Can alternators make noise?
by Benzadmiral. 09/20/18 01:21 PM
Pr 1970 Superbirds For sale - Barn Find
by user52165. 09/20/18 12:32 PM
Fram Ultra Air Filters
by StevieC. 09/20/18 12:20 PM
Change oil filter or not. Very low miles
by Martin10. 09/20/18 11:37 AM
Toslink optical audio cable (plastic) experience
by ffhdriver. 09/20/18 11:30 AM
A woman I work with wants an affair with me!
by Drew99GT. 09/20/18 11:08 AM
ACEA A5/B5 REQUIREMENTS
by Kjmack. 09/20/18 10:56 AM
Carolina Reaper hot peppers
by gman2304. 09/20/18 09:54 AM
New Fram air filter?
by irv. 09/20/18 09:15 AM
Any golf cart experts?
by HawkeyeScott. 09/20/18 09:15 AM
EU Subaru 2.5 FB engine oil
by IMPALA08. 09/20/18 08:16 AM
02 Focus head replacement
by Eric Smith. 09/20/18 08:08 AM
A5/B5 or A3/B3
by ka9mnx. 09/20/18 07:53 AM
2018 Mazda 3 2.5 Castrol or Mazda Moly
by mazdamonky. 09/20/18 07:44 AM
What fuel are you running?
by Matagonka. 09/20/18 07:25 AM
Be careful what you wish for...
by Shannow. 09/20/18 04:40 AM
Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
97 registered members (94astro, AZjeff, ABomb369, ad244, 2010Civic, 9 invisible), 1,676 guests, and 50 spiders.
Topics290,714
Posts4,848,913
Members66,021
Most Online3,590
Jan 24th, 2017
charcoal EVAP canister question #4653142
02/01/18 01:30 PM
02/01/18 01:30 PM
co
NissanMaxima Offline OP
co
Hi all:
This is a two part question for the board...
I get a slight odor of gas after driving my 95 Maxima and parking it in the garage. I've had it to the dealer that I use from time to time and they did (I think) a pretty thorough inspection. They were not able to find any obvious leaks and their only suspicion is the charcoal canister needs to be replaced. This is an expensive part for this car and although I could attempt installation myself, I may elect to have them do it in which case that is more $$. I always thought evap systems were "closed". If there are no leaks in the lines, where is the odor coming from? Is there some over pressurization vent or something that opens up? Also, the gap fine is fine and holding pressure.
Now to the second question...some folks on a Nissan board I frequent suggested checking for engine codes with a scanner. They said that just because the CEL is not on does not guarantee there is not a code to be retrieved. Is this correct? From what I understand Nissan has their own scanner (I think it is called Consult). Should I take it to another dealer to see if they can retrieve any codes that might point to something other than the canister? What about an OBDII scanner? I don't have one nor have ever used one but see they are really cheap at PepBoys and the like. Does anyone know if an OBDII scanner would retrieve the same codes as what Nissan might determine? If so, can I get away with one of these $14 USD ones I see for sale or should I invest in something a bit better and what should I look for as a first time buyer/user of one of these.
Re: charcoal EVAP canister question [Re: NissanMaxima] #4653147
02/01/18 01:39 PM
02/01/18 01:39 PM
KY
MCompact Online content
MCompact  Online Content
KY
Double-check the hoses going to the canister; a cracked/split hose is usually the culprit- not the canister.
Mine:
2014 M235i
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2009 Cooper Clubman
Son's
2009 328i
Buy what makes you smile...
Re: charcoal EVAP canister question [Re: NissanMaxima] #4653166
02/01/18 01:57 PM
02/01/18 01:57 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
IIRC, in general 95 model year is not OBD-II compliant.
I am not sure if Nissan started their compliant in 95.
You can probably ask the Nissan forum about that.
If it is NOT OBD-II compliant, then there is NO OBD-II reader/scanner can read the code.
I know GM uses ALDL connector on the 95 model year which has a different pin and different standard, it is their version of OBD-I (one instead of two).
  • 2017 Toyota Sienna
Re: charcoal EVAP canister question [Re: NissanMaxima] #4653167
02/01/18 01:57 PM
02/01/18 01:57 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
At that time, each manufacturer have different standard and only their reader/scanner can read the code.
Plus the code is manufacturer specific since there is no standard.
Re: charcoal EVAP canister question [Re: NissanMaxima] #4653179
02/01/18 02:13 PM
02/01/18 02:13 PM
Displaced Texan in Mexico City
Gimpy1 Offline
Gimpy1  Offline
First things first, you stated that you 1995 Nissan Maxima..., OBD2 was not required by federal law until 1996. So the first thing you need to verify is which diagnostic system your vehicle has. OBD2, among other things, standardized the DLC connector to the trapezoidal connector you commonly see on any current scanner, prior to that each auto manufacturer had their own connector and interface. So first you before you buy ANYTHING verify which diagnostic system you car has. Secondly, assuming your car has OBD1, you will not be able to use an OBD2 scanner, and since OBD1 is less robust you might not even get a code for an EVAP issue. I suggest you get a good service manual and start troubleshooting from there. Just because you have a certain code does't mean you should start replacing parts willy nilley. Find the root cause of the issue first. When does the gasoline smell start, right after you fill the tank completely, 3/4 or when the fuel gauge is nearly at empty? It could quite possibly be the purge solenoid is not working, or a cracked line. Replacing the charcoal canister in that situation will do absolutely zero except make your wallet lighter. Replacing parts based on DTC's is the worst thing you can do. DTC point you to the issue, further diagnostics are still needed. Here is an example: lets say you go get gas some early morning on the way to work, you pay for your gas, and are happily on you merry way to work that 9-5, all of a sudden in traffic your amber check engine light goes on, so you go to autozone where they do free scans and the the scanner shows an EVAP code. You read that it is a something to do with the EVAP canister so you go and spend xxx amount of cash and replace the canister, the check engine light is still on and goes back on after being cleared, your like [censored], so you do more diagnostics, and check you fuel cap, which was not properly closed and bang it dawns on you the gross leak was from an improperly closed fuel cap which would have been a free "repair". Now this is an exaggerated example but I have seen it happen. Moral of the story is first find out which on board diagnostic system you have, find out exactly which components are affected or involved in the DTC, check ALL components to verify that they are in working order and finally replace the faulty component based on a complete diagnosis. Google and YouTube are you friends and are free. Use them. Hope this helps
Re: charcoal EVAP canister question [Re: JMJNet] #4653180
02/01/18 02:14 PM
02/01/18 02:14 PM
co
co
Hi: Folks on the Nissan board state the car is actually OBDII compliant. I have seen folks at the emission station occasionally hook up to a connector under the dash on the passenger side which I believe is the OBDII connector.
Re: charcoal EVAP canister question [Re: NissanMaxima] #4653190
02/01/18 02:31 PM
02/01/18 02:31 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
There is a connector in my 95 Suburban also under the dash but it was not OBD-II compliant.
You can try going to the part store and see if it is really compliant.
Unfortunately, we cannot determine that for you.
Re: charcoal EVAP canister question [Re: JMJNet] #4653193
02/01/18 02:33 PM
02/01/18 02:33 PM
toronto
PeterPolyol Offline
PeterPolyol  Offline
toronto
Yeah 95 was a strange year of transition to OBD2. Lots of Japanese 95s have an OBD style connector but don't run the OBD protocol and thus don't work with OBD scanners. On the Max it might be a simple matter of grounding a test pin to make the CEL flash the code out- might not need a scanner at all?
NissanMaxima, Check for a rusted or broken vapor line along the bottom of the vehicle, right from the tank to the canister. You'd really notice it on warm days or just after fueling up.
Re: charcoal EVAP canister question [Re: NissanMaxima] #4653199
02/01/18 02:40 PM
02/01/18 02:40 PM
Gimpy1 Offline
Gimpy1  Offline
Instead of trusting what folks on the Maxima forum say (which can vary depending on the build date of your car or the submodel) verify it by looking for the compliance sticker ON THE VEHICLE itself. You can usually find the info on the door sticker that has the VIN and manufacturer info. Just google obd2 compliance sticker and go to images, you will find the location of the stickers.
Re: charcoal EVAP canister question [Re: NissanMaxima] #4653201
02/01/18 02:42 PM
02/01/18 02:42 PM
California
nthach Online content
nthach  Online Content
California
That Maxima uses a primitive EVAP system compared to most post-2000 cars with on-board refueling vapor recovery and returnless fuel systems which are a bit more air-tight than the 1st gen systems.
I'd start first by checking the lines between the vacuum switching valve for both EGR and EVAP and the vapor lines between the intake manifold, carbon canister and fuel tank. There's also a valve at the tank as well. Your car can't run a check pump to check for an EVAP leak or loose fuel cap but there's a rollover/vent valve at the tank to route vapors to the canister.
Re: charcoal EVAP canister question [Re: NissanMaxima] #4653202
02/01/18 02:42 PM
02/01/18 02:42 PM
NJ
Leo99 Online content
Leo99  Online Content
NJ
Get under the car and inspect the hoses to/from the canister. I've changed one out. On my Toyota, there is a tricky fuel line connection you just had to be patient with. THhe canister for your maxima is only $55 on rockauto. Canister for my Rav4 goes for $350 but I found one on ebay for $250.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 359,000 miles
2015 Camry 59,000 miles
Re: charcoal EVAP canister question [Re: NissanMaxima] #4653216
02/01/18 02:56 PM
02/01/18 02:56 PM
toronto
PeterPolyol Offline
PeterPolyol  Offline
toronto
If needed, consider rebuilding your canister. I could never pay hundreds of $$$s for 4 bucks worth of charcoal pellets and 3 bucks worth of plastic.
Re: charcoal EVAP canister question [Re: NissanMaxima] #4653281
02/01/18 04:31 PM
02/01/18 04:31 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Check for gas leaks underneath or any oil leaks if dropping on exhaust etc.. check the hoses (as mentionned) and check for exhaust leaks. If its none of the above, I wouldnt worry about it. My 07 smells like gas when started too.. I wouldnt bother spending the money on an EVAP canister even if it was the culprit. Just not worth it. Park the car outside if worried about Carbon Monoxide. I wouldnt worry too much though about a "slight odour of gas".
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: charcoal EVAP canister question [Re: NissanMaxima] #4653348
02/01/18 05:46 PM
02/01/18 05:46 PM
ME
eljefino Offline
eljefino  Offline
ME
Does your car go "whoosh" when you open the gas cap to buy gas? It should, as it's supposed to keep a slight vacuum so the fumes stay in.
I would go to an emissions guy and get the car smoke tested. You could have a hole in the top of the gas tank for example.
Even if the car were (partly) OBD-II compliant as an experiment on Nissan's part, the EVAP testing system might not have been included as it was expensive.
Re: charcoal EVAP canister question [Re: NissanMaxima] #4653496
02/01/18 09:30 PM
02/01/18 09:30 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
I use to get an occasional smell of gas after driving but with no obvious leaks and no other symptoms. It turned out to be a leak at the fuel filler hose between the filler neck and the tank. It only leaked when in motion and would dry quickly when stopped.
Why do you think that the evap canister is the issue?
