Crane EE 5301 Humidifier
by maverickfhs. 12/15/18 02:38 PM
I have sinned
by 901Memphis. 12/15/18 01:57 PM
Milwaukee m12 in vanhaus ratchet
by pda1122. 12/15/18 01:19 PM
Klein dikes
by Donald. 12/15/18 01:03 PM
Help Soldering 3.5mm mono microphone plug
by Brybo86. 12/15/18 01:02 PM
Small Trolling Motors
by wings&wheels. 12/15/18 12:49 PM
Toyota Corolla, good and bad?
by jongies3. 12/15/18 12:35 PM
Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
71 registered members (atikovi, 901Memphis, anndel, ArrestMeRedZ, 10 invisible), 1,736 guests, and 37 spiders.
Topics295,113
Posts4,927,994
Members66,688
Most Online2,553
Oct 27th, 2018
Head Gasket Failure #4653168
02/01/18 12:59 PM
02/01/18 12:59 PM
Venezuela, South America
Emanuel Offline OP
Emanuel  Offline OP
I recently posted on this forum that I had a problem of loss of coolant, there wasnīt any leaks and the radiator cap seemed to have been working properly. Coolant expansion tank boiling, many people pointed that my problem could be related to my head gasket.
Yesterday my car lost compression between two cylinders, the number 1 and 2, my mechanic took the cylinder head apart and saw that the head gasket was burnt between two cylinders. Before bringing the car to my mechanic I checked the cooling system to see if combustion gases were getting into the cooling system. I saw bubbles the first time I started the engine but after that there wasnīt any bubbles. The car was blowing some white and blue smoke on the tailpipe, and coolant loss was very slow like 300 cc every 3 days. I didnīt saw any condensation on the oil filler cap nor in the oil dipstick.
My question is: Should I change my oil even when there arenīt any signs of coolant getting into the lubrication system?
Re: Head Gasket Failure [Re: Emanuel] #4653172
02/01/18 01:01 PM
02/01/18 01:01 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Yes
2015 Hyundai Sonata 2.4L 88k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 231k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: Head Gasket Failure [Re: Emanuel] #4653184
02/01/18 01:19 PM
02/01/18 01:19 PM
Onondaga County
Miller88 Online content
Miller88  Online Content
Onondaga County
Any time I've pulled a head off of an engine, there's always been coolant that's dropped onto the pistons or down oil passages. Both of which will ultimately make their way into the oil.
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
Re: Head Gasket Failure [Re: Emanuel] #4653185
02/01/18 01:20 PM
02/01/18 01:20 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Sorry to hear of the blown HG . Not good news , but , at least , you have a direction to go .
Best of luck to you , :-)
Wyr
God bless
Re: Head Gasket Failure [Re: Emanuel] #4653186
02/01/18 01:22 PM
02/01/18 01:22 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
wink Glad you can put that issue to rest. Toyotas and headgaskets my friend, you should be fully aware by now. Yes, of course change the oil. Also look into getting a thermostat installed ASAP, Toyota engine thermal management is already chronically abysmal IMO and cycling head temps, pressure fluctuations and overcooling/uneven head temps are just going to guarantee head gasket problems in a Toy 4 cyl. The 1ZZ is better for headgaskets than other Toy 4's but their head sealing is noticably below average relative to the entire pool of engines currently in service.
Also a shout out to tig1 who actually called it first.
Scambling for solutions is a hopelessly futile endeavour and potentially dangerous, without first coming to a solid, personal understanding of the problem. Beware riding the ideological hobby horse.
Re: Head Gasket Failure [Re: PeterPolyol] #4653189
02/01/18 01:31 PM
02/01/18 01:31 PM
Emanuel Offline OP
Emanuel  Offline OP
I have a 7AFE engine not a 1ZZFE. My first head gasket lasted 250k miles.
Re: Head Gasket Failure [Re: Emanuel] #4653203
02/01/18 01:44 PM
02/01/18 01:44 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Oh a 2001 with a 7A, that's got to be a E110 (old school Corolla like the Geo Prism). We don't have 2001s like that here in Canada. Why didn't you clarify earlier? The thermostat is off the head in that car, not on the block. Yeah 250K miles is good for one gasket (though I don't rate them in miles, they're not wear items!). The A-engine isn't so notorious for head gasket weakness, not like the E- and S- engines from that era that's for sure.
Re: Head Gasket Failure [Re: Emanuel] #4653212
02/01/18 01:51 PM
02/01/18 01:51 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Yes change the oil. It will be full of contaminants. And change it again in a couple days.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Head Gasket Failure [Re: Nick1994] #4653240
02/01/18 02:20 PM
02/01/18 02:20 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Yes
+1
Re: Head Gasket Failure [Re: PeterPolyol] #4653319
02/01/18 04:08 PM
02/01/18 04:08 PM
Emanuel Offline OP
Emanuel  Offline OP
The serial in the car says it is a AE112, I didnīt clarify earlier because Iīm used to 99-02 Corollas having A-Series Engine here in Venezuela, and in South America, Europe and Asia.
Re: Head Gasket Failure [Re: Emanuel] #4653320
02/01/18 04:08 PM
02/01/18 04:08 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Yeah if you go through all that trouble may as well just change the oil to be safe..
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Head Gasket Failure [Re: Rolla07] #4653323
02/01/18 04:10 PM
02/01/18 04:10 PM
Emanuel Offline OP
Emanuel  Offline OP
I will change the oil
Re: Head Gasket Failure [Re: Emanuel] #4653386
02/01/18 05:54 PM
02/01/18 05:54 PM
Silicon Valley
PandaBear Offline
PandaBear  Offline
Silicon Valley
Yes, your oil is toasted. After your HG change your mechanic should put new oil in it as well for this reason. Change this first fill early and if you have time, take the pan off and scrape any sludge that might have build up from the coolant leak as well.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Head Gasket Failure [Re: Emanuel] #4653443
02/01/18 07:22 PM
02/01/18 07:22 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
IIR the original thread correctly (it got a bit convoluted) this engine already had a head gasket replacement in its fairly recent past.
If that is correct, its particularly important (though its always important) that your mechanic doesn't just chuck another one on. The head and the block need to be carefully checked for distortion with a known-good steel straight edge and feeler guages. You can check the stright edge with fishing line.
Such distortion might explain short head gasket life. I don't know this engine, but if it uses stretch head bolts you should also ensure that they aren't being re-used.
Nothing specific against your mechanic, but I wouldn't trust a randomly selected Taiwanese mechanic further than I could throw them.
Re: Head Gasket Failure [Re: Emanuel] #4653461
02/01/18 07:48 PM
02/01/18 07:48 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Change it. An oil analysis is the only way to verify coolant free oil.
The "thinking" man's friend.
