Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Need Expert TIG Welder, Toronto Area
by George7941. 03/18/19 01:44 AM
Cadillac CT5 Revealed
by E365. 03/18/19 01:36 AM
Scored free 0w-20 semi synthetic
by pdxglocker9mm. 03/18/19 01:13 AM
TomRx, Ozdave, Rod1701, Arbitrader, Djdecember
67545 Registered Users
116 registered members (ABerns, 65convertible, addyguy, 928, AdditiveOCD, 10 invisible), 2,276 guests, and 59 spiders.
Topics286,013
Posts4,900,707
Members67,545
Most Online2,967
Mar 10th, 2019
Maxlife - still the best oil for R/M seal leaks? #4653297
02/01/18 04:48 PM
02/01/18 04:48 PM
Idaho
RonRonnster Offline OP
Idaho
A friend of mine picked up a '94 GMC Suburban with the TBI 350. Weeps a little bit from the rear main seal. I suggested he try Valvoline Maxlife to see if that helps slow it down at all - also couldn't hurt with 184k miles on the engine. After reading some threads here, and on other sites, many people are commenting that Maxlife doesn't work as well as it used to. Of course, no real data to back that up, but it does appear that Valvoline changed it's formula to meet Dexos Gen 2 specs. Is there a "better" high mileage oil out there than Maxlife these days for rear main leaks? I have run FS Maxlife in my '98 Chevy, but it hasn't been a leaker to speak of.
Other high mileage options that are easily attainable at WalMart:
Mobil 1 High Mileage
Pennzoil High Mileage
Castrol GTX High Mileage
SuperTech High Mileage
Any experience or anecdotal evidence that any of these work better the another for seal leaks?
- 2007 GMC Yukon XL Denali - 6.2L / 81k mi.
- 1998 Chev K1500 4x4 - 5.7L / 155k mi.
Re: Maxlife - still the best oil for R/M seal leaks? [Re: RonRonnster] #4653308
02/01/18 04:57 PM
02/01/18 04:57 PM
KS
FordBroncoVWJeta Offline
KS
I think the reason maxlife doesn't work like its use to because its now a semi synthetic. I started putting PHM in my sunfire, stopped leaking and cut down on burning.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2001 Pontiac Sunfire 2.2
Re: Maxlife - still the best oil for R/M seal leaks? [Re: RonRonnster] #4653310
02/01/18 04:58 PM
02/01/18 04:58 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
I've never had a rear main seal leak, so I cannot comment on any oils totally effectiveness at stopping that sort of leak.
Many here are very happy with maxlife. I'd say he try that first and see what happens.
I had some leaks on my 97 civic and 98 Sienna. I used liqui moly motor oil saver and had good results.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Maxlife - still the best oil for R/M seal leaks? [Re: RonRonnster] #4653337
02/01/18 05:30 PM
02/01/18 05:30 PM
MURICA
maverickfhs Offline
maverickfhs  Offline
MURICA
Subscribed...
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Maxlife - still the best oil for R/M seal leaks? [Re: RonRonnster] #4653341
02/01/18 05:38 PM
02/01/18 05:38 PM
Martha's Vineyard MA
SHOPete Offline
SHOPete  Offline
I was a skeptic on HM oils until I put PZHM in a leaky Ford Windstar V6. A miracle drug. Completely dried up a soaked motor. If I needed it, I'd use it again for sure. Can't comment on MaxLife.
17 Hyundai GLS QSUD 5w-30 OEM filter
09 Corvette LS3 M1 5w-30 M1-113A
01 Toyota Tundra 135K PZ Euro 0W-40 OEM filter
Re: Maxlife - still the best oil for R/M seal leaks? [Re: SHOPete] #4653358
02/01/18 05:55 PM
02/01/18 05:55 PM
wv
krismoriah72 Offline
wv
I do not endorse these products..just have seen the bottles.
Re: Maxlife - still the best oil for R/M seal leaks? [Re: RonRonnster] #4653362
02/01/18 06:04 PM
02/01/18 06:04 PM
NC
lawrencerd Offline
lawrencerd  Offline
NC
I can honestly say Maxlife dried up a leak very well in my Jeep, since using QS HM it is a leaker again. Not a huge amount but that is one data point. Good luck with your friend's leak.
Re: Maxlife - still the best oil for R/M seal leaks? [Re: RonRonnster] #4653369
02/01/18 06:14 PM
02/01/18 06:14 PM
MN
oil_film_movies Offline
MN
Valvoline MaxLife does not swell the seals, an important distinction. We know it doesn't swell the seals much because it passes seal-swell tests in SN, and dexos1 for the full syn Maxlife. Maxlife conditions the seals. Conditioning may stop a small leak, as the seals would get more flexible, yet for something old already leaking, I'd definitely put in something like krismoriah72's Bar's or Blue Devil. See above post.
Re: Maxlife - still the best oil for R/M seal leaks? [Re: RonRonnster] #4653370
02/01/18 06:17 PM
02/01/18 06:17 PM
Where the wind comes sweepin'
Reddy45 Online shocked
Reddy45  Online Shocked
Every 'fix in a bottle' I've tried worked initially and then stopped working some time later.
Even AutoRX was able to temporarily stop a leaking RMS, but the leak returned on the next oil change.
ATP 205 slowed the leak, but didn't stop it.
High mileage oil temporarily stoped the leak, but it returned later.
I'd leave it or pony up the money or sweat equity to replace the entire seal.
Re: Maxlife - still the best oil for R/M seal leaks? [Re: krismoriah72] #4653374
02/01/18 06:32 PM
02/01/18 06:32 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Originally Posted By: krismoriah72
I do endorse these products..just have seen the bottles.
Fix d this for you smile
Re: Maxlife - still the best oil for R/M seal leaks? [Re: RonRonnster] #4653393
02/01/18 07:01 PM
02/01/18 07:01 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Maxlife worked to stop the RMS leak my Jeep had. Smitty's Super-S Completely stopped the leaks and oil burning the wife's Tahoe had.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Maxlife - still the best oil for R/M seal leaks? [Re: RonRonnster] #4653398
02/01/18 07:06 PM
02/01/18 07:06 PM
Texas
4WD Offline
4WD  Offline
Texas
Dripping or wicking (engine famous for later) Mobil 1 10w30 High Mileage is a tad thicker with having to go 40s
Re: Maxlife - still the best oil for R/M seal leaks? [Re: SHOPete] #4653414
02/01/18 07:29 PM
02/01/18 07:29 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: SHOPete
I was a skeptic on HM oils until I put PZ HM in a leaky Ford Windstar V6. A miracle drug. Completely dried up a soaked motor. If I needed it, I'd use it again for sure. Can't comment on MaxLife.
I concur, I think the Pennz and Qkr St oils are similar packages,
and the high mileage products work very well on leaky rear crankshaft seals.
Re: Maxlife - still the best oil for R/M seal leaks? [Re: RonRonnster] #4653424
02/01/18 07:52 PM
02/01/18 07:52 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
Maxlife red bottle would be my first choice although M1 HM seems to work as well. The main rap I have on Maxlife is that the newer formulations no longer have any moly content.
The Maxlife is cheaper OTS but the M1 will be cheaper AMIR if you wait a couple of months for one of their MIRs.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: Maxlife - still the best oil for R/M seal leaks? [Re: RonRonnster] #4653460
02/01/18 08:47 PM
02/01/18 08:47 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Maxlife Red bottle and probably the 5w30 variant. Don't bother with M1 for this problem.
