one of the kids damaged a wheel on the Camry; I ordered a Toyota rim from DT; show up for the appt and they did not have the wheel. Grrrrr! instead they had a generic rim - and the hub hole is 1/2" larger than the hub. Does wheel stability, rigidity, and design require that the hole size match? I would think that it should....
