Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
Diesel engines and emissions
by spasm3. 12/16/18 03:31 PM
Experiment time
by 53' Stude. 12/16/18 02:52 PM
2019 2.7L EB - Edge ST & Catch Can
by -SyN-. 12/16/18 02:51 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
66 registered members (ABomb369, 1345, bdcardinal, anndel, A310, 8 invisible), 1,436 guests, and 45 spiders.
Topics295,169
Posts4,929,070
Members66,700
Most Online2,553
Oct 27th, 2018
WIX 51516 XP Q?s #4653002
02/01/18 10:17 AM
02/01/18 10:17 AM
Cajun Country, La.
BlueOvalFitter Offline OP
Cajun Country, La.
After reading the post in this forum about WIX oil filters I did some research on the application for my trucks engine (Ford 4.2 V6). According to the WIX website, it shows my filter application having the base plate end by-pass valve. Well, the filter that I bought from ROCK AUTO for $3.14, DOES NOT have aforementioned by-pass valve. I wonder, why not? Maybe that's why it only cost $3.14? If I had known this prior to buying it, I would have bought a FU at the same time, used it instead, and kept the WIX as a spare. Opinions?
shrug
Re: WIX 51516 XP Q?s [Re: BlueOvalFitter] #4653018
02/01/18 10:34 AM
02/01/18 10:34 AM
Idaho
CT8 Online content
CT8  Online Content
Idaho
The Fram has the dome bypass as well if I unserstand the post.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: WIX 51516 XP Q?s [Re: CT8] #4653032
02/01/18 10:52 AM
02/01/18 10:52 AM
Seattle, WA
SnowmanCO Offline
SnowmanCO  Offline
Seattle, WA
It's hard to see the bypass valve's on the Wix's from the outside the filter. Unlike the Motorcraft filters where you can see the extra threads. Yours is probably similar to this https://www.youtube.com/watch?v=56JfXs_5ajw or illustrated here as well https://www.youtube.com/watch?v=YcJ0pp2pneY
16 F150 5.0-QS UD 5w20,MtCrft FL500S
10 Merc C300-Mob 1 0w40,MANN H U7 18/5X
08 Maz3S 2.3-Cast Syn 5w30,Wix 57203XP
17JD D160-Cast Syn 0w30,MtCrft FL400S
Re: WIX 51516 XP Q?s [Re: SnowmanCO] #4653035
02/01/18 10:57 AM
02/01/18 10:57 AM
Seattle, WA
SnowmanCO Offline
SnowmanCO  Offline
Seattle, WA
After looking at it again, it has the end bypass valve like the Platinum here https://www.youtube.com/watch?v=1B_hWb5mCCg.
Thread on the pros and cons of base plate bypass here https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2651107. Filter mounting direction (filter mounting downward benefits most), and sacrificing amount of media (less on base plate bypass designs) seems to be a big factor on why they place the bypass on one end versus the other.
Re: WIX 51516 XP Q?s [Re: BlueOvalFitter] #4653048
02/01/18 11:07 AM
02/01/18 11:07 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
shrug
It really, TRULY, genuinely does NOT matter.
I doubt your oil filter on your 4.2 ever goes into bypass for more than a second on the coldest day of the year.
Why worry about such a trivial thing?
Read this: https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3197094/
He had to go full throttle sometimes to get it to open. You are worrying about nothing.
Re: WIX 51516 XP Q?s [Re: BlueOvalFitter] #4653049
02/01/18 11:08 AM
02/01/18 11:08 AM
The land of USA-made Subies!
SubieRubyRoo Offline
I've used the Napa Platinum 41516 (same filter) on my Fusion for a couple OCIs. Wear numbers and insolubles looked good, but guys like ZeeOhSix are convinced these filters are better described as sieves. I bought a couple on sale but will not pay regular retail of nearly $13.
Re: WIX 51516 XP Q?s [Re: SubieRubyRoo] #4653062
02/01/18 11:16 AM
02/01/18 11:16 AM
Seattle, WA
SnowmanCO Offline
SnowmanCO  Offline
Seattle, WA
B2=20 means 95% efficient at filtering particles 2 microns or larger. Not exactly sieves if you believe what that number really means. Some people think it means 50% of particles 20 microns or larger.
Re: WIX 51516 XP Q?s [Re: SnowmanCO] #4653084
02/01/18 11:34 AM
02/01/18 11:34 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
That is not correct.
B2="X" means that the fitter is 50% at um "X", not 95%.
When you see a "B" followed by a number, that number is the inverse fraction factor.
Example B2 = 1/2. And we know that 1/2 = .50, or 50%. So it's then applied to the formula of the "whole - the passing effect". (100%-50% = 50% efficient at "X"um size)
Example B20 = 1/20 = .05, so it's 5% that passes, or 95% efficient at catching stuff.
Wix often states stuff such as B2/20 = 6/20. That means it's 50% at 6um; 95% at 20um.
(it's kind of misleading, because it's really more appropriate to state B2 at 6um, B20 at 20um, but that's not how it's done).
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: WIX 51516 XP Q?s [Re: SnowmanCO] #4653088
02/01/18 11:38 AM
02/01/18 11:38 AM
Oklahoma
CELICA_XX Offline
CELICA_XX  Offline
Oklahoma
The Wix XP always seemed good to me, but I know the 50% designation has always been a source of confusion for many members including myself.
15 Toyota Prius - M1 EP 0w20 SN+
02 Toyota ECHO - Valv MaxLife Full Syn 5w30 SN+
97 Lexus LX450 - M1 EP HM 5w30 SN+
93 Lexus LS400 - Valv MaxLife Full Syn 5w30
Re: WIX 51516 XP Q?s [Re: SnowmanCO] #4653098
02/01/18 11:44 AM
02/01/18 11:44 AM
Seattle, WA
SnowmanCO Offline
SnowmanCO  Offline
Seattle, WA
Then again Royal Purple uses the same Beta ratio formatting, but they have it backwards:
"Average beta rating based on ISO 4548-12 multi-pass test methods:
B100 = 25 (which means at 25 or greater micron; media is 99% efficient.)
B75 = 20 (which means at 20 or greater micron; media is 98.7% efficient. Also considered absolute rating.)
B5 = 10 (which means at 10 micron or greater; media is 80% efficient.)"
They have it listed backwards really. The number after the B should be the particle size. They have the number after the B as the number of 1/X particles that make it through at the listed particle size. This is an unconventional formatting based on a number of industry documents I have seen. If this were applied to the Wix XP, the is would mean 50% of particles 20 microns or greater. But, again, this is not conventional.
See here (and many other places) at 6:09 it shows the number after the B should indicate the particle size https://www.youtube.com/watch?v=aiLhfAFhkvs
Re: WIX 51516 XP Q?s [Re: Linctex] #4653111
02/01/18 12:03 PM
02/01/18 12:03 PM
Cajun Country, La.
Cajun Country, La.
shrug
It's an insomnia thing! Do you know how much I'm going to be pacing the floor at night, not being able to sleep, knowing that it's not a base plate by-pass? Oh, woes me, oh woes me!
Ah well, it's built like a FU so that part makes me happy. I "GUESS" it deserves it's turn on my almighty V6 engine! Oh, and if it makes my engine clatter upon start up, I will remove it so fast the paint will have to catch up with the filter!
crackmeup
Re: WIX 51516 XP Q?s [Re: SnowmanCO] #4653150
02/01/18 12:41 PM
02/01/18 12:41 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
LOL ... there is no filter on the market for passenger cars that is "95% @ 2 microns" efficiency. You're all twisted up on understanding WIX's beta format.
Re: WIX 51516 XP Q?s [Re: BlueOvalFitter] #4653156
02/01/18 12:46 PM
02/01/18 12:46 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Well, not really if you include the media performsnce as part of the "build". J/K laugh
Don't worry about it, just don't redline your engine when the oil is cold.
Re: WIX 51516 XP Q?s [Re: BlueOvalFitter] #4653450
02/01/18 07:33 PM
02/01/18 07:33 PM
Georgia
MParr Offline
MParr  Offline
Georgia
BOF
I contacted WIX today. The technical rep answered the bypass question for me. He said it didnít really matter which end the bypass valve was in. You do get more media area with the dome end bypass. Iím like you about the bypass location for a Ford product. The Motorcraft FL-400s has the base end bypass. The WIX 51516 and the NAPA Gold 1516 has the base end bypass. The WIX 51516XP and the NAPA Platinum 41516 both have dome end bypass. He told me that the bypass location could change in future WIX and NAPA Gold oil filters. So, open the box and look before you buy. I do that anyway because there may be some manufacturing flaws in any brand filter that can be seen.
2013 KIA Optima EX 2.4L. Now: QSUD 5W30 & STP S2808ML
2017 Ford Escape SE 2.0T Now: Mobil 1 5W30 & NAPA Gold 1348
Re: WIX 51516 XP Q?s [Re: MParr] #4653490
02/01/18 08:25 PM
02/01/18 08:25 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Originally Posted By: MParr
I contacted WIX today. The technical rep answered the bypass question for me. .....
Wonder if it will be because of M+H having control.
