WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knock Out Punch
by user52165. 09/21/18 03:41 PM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
29 registered members (CleverUserName, 2015Corolla, chance, Anduril, 4 invisible), 777 guests, and 36 spiders.
Topics290,810
Posts4,850,742
Members66,036
Most Online3,590
Jan 24th, 2017
Milkhouse heaters settings #4653924
02/02/18 01:48 PM
02/02/18 01:48 PM
Canada
Broo Offline OP
Broo  Offline OP
Canada
One of these questions that sometimes pop up in my mind. While the answer isn't really important, it bugs me as to why it is this way.
Most utility heaters have two settings : 750W and 1500W. That makes sense. Using the lower settings allows to use some other equipment on the same circuit without tripping the breaker while the highest setting heats up more but uses almost all of a standard 15A breaker capacity.
There is however a utility heater model made by various manufacturers called a "Milkhouse Heater". It also has two setting : 1300W and 1500W. That's not much of a difference in both power draw and heat output.
Anybody knows why this model has two settings so close to one another instead of a single set power ?
Re: Milkhouse heaters settings [Re: Broo] #4653950
02/02/18 02:27 PM
02/02/18 02:27 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
I always figured that the 1300w setting was just to give you the opportunity to give you a little more leeway on a 15a circuit
2019 Cherokee, 2015 Rogue, 2014 Sentra, 2001 Camry, 2005 Starcraft, 1998 Dodge B1500
1996 Sebring Jx, 1984 F150, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Milkhouse heaters settings [Re: Broo] #4653955
02/02/18 02:30 PM
02/02/18 02:30 PM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
Maybe so you can plug a lamp in the same outlet,
and keep a eye on that heater and outlet at the same time... grin hide
actually have 2 in my garage that I use , nice little heaters...
and run them on high...
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive184k miles
Last Change;
Penn. Plat. HM. 5w30
Fram xg8a, Fram CA8141
I like my oil (slippery).
Re: Milkhouse heaters settings [Re: Broo] #4653959
02/02/18 02:36 PM
02/02/18 02:36 PM
indiana
dakota99 Offline
dakota99  Offline
indiana
I love those utility heaters but yeah I never have understood why the heat settings are so close together. I wish someone would make a 16 amp 1920 watt utility heater. There's a lot of times where a 1500 watt heater is just not enough for me so I end up running two together. Heck put a 20 amp plug on the end and market it to contractors and so forth. That would deter the common homeowner from trying to plug it into a standard 15a house outlet. Most 1500 watt heaters are actually only 1320~ on a meter.
Re: Milkhouse heaters settings [Re: Broo] #4654018
02/02/18 04:18 PM
02/02/18 04:18 PM
North TEXAS
oldoak2000 Offline
oldoak2000  Offline
North TEXAS
Because its CHEAPER to make it that way; a true 750w setting would require a true separate/additional stringing of ni-chrome wire (more cost) for higher ohms (lower current/watts).
The 1300/1500 model has just a SINGLE loop thats tapped a little close to one end to run the shortened loop hotter.
I had to buy an oil-filled heater this year to get a (low) 600w setting (reasonably priced) - they're safer too!
Re: Milkhouse heaters settings [Re: Broo] #4654054
02/02/18 05:20 PM
02/02/18 05:20 PM
Elizabethtown, Pa
Al Offline
Al  Offline
Elizabethtown, Pa
Most heaters are 1300 and 1500 watts. I think oldoak hit it
Re: Milkhouse heaters settings [Re: dakota99] #4654240
02/02/18 08:40 PM
02/02/18 08:40 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Two 750 watt heaters is safer than one 1500 watt, anyway.
A lot of small space heaters have three settings now.
Re: Milkhouse heaters settings [Re: oldoak2000] #4654353
02/02/18 10:54 PM
02/02/18 10:54 PM
Canada
Broo Offline OP
Broo  Offline OP
Canada
If that's the case, then I wonder why they didn't tap it right in the middle to make a 750/1500.
Re: Milkhouse heaters settings [Re: Broo] #4654423
02/03/18 01:51 AM
02/03/18 01:51 AM
Connecticut 06033
oilmutt Offline
oilmutt  Offline
Connecticut 06033
Please be careful we lost over 20 horses locally because of a short in a barn utility heater.
'05 Chevy Malibu 6cyl,119k, Syn. Oil (owned)
'16 Toyota Camry,4cyl 25k Syn oil (leased)
'92 Ford Tempo ,4cly 26k Conv oil (managed)
Re: Milkhouse heaters settings [Re: Broo] #4654537
02/03/18 08:38 AM
02/03/18 08:38 AM
California
Errtt Offline
Errtt  Offline
California
Earlier this winter I thought of buying one and it too had 1000 & 1500 watt heat settings.
I was hoping for something like a low, medium and high setting (something like 500, 1000, 1500 watt settings).
Then I started thinking rather than a heater to warm up a room, maybe something less to knock a little chill out of the air, more like a maintainer like an oil filled heater. The ones I looked at also had 2 heat settings, but then I found one that went down to 750 watts, but it was 750 watts on or off only. Then I thought of maybe getting two of those, but now the weather has warmed up and the itch has gone away.
We have a couple small ceramic fan force personal low watt heaters (couple hundred watts each) that put out a little warm air. Very small footprint and would warm the feet or hands if held right in front of them but won't warm up a cold room in short order. They are so low in heat the housing is plastic.
I think (for next winter) for now maybe 1 of the milkhouse type and 1 of the oil filled. I'd like something I can run off the generator if needed and not tax it so hard robbing the generator much for other needs, and a low, medium & high settings to give something to work with.
With winter soon over maybe watch for decent sales as heater demands lighten up.
