Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Need Expert TIG Welder, Toronto Area
by George7941. 03/18/19 01:44 AM
Cadillac CT5 Revealed
by E365. 03/18/19 01:36 AM
toplscuda, swrve, TomRx, Ozdave, Rod1701
67547 Registered Users
113 registered members (2009Edge, 97f150, 2015_PSD, ABerns, 12 invisible), 2,307 guests, and 60 spiders.
Topics286,014
Posts4,900,738
Members67,547
Most Online2,967
Mar 10th, 2019
13 ram 4.7 Amsoil 5w30 22,000 oci #4654393
02/03/18 12:03 AM
02/03/18 12:03 AM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
Seems like this truck is impossible to get a decent sample from.
It tows heavy and has a 4" lift kit and larger tires so I don't know if there is anything I can do, the little 4.7 might just be over worked.
Could this engine just be full of sludge?
Re: 13 ram 4.7 Amsoil 5w30 22,000 oci [Re: DustinC] #4654399
02/03/18 12:22 AM
02/03/18 12:22 AM
SD
zrxkawboy Offline
zrxkawboy  Offline
SD
Interesting. Our 3.7 Jeep (6 cyl version of your 4.7) shows high iron, too, but runs just fine.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: 13 ram 4.7 Amsoil 5w30 22,000 oci [Re: DustinC] #4654446
02/03/18 04:35 AM
02/03/18 04:35 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Why would the engine be full of sludge? Has Amsoil always been run?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 13 ram 4.7 Amsoil 5w30 22,000 oci [Re: DustinC] #4654453
02/03/18 05:06 AM
02/03/18 05:06 AM
California
jj51702 Offline
jj51702  Offline
California
Full of sludge? Just cuz there's some extra wear? Wat?
Re: 13 ram 4.7 Amsoil 5w30 22,000 oci [Re: DustinC] #4654481
02/03/18 07:01 AM
02/03/18 07:01 AM
Georgia
MParr Online content
MParr  Online Content
Georgia
Sludge? Not likely.
2013 KIA Optima EX 2.4L. Now: Unknown &OE filter
2017 Ford Escape SE 2.0T Now: NAPA Synthetic 5W30 & NAPA Gold 1348
Re: 13 ram 4.7 Amsoil 5w30 22,000 oci [Re: DustinC] #4654482
02/03/18 07:04 AM
02/03/18 07:04 AM
Indiana
msmoke00 Offline
msmoke00  Offline
Indiana
What’s the backstory with the 55 silicon? That level if coming from an air filtration issue could definitely cause higher wear numbers.
Re: 13 ram 4.7 Amsoil 5w30 22,000 oci [Re: DustinC] #4654486
02/03/18 07:23 AM
02/03/18 07:23 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Just for S&G try an A3/B4 oil next time.
Re: 13 ram 4.7 Amsoil 5w30 22,000 oci [Re: DustinC] #4654520
02/03/18 08:26 AM
02/03/18 08:26 AM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
22,000 oci with loads on the engine....there’s your problem.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: 13 ram 4.7 Amsoil 5w30 22,000 oci [Re: DustinC] #4654579
02/03/18 09:42 AM
02/03/18 09:42 AM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
Back story on the engine is it always got changed at quick lubes with Chinese filters and long oci, I was hoping some of the wear was from the oil cleaning the old sludge even after a 3200km oci the oil had high oxidation numbers
The 22,000 oci interval should be doable because it's still under the oils severe service recommend oci
Re: 13 ram 4.7 Amsoil 5w30 22,000 oci [Re: msmoke00] #4654580
02/03/18 09:44 AM
02/03/18 09:44 AM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
Cracked evap line it's been repaired and the past 3 oci the trucks been in 100% shape
Re: 13 ram 4.7 Amsoil 5w30 22,000 oci [Re: DustinC] #4654618
02/03/18 10:21 AM
02/03/18 10:21 AM
Michigan
ZZman Offline
ZZman  Offline
Michigan
It would be important to see the results of other 4.7 motors for comparison.
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram TG
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: 13 ram 4.7 Amsoil 5w30 22,000 oci [Re: ZZman] #4654640
02/03/18 10:38 AM
02/03/18 10:38 AM
SD
zrxkawboy Offline
zrxkawboy  Offline
SD
Here's one from my 3.7, which is the V6 version of the 4.7 V8.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4201536/1
Re: 13 ram 4.7 Amsoil 5w30 22,000 oci [Re: ARB1977] #4656307
02/04/18 08:59 PM
02/04/18 08:59 PM
Florida
Artem Offline
Artem  Offline
Florida
Agreed. Towing is considered SEVERE duty and should not be a candidate for extended OCIs, regardless of what the oil manufacturer says (unless they give you a written warranty)
I'm sure this engine will be just fine though. Will probably smoke and burn oil worse then a similar one but with 10k OCIs for example.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: 13 ram 4.7 Amsoil 5w30 22,000 oci [Re: DustinC] #4656568
02/05/18 06:35 AM
02/05/18 06:35 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
Converting to miles (kms in the report as shown) ...
- the most recent was only about 5.3k miles; with 93ppm Fe. We rate of 18ppm/1k miles.
- next down was 6k miles; 88ppm Fe. Wear rate of 15ppm/1k miles.
- next before that was 2k miles; 38ppm Fe. Wear rate of 19ppm/1k miles.
- the "22,000" OCI was actually 4 UOAs ago, and is akin to 14k miles with 200ppm Fe. Wear rate of 14ppm/1k miles.
I'm not a fan of having Fe above 100ppm in any OCI, but ironically it gave you the lowest wear rate. The wear rates are fairly consistent (pretty darn high).
This looks like a combination of Si and hard use. You had an air intake issue, and it may be continuing, or residual Si is still doing it's work.
The long OCI could possibly have been to blame, but the three most recent UOAs are short, and yet wear is still high.
It looks like you're averaging about 4k miles a month; that's a lot. Also, seems to be a UOA/OCI missing in there? The vehicle miles versus the UOA miles don't match up for the first one.
And here I thought PAOs were the magical fluid and would stop all wear across the planet ... that's what most BITOGers want me to believe.
You might want to consider, if you're willing to experiment, trying a dino 15w-40 or 10w-30 HDEO and see what happens. I doubt the wear can get much higher, and it would save you some money.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 13 ram 4.7 Amsoil 5w30 22,000 oci [Re: dnewton3] #4657743
02/06/18 10:01 AM
02/06/18 10:01 AM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
The missing UOA is because I sampled the oil then changed after I received the terrible results, next oil change will be 5w30 HDEO (amsoil Max duty diesel) and then in april I will probably try some bulk 5w40 HDEO its just -40 here lately so I would like to stick with a thinner oil until it warms up.
