterday at 08:37 PM
Dehumidifier icing
by Kestas
Diesel lube in Petrol Engine
by Ducked
Yesterday at 07:46 PM
New key programming cost
by 92saturnsl2
Yesterday at 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
Yesterday at 07:09 PM
ronw1309, Suth31, yamahaboy125, Turboholic, TrpNY
65284 Registered Users
85 registered (andyd, ARCOgraphite, A310, 2004tdigls, ArrestMeRedZ, 04sierrashortbed, 9 invisible), 1305 Guests and 43 Spiders online.
65284 Members
67 Forums
285689 Topics
Page 1 of 3 1 2 3 >
#4654626 - 02/03/18 09:30 AM Hi I am new on here and Im not sure where to post
Vailshred Offline
Loc: Colorado
Hi everyone, I found your forum last eve during my search for some advice on my situation. Im not sure where to post my questions so if you could suggest which thread I should post I would appreciate it. In a nutshell... I have a 2004 Audi 4.2 engine. Motor was disassembled, cylinder walls were coated in Nickel Silicon Carbide (aluminum block), installed new rings and reassembled engine. I ignorantly put in synthetic oil. Im looking for help, suggestions from engine builders or anyone with experience with setting piston rings. I have learned that I should not use synthetic on ring setting.
Thanks in advance
#4654633 - 02/03/18 09:34 AM Re: Hi I am new on here and Im not sure where to post [Re: Vailshred]
zrxkawboy Offline
Loc: SD
Welcome to the board. What type of rings were used? Some break in faster/easier than others. (I'm just speaking generally...I've never worked on one of those particular engines.)
Edited by zrxkawboy (02/03/18 09:39 AM)
"Think of all the Ford owners who will someday want an automobile." John Dodge
#4654634 - 02/03/18 09:35 AM Re: Hi I am new on here and Im not sure where to post [Re: Vailshred]
maverickfhs Offline
Loc: VA
welcome
Many really experienced and helpful folks here, you seem to be in right forum.
Above question is beyond my pay grade laugh
2006 Civic EX 200K/AT
2006 Acura TSX 177K/AT
#4654635 - 02/03/18 09:36 AM Re: Hi I am new on here and Im not sure where to post [Re: Vailshred]
kschachn Offline
Loc: Upper Midwest
And were did you take the block for Nikasil coating?
1994 BMW 530i, 227K
1996 Honda Accord, 262K
1999 Toyota Sienna, 394K
2000 Toyota ECHO, 267K
#4654637 - 02/03/18 09:37 AM Re: Hi I am new on here and Im not sure where to post [Re: Vailshred]
4WD Offline
Loc: Texas
What is the oil?
#4654672 - 02/03/18 10:11 AM Re: Hi I am new on here and Im not sure where to post [Re: Vailshred]
Vailshred Offline
Loc: Colorado
OK, Awesome! Thanks for chiming in guys. Here is more info on situation
Cylinder coating was done here http://www.millennium-tech.net/serviceInfo.php?id=12
Mobile 1 0-20. This oil was only in the engine for about 7 miles and 40 min of idling. I switched out to a conventional 20-30 as soon as I realized what I did.
The aluminum cylinder walls on this engine score very easily and its very common. I decided to get them plated to add strength to them. They plate the walls to a little over factory bore, then hone the walls to spec size. I used stock rings from Audi.
Im aware that I messed up pretty bad and am humbled by my lack of seeking advice or knowledge. I followed the Audi rebuild manual and did not question the oil. See the walls from factory are a polished aluminum wall for say. So the manual is saying synthetic is fine in ring replacement. I went to bed one night and realized that my walls are not the same as what the manual says anymore since mine have been coated..
Panic struck hard. Its a 10+hr book time to pull this engine, add another 4 or 5 to get pistons out and then re cross hatch, new rings and so on...
Im crossing my fingers that Since I switched oil so soon, removed all the syn I could and I will change oil again in a few miles, that I can get these rings to seat with out redoing everything.
Im not blowing any smoke but the car has no power at all. Like I said in initial post, the rings have less then 10 miles on them and motor has probably ran for a little over a hour by this time...
#4654674 - 02/03/18 10:12 AM Re: Hi I am new on here and Im not sure where to post [Re: Vailshred]
Trav Offline
Loc: MA, Mittelfranken.de
Many new cars come right from the factory with synthetic oil. What the problem? Does it burn excess oil?
I have never heard of plating or plasma coating these blocks only boring/honing to an almost mirror finish them finally roughen them slightly to expose silicon particles.
There should be no problem seating the rings on these regardless of the oil used simply because of the silicon particles which are harder than the piston ring, the ring will break in/wear properly regardless if the job was done right.
Edit: I see your link, I never knew they started with plating but the plating seems to have the same properties as the OE as far as silicon particles so the above would still apply.
Edited by Trav (02/03/18 10:17 AM)
#4654675 - 02/03/18 10:12 AM Re: Hi I am new on here and Im not sure where to post [Re: Vailshred]
Linctex Offline
Loc: Waco, TX
It REALLY depends on the quality of machine work.
Older engines needed a rougher cylinder wall surface to help "wear in" piston rings that were not 100% perfectly round.
A lot of newer machine practices with very close tolerances are not like that.
You need to ask the company that did the cylinder coating (like aircraft cylinders are coated) what to use. They might suggest synthetic oil from the beginning.
When I install Nikasil aircraft cylinders, I break them in on semi-synthetic.
#4654680 - 02/03/18 10:15 AM Re: Hi I am new on here and Im not sure where to post [Re: Vailshred]
Linctex Offline
Loc: Waco, TX
Originally Posted By: Vailshred
I'm not blowing any smoke but the car has no power at all.
This is bad.
Any number of things can cause this - what are the temperatures like?
#4654691 - 02/03/18 10:21 AM Re: Hi I am new on here and Im not sure where to post [Re: Linctex]
Vailshred Offline
Loc: Colorado
all temps seem normal. Compression test with block cold were between 135 and 145 on all 8. Tops of pistons were damp when I peeked through plug holes, 1 cylinder was dry. I do remember when I took it out for the 7 mile spin it started to gain a little more power towards the end of the drive. Maybe that 1 dry piston was beginning to seat?
#4654702 - 02/03/18 10:26 AM Re: Hi I am new on here and Im not sure where to post [Re: Linctex]
Vailshred Offline
Loc: Colorado
email from company
Well! This caught me off guard. Lol Our recommendation is to use a zinc rich non synthetic for break-in. The synthetic is soooo good it can deter break-in by lubricating the ring coating meant to aide in break-in. That being said, there are mixed ideas about synthetics effectiveness/ineffectiveness. Personally, I see no advantage in changing over to the non-syn oil at this stage. The additive packages in your syn oil are already attached to the metal parts. A quality non syn, zinc rich will not have enough/proper detergents to remove the synthetic additive package. I would “run what you brung” at this stage.
#4654706 - 02/03/18 10:28 AM Re: Hi I am new on here and Im not sure where to post [Re: Vailshred]
ARCOgraphite Online   content
Loc: N.H, U.S.A.
Mobil 1 0w20 is not synthetic oil.
Most NA synthetic oils are petroleum oil base.
This break in fokelore is more at Castor bean oil and other fatty ester oils NOT paraffin oils or poly alpha.
Look elsewhere for issue like bad intake gasketing/sealing ANYWHERE, Air metering connected and leak free, wrong injector wiring.
and ... numero uno: incorrect cam phasing.
Also - BTDT myself - missing ground wire (S) to block and head
time early - but I understand that.
Edited by ARCOgraphite (02/03/18 10:30 AM)
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
#4654711 - 02/03/18 10:32 AM Re: Hi I am new on here and Im not sure where to post [Re: Vailshred]
andyd Online   content
Loc: Marshfield , MA
Please post a follow up TIA.
the first SBC, the 265 ci, used Boraxo soap powder to seat the rings
Thick oil is better grin2
#4654714 - 02/03/18 10:34 AM Re: Hi I am new on here and Im not sure where to post [Re: Vailshred]
Loc: N.H, U.S.A.
New oils are zinc/phos rich.
ZDP gets used up like a case of beer in a frathouse over time.
That 1200ppm zinc rich oil will have 800 ppm ACTIVE ZDP after a month.
A 25w40 4 stroke motorboat oil is not a bad choice.
#4654733 - 02/03/18 10:46 AM Re: Hi I am new on here and Im not sure where to post [Re: Vailshred]
Cujet Offline
Loc: Jupiter, Florida
Not so. Nikasil or other variations on the nickel silicon carbide plating processes always seat the piston rings rapidly. You did nothing wrong and you won't have any issues.
Furthermore, your use of uber-thin oil will not keep the rings from wearing against a freshly honed Nikasil cylinder. Really, it's not a problem. Your lack of power issue lies elsewhere.
Edited by Cujet (02/03/18 10:50 AM)
Page 1 of 3 1 2 3 >
