Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
43 registered members (bbhero, Ag76, ArrestMeRedZ, Agnosto, Brad_C, Bailes1992, 6 invisible), 947 guests, and 57 spiders.
Topics286,170
Posts4,903,516
Members67,572
Most Online2,967
Mar 10th, 2019
Motorcraft 5W-30 Blend 17 2.3EB Explorer #4653241
02/01/18 03:21 PM
02/01/18 03:21 PM
The Garden State
Whimsey Offline OP
Whimsey  Offline OP
The Garden State
This is my 2nd UOA for this vehicle. The ff oc was at 2,000 mi. The next oil change was dealer done at 2,000 mi. for 3,200 miles. Then the Mobil 1 oil went in at 5,200 mi, the UOA went til 12,200 mi, 7,000 mi on the oil. This UOA of Motorcraft went till 16,475 mi, 4,275 miles on the oil. This was a more realistic UOA of actual "everyday" driving, including the use of the remote starts to warm up the vehicle and melt the windshield ice. I wanted to get to a 5,000 mi OC but if I wanted to change the oil myself I had to do it when I did, before winter really happened here a couple of days afterwards. The thing that stands out is the drop in viscosity from a 30 weight to a 20 weight. Yet it doesn't appear that it was from fuel dilution, maybe some, but the flashpoint was still good. Perhaps the DI and Turbo do shear the oil even without fuel dilution. The TBN was still a respectable 3.6 even with the sheared oil. The iOLM for this change at 4,275 miles was 58%. The next UOA is Mobil 1 5W-30 which was installed after this oil and I'll do an UOA when I drain it in the spring. From then on I'll use Mobil 1 as I have quite a few changes worth of it at this point in time.
Whimsey
Re: Motorcraft 5W-30 Blend 17 2.3EB Explorer [Re: Whimsey] #4653249
02/01/18 03:47 PM
02/01/18 03:47 PM
Rockwall, Texas
Old Mustang Guy Offline
Rockwall, Texas
I like Mobil 1 for this turbo car. I use it in my wife's 09 Acadia at 5k OCI due to D.I. And known timing chain issues. If this car were mine I would do the same due to shearing and/or fuel.
Re: Motorcraft 5W-30 Blend 17 2.3EB Explorer [Re: Whimsey] #4653251
02/01/18 03:50 PM
02/01/18 03:50 PM
St. Charles County, Missouri
csandste Offline
csandste  Offline
This oil was in a used Buick Encore that I bought from a Ford dealer. Since it wasn't Dexos and the dealer didn't reset the OLM, I dropped it at about 4000 miles. Still looked clean, the Maxlife which I changed to looks pretty dirty pretty fast. Don't know whether clean looking oil is a good thing or a bad thing.
I used Kendall 5w20 on a Kia Rio and had Firestone not dropped it for QS I might have kept at it when the car got out of warranty. Conoco-Phillips has a lot of group III production capacity and their oils are all great values IMO.
I live in a condo where changing your oil is forbidden so finding a good source of cheap oil changes is important. A local tire store with cheap Valvoline products is the decider for me.
I wouldn't worry about shearing down to 5w20. Things look good, especially for the combo of di and turbo. If you get through your stash of M1, this oil looks like a pretty good, cheaper, fall back.
2017 Kia Soul Plus-- VWB 5-30, 54,000 miles.
Re: Motorcraft 5W-30 Blend 17 2.3EB Explorer [Re: Whimsey] #4653294
02/01/18 04:45 PM
02/01/18 04:45 PM
The Garden State
Whimsey Offline OP
Whimsey  Offline OP
The Garden State
Oops, forgot to mention, the oil filter was the same as the last one, a Motorcraft FL910S.
Whimsey
Re: Motorcraft 5W-30 Blend 17 2.3EB Explorer [Re: Whimsey] #4653357
02/01/18 05:55 PM
02/01/18 05:55 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Think I'd be picking up some Magnatec 5W30 (cheap at WM for $17.88/5 qt. jug), that Motorcraft doesn't look like it did very well for only 4300 miles.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Motorcraft 5W-30 Blend 17 2.3EB Explorer [Re: Whimsey] #4653606
02/02/18 03:05 AM
02/02/18 03:05 AM
Washington, USA
Onug Offline
Onug  Offline
Washington, USA
My first guess was the dealership put in the wrong oil, but if I read your post correctly you changed the oil yourself. That oil has really sheared down, but wear metals are fine. M1 shears in my EB, but maybe yours will do better. Will be interesting to see how it holds up.
2016 F-150 3.5L Ecoboost
Current Oil: Castrol Magnatec 5W-30 and Fram Ultra filter
Re: Motorcraft 5W-30 Blend 17 2.3EB Explorer [Re: Whimsey] #4653625
02/02/18 06:17 AM
02/02/18 06:17 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
Good wear overall.
Longer OCIs will actually drop the wear rates.
In reality, you could have easily waited until AFTER winter to OCI, rather than do it before.
But I understand the typical BITOG addiction to wrench on stuff .... Must...Touch...Tools...
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Motorcraft 5W-30 Blend 17 2.3EB Explorer [Re: Whimsey] #4653669
02/02/18 07:37 AM
02/02/18 07:37 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
I would respectfully disagree with Dave on this one-those viscosity numbers are not good at all for 5W30, especially without the fuel contamination that EB engines are known for-you did the right thing by changing it.
Re: Motorcraft 5W-30 Blend 17 2.3EB Explorer [Re: Whimsey] #4653690
02/02/18 08:17 AM
02/02/18 08:17 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Quite a drop in KV100C due to shearing and fuel dilution, nontheless the metal wear rates are good.
Oil is serviceable and OCI could be further extended IMO.
Re: Motorcraft 5W-30 Blend 17 2.3EB Explorer [Re: dnewton3] #4653822
02/02/18 11:10 AM
02/02/18 11:10 AM
The Garden State
Whimsey Offline OP
Whimsey  Offline OP
The Garden State
Originally Posted By: dnewton3
Good wear overall.
LOL LOL LOL I'm 64, 2 replacement knees, bad arthritis, can't see close up anymore and I HATE the cold! I only wrench when I have, like getting the snowblower working for winter or changing my own oil for peace of mind grin2 . In this case if I waited till after winter which is usually mid-late April I'd be up in the 9,000 mile OC range. Not a comfort zone for me with a synblend oil in the EB engine through winter with lots of remote starts by my wife, who drives this. When I replaced the oil on 12/5 I used Mobil 1 5W-30, same as in my first UOA shown. This I hope to run into June. I should have around 7,000+ miles on the oil with it running through the worst of winter, again lots of remote starts. And yes I'll do an UOA. With our Ford 4.6 and 2.0 Zetec, both port injected, I do ~9,000+ mile OCIs and feel comfortable. I'm still trying to establish my 'comfort zone" with this EB engine.
Whimsey
Re: Motorcraft 5W-30 Blend 17 2.3EB Explorer [Re: Whimsey] #4653834
02/02/18 11:26 AM
02/02/18 11:26 AM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
Thanks, Whimsey. Yep, that one got sheared and/or diluted pretty good. It is kind of hard figuring a good point here for mileage. I am going to Castrol 0W-40 this summer for both of our Ecoboosts, and see how it holds up over 4k-ish miles. Otherwise, I can't see going much more than 2500-3000 with the 30's.
Re: Motorcraft 5W-30 Blend 17 2.3EB Explorer [Re: zeng] #4653836
02/02/18 11:28 AM
02/02/18 11:28 AM
The Garden State
Whimsey Offline OP
Whimsey  Offline OP
The Garden State
The shearing cause is interesting. I know that Blackstone's fuel dilution measurement can be dubious at times. But in this case even with the sheared viscosity level the fuel dilution level is still above the norm and there is less than .5% fuel dilution they're showing shrug . I think the DI and turbo both take a toll on the oil viscosity, especially ON a conventional or synblend oil even if they meet the Ford specification of WSS-M2C946-A. I believe if you're planing on keeping vehicles with EB engines long term it's probably cost effective to use a synthetic oil in the long term. I'm waiting for Mobil 1's discount of $12/5 qts to pick up some more between March and May and August and October for $11-$13/5 quarts grin .
Whimsey
Re: Motorcraft 5W-30 Blend 17 2.3EB Explorer [Re: Whimsey] #4654685
02/03/18 11:17 AM
02/03/18 11:17 AM
MO,USA
JBinKC Offline
JBinKC  Offline
MO,USA
Just an observation:
It seems ever since their Shield oils came out (Conoco/Phillips 5-30 synblend) I am seeing more UOAs shearing down a grade like most other conv. and synblend oil brands when in the past it has been very resistant to it. Maybe this is an a adjustment in the formulation for CAFE standards
It doesn't seem to affect performance of the measurements performed by Blackstone.
