Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
68 registered members (AZjeff, andyd, AdditiveOCD, atikovi, A_A_G, AdmdeVilleneuve, 8 invisible), 1,466 guests, and 39 spiders.
Topics295,007
Posts4,925,827
Members66,664
Most Online2,553
Oct 27th, 2018
blown hg; options #4653931
02/02/18 01:07 PM
02/02/18 01:07 PM
Chicago, IL
tomcat27 Offline OP
tomcat27  Offline OP
Chicago, IL
blown head gasket on 2001 Camry (only 112k miles) due to overheating from collision and radiator damage. (apparently the temperature gauge is just a decoration and does not need to be watched)
do I:
1) just sand the head on a flat surface
2) mill at machine shop
3) mill @ machine shop, replace seals, check valves
4) re-man'd head
long-term keeper.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: blown hg; options [Re: tomcat27] #4653933
02/02/18 01:09 PM
02/02/18 01:09 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Pop a used low-mile engine in it.
"Zed's dead baby, Zed's dead."
Re: blown hg; options [Re: tomcat27] #4653943
02/02/18 01:19 PM
02/02/18 01:19 PM
USA
mk378 Offline
mk378  Offline
USA
If it was driven until it would go no more, the whole engine is toast.
Re: blown hg; options [Re: tomcat27] #4653947
02/02/18 01:24 PM
02/02/18 01:24 PM
Chicago, IL
tomcat27 Offline OP
tomcat27  Offline OP
Chicago, IL
it was driven 5 miles. seems to run fine; except for the hg.
I have no idea how hot it got; I got a phone call when steam was noticed from the hood
I put a radiator and condenser in it and straightened the radiator support
Re: blown hg; options [Re: tomcat27] #4653963
02/02/18 01:43 PM
02/02/18 01:43 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
At work we have repaired many aluminum head engines that over heated to the point of the valve seats falling out . You need to have a machine shop check and straighten the head if it needs to be straightened. Also measure the block with a straight edge to make sure it is flat.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: blown hg; options [Re: tomcat27] #4653966
02/02/18 01:44 PM
02/02/18 01:44 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
it got hot enough to crush the head gasket! Its likely that the low tension piston rings are junk now too.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: blown hg; options [Re: Chris142] #4653967
02/02/18 01:48 PM
02/02/18 01:48 PM
Chicago, IL
tomcat27 Offline OP
tomcat27  Offline OP
Chicago, IL
I would rather do things correctly - once. hmm. interesting on the rings. so, dis-assemble the engine or put in a reman engine.
I want the car to last through 3 kids. I know... silly me. the first one is doing his best to kill it.
Re: blown hg; options [Re: tomcat27] #4653970
02/02/18 01:53 PM
02/02/18 01:53 PM
Chicago, IL
tomcat27 Offline OP
tomcat27  Offline OP
Chicago, IL
I will run a compression test later; and send the head to the shop; or consider a rebuild. probably do that myself. unless someone can recommend a Jasper..... (sorry; twisted humor on my part)
Re: blown hg; options [Re: tomcat27] #4653974
02/02/18 01:56 PM
02/02/18 01:56 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
If you're going to do the work, give the head to a machine shop. Let them redo everything as needed. Then just clean everything up and put it all back together.
If you're new at this do a lot of research. YouTube is your friend and books too. Be clean and organized. Take lots of pictures as you go and keep all the parts separate somewhere in groups.
Find a manual that gives you step by step instructions. Don't hurry. Be clean. And did I suggest, take lots of pictures. If someone helps be careful that they don't do things you don't see or understand. Take pictures. Make your help keep bits and pieces sorted and in some kind of understandable order.
Use new engine oil and filter. Change them a couple of times in the first thousand miles.
Clean out the cooling system. Replace the water pump and thermostat. Use new coolant and distilled water. Find out what coolant to use. It makes a difference.
Have fun.
Re: blown hg; options [Re: tomcat27] #4653980
02/02/18 02:09 PM
02/02/18 02:09 PM
California
nthach Offline
nthach  Offline
California
If you want to do the job right, pull the head and send that into a machine shop for any correction that needs to be done, might be a good time for a valve job as well. Check the block with a straight edge and a feeler gauge for warping. I doubt Toyota switched over to low-tension rings on a 5S-FE. Use OEM or Fel-Pro gaskets and flush out the cooling system. I'd use Toyota Red or Zerex Asian formula from now on.
You can also get a used "30K" motor from Japan, but you're going to roll the dice. The good news with a used engine is that it's in a state for you to teardown and replace what needs to be replaced.
Re: blown hg; options [Re: tomcat27] #4653990
02/02/18 02:22 PM
02/02/18 02:22 PM
Connecticut 06033
oilmutt Offline
oilmutt  Offline
Connecticut 06033
Year, make, model, engine,millage???????????.
'05 Chevy Malibu 6cyl,119k, Syn. Oil (owned)
'16 Toyota Camry,4cyl 25k Syn oil (leased)
'92 Ford Tempo ,4cly 26k Conv oil (managed)
Re: blown hg; options [Re: tomcat27] #4654001
02/02/18 02:49 PM
02/02/18 02:49 PM
Chicago, IL
tomcat27 Offline OP
tomcat27  Offline OP
Chicago, IL
2001 Toyota Camry. 112,000 miles. (in the original post) 2.2l I have the genuine Toyota Factory service manual. I've used Zerex red coolant. about 1k ago I replaced the timing belt and water pump. I'm no stranger to "bagging and tagging" parts; and taking photos. I used to have a perfect memory. not so much anymore.
Re: blown hg; options [Re: tomcat27] #4654002
02/02/18 02:58 PM
02/02/18 02:58 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
You say head, singular so I assume 2.2? Doesn't take much movement to break a 2.2 Camry head gasket seal- have dealt with a few, including my own. I seriously doubt the rest of the engine is toast though. The rings are 1.2mm thick (as opposed to the old school 1.5mm rings) so it's possible? they're compromised, of course you'd have to test compression to know for sure wink I'd gamble on there being no more damage than just the HG. 5 miles is nothing, so doubts are there about loose valve guides also, but that all needs to be verified. 112K miles isn't so much at all.
For reference, some engines are designed to travel quite a few more miles than that with no coolant- without sustaining excessive damage. There are even ECU programs that shut some cylinders down for "air cooling" effects. But as I said, it doesn't take much to pop a Toyota S-engine head gasket- by far the weakest point of an otherwise tough engine that should still be serviceable.
Best of luck!
Scambling for solutions is a hopelessly futile endeavour and potentially dangerous, without first coming to a solid, personal understanding of the problem. Beware riding the ideological hobby horse.
Re: blown hg; options [Re: tomcat27] #4654007
02/02/18 03:03 PM
02/02/18 03:03 PM
Lakeside, CA
Blkstanger Offline
Blkstanger  Offline
Lakeside, CA
Look up JDM engines. IMHO I think that would be a good option for you
99 Jeep WJ 4.7 192,000 Maxlife 10w30, Fram Ultra.
Re: blown hg; options [Re: tomcat27] #4654010
02/02/18 03:06 PM
02/02/18 03:06 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Do you know where in the Midwest you're located?
