Roller Bearing Setup For Dillon Shellplate
by billt460
06/23/18 05:59 AM
Omnia - the band
by Shannow
06/23/18 02:58 AM
Guest's devices cannot connect to my WiFi
by boulderdentist
06/23/18 12:54 AM
Battery stuck in flashlight.
by Chris142
06/22/18 11:53 PM
Must read for everyone watching their diet
by JLTD
06/22/18 11:28 PM
2014 Mazda5 Valvoline Synpower 0W-20 7500 miles
by PWMDMD
06/22/18 10:54 PM
VOA Ravenol ECS 0W-20
by PWMDMD
06/22/18 10:47 PM
2020 mid-engine Corvette spy vid?!
by AZjeff
06/22/18 10:45 PM
'05 base impala. NO turn signals.FAST blinking.
by Lee4212
06/22/18 10:34 PM
Motul 15w-50, 5 Liter 4 Pack $19.42
by hatt
06/22/18 10:10 PM
High Lead Redline 5W40 thoughts? Ty
by Pajero
06/22/18 09:40 PM
Source of the Mighty Columbia River
by Snagglefoot
06/22/18 09:32 PM
Another thick/thin article to discuss
by JLTD
06/22/18 09:23 PM
Ethylene Glycol Long Life Coolant for KUBOTA
by pburchett
06/22/18 09:11 PM
Mobil 1 5W-30, 6,200 mi, 2017 2.3 EB Explorer
by Whimsey
06/22/18 08:48 PM
Chevron 10w-40, 97 Nissan Maxima, 3000 miles
by OilGeek91
06/22/18 08:36 PM
Old green antifreeze in garage storage is gelling
by JLawrence08648
06/22/18 08:32 PM
VWs at Pick n Pull
by Eric Smith
06/22/18 08:17 PM
Single Data Point: CK-4 destroys the flat tappet
by Gokhan
06/22/18 08:12 PM
Breaking in new short block
by Bub
06/22/18 07:00 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
53 registered (4WD, Alex_V, ArrestMeRedZ, 2002 Maxima SE, alarmguy, 10 invisible), 961 Guests and 71 Spiders online.
65299 Members
67 Forums
285817 Topics
#4653835 - 02/02/18 10:28 AM Amsoil OE 0W20 & Magnatec 0W20 Q?'s
BlueOvalFitter Offline
Loc: Cajun Country, La.
I usually just FRANKENBREW my oil without asking Q?'s on the forum about it. This time I am just curious to get your opinions.
My truck is coming up on an OCI. I have yet to decide on which weight of Magnatec I want to use this time. I have used 5W30 the last 2 OCI's. My cousin gave me a qt. of Amsoil OE 0W20 oil and I want to use it as my 6th qt. in my engine, along with the 5 qts. of Magnatec. Wal-Mart sells the 0W20 for an additional $2.00 over their 5W20 & 5W30 5 qt. prices ($19.88 VS $17.88). Is the 0W20 worth the additional $2.00? The 0W20 must have an additive package that is better than the 5W20 & 5W30. Does it? Thank You.
shrug
#4653853 - 02/02/18 11:08 AM Re: Amsoil OE 0W20 & Magnatec 0W20 Q?'s [Re: BlueOvalFitter]
JustN89 Offline
Loc: DFW
Based on your climate, I would save two bucks and go with a 5W.
#4653860 - 02/02/18 11:14 AM Re: Amsoil OE 0W20 & Magnatec 0W20 Q?'s [Re: BlueOvalFitter]
Old Mustang Guy Offline
Loc: Rockwall, Texas
I agree on no benefit from 0w20. I would just dump the amsoil in with 5 quarts of 5w.
#4653873 - 02/02/18 11:30 AM Re: Amsoil OE 0W20 & Magnatec 0W20 Q?'s [Re: Old Mustang Guy]
BrocLuno Offline
Loc: Kalifornia Kollective
+1 Just consider it top-up oil and add it as the last qt laugh
#4653895 - 02/02/18 12:04 PM Re: Amsoil OE 0W20 & Magnatec 0W20 Q?'s [Re: BlueOvalFitter]
Thank You gentlemen, for your replies. That's exactly my thinking as well; use the Amsoil as the 6th qt.
I read the numbers on the 5W20 VS 5W30. I liked the 5W20 numbers better, so that's going into my engine this time, probably from now on. Until I want to use a different name brand. grin
thumbsup USA
#4653906 - 02/02/18 12:31 PM Re: Amsoil OE 0W20 & Magnatec 0W20 Q?'s [Re: BlueOvalFitter]
CT8 Offline
Loc: Idaho
What is motor oil ? It is a blend of different base stocks and additives to meet a requirement. Look at the uoas and voas they pretty much have the same additives and base stock blends.APPLICATIONS
Use AMSOIL OE Synthetic Motor Oil in applications that require any of the following specifications:
COPY and PASTE
5W-30 (OEF)
API SN (Resource Conserving), SM...; GM dexos1 Gen 2 (supersedes LL-A-025, 6094M and 4718M); ACEA A1/B1,A5/B5; Chrysler MS-6395; Ford WSS-M2C946-A, WSS-M2C929-A; ILSAC GF-5, GF-4...
COMPATIBILITY
AMSOIL OE Synthetic Motor Oil is compatible with other synthetic and conventional motor oils. Adding other oils, however, will shorten the life expectancy of AMSOIL motor oils and reduce their performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed.
Aftermarket oil additives are not recommended for use with AMSOIL OE Synthetic Motor oil
#4653938 - 02/02/18 01:15 PM Re: Amsoil OE 0W20 & Magnatec 0W20 Q?'s [Re: BlueOvalFitter]
JLTD Offline
Loc: US
Cajunland, where it rarely if ever gets below freezing, 0w anything won't make a bit of difference. Agree with above, save your $$, get the 5 quarts of 5w20 and add in the quart of Amsoil.
...and curious what changed this time?
Done discussing thick vs thin - too divisive. Will let UOAs do the talking.
His: 2015 4Runner SR5 1GR-FE 39k, Amsoil OE 5w20/Wix
Testing vs 5w30
Hers: 2008 Jeep Liberty 135k, Amsoil SS 5w30/Amsoil
#4654021 - 02/02/18 03:34 PM Re: Amsoil OE 0W20 & Magnatec 0W20 Q?'s [Re: BlueOvalFitter]
PandaBear Offline
Loc: Silicon Valley
Most likely same additive package but the base oil blend is more expensive for 0w20, or 0w20 has higher demand, so they charge more.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#4654235 - 02/02/18 07:28 PM Re: Amsoil OE 0W20 & Magnatec 0W20 Q?'s [Re: PandaBear]
Linctex Offline
Loc: Waco, TX
Originally Posted By: PandaBear
Most likely .... the base oil blend is more expensive for 0w20,
This ^^^
#4654817 - 02/03/18 12:03 PM Re: Amsoil OE 0W20 & Magnatec 0W20 Q?'s [Re: JLTD]
Well, being that it's Amsoil, and I have never used an 0W20 before, so......shrug
