Originally Posted By: 4ever4d
Originally Posted By: SilverSnake
Boomerang: I have posted this article before and it has been ridiculed by many on this forum as oil industry garbage and part of the big conspiracy to get us all to change our oil more frequently than necessary. I do not agree and find the article to be an excellent summary of the issues involved. I am posting the entire article since I cannot find the link on the net anymore. I hope you find it useful.
Amsoil Article: Chemical Reactions Occur in Motor Oil, Even When Not In Use
By Dan Peterson, Vice President, Technical Development, Amsoil, May 2012
http://www.1st-in-synthetics.com/Tech/Chemical_Reactions_Occur_In_Motor_Oil_Even_When_Not_In_Use.htm
Well you must understand that anything Amsoil related is quickly put into the misinformation or plain out lies file. Just bear it and move forward.
I didn't notice anything in that article that was demonstrably untrue (though the high proportion of engine failures attributed to glycol contamination was surprising and I'd have liked to see a source for it) but the overall effect is one of exaggeration.
Deterioration of oil does occur at ambient temperature in an unused engine but it is very very slow, and this is not acknowledged in the article.
Most of the problems discussed are actually attributable to sustained short-tripping rather than idleness.
In the abscence of short-tripping,or coolant leaks, the main potential damaging factor in an idle engine would be condensation. This could be minimised by venting after a run, or to be really thorough, fitting a dessicant breather, though hardly anyone does either and it doesn't seem to be generally necessary.
(I'm assuming there isn't some secret special fragility about Amsoil that only they know about)
