Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Ericbrooks, Japanese, lordcheeto, WondrousBread, slickoo9
66672 Registered Users
24 registered members (4WD, bbhero, Char Baby, ArrestMeRedZ, Duffyjr, DirtyOilGuy, 2 invisible), 781 guests, and 38 spiders.
Topics295,047
Posts4,926,767
Members66,672
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
How much ZDDP do I need? #4652944
02/01/18 09:26 AM
02/01/18 09:26 AM
SD - South Dakota
meborder Offline OP
meborder  Offline OP
SD - South Dakota
Not sure if there is a hard number or not, but I need to know what kind of oil I should be looking for.
I put a bigger cam in a 305 for my plow truck and upgraded the springs accordingly
It is a hydraulic flat tappet cam with 260/260 advertised duration 204/204 @ 0.050" lift. It has .427" lift at the valve.
The springs are 358lbs/inch. They have 125lbs on the seat and just shy of 300 lbs at lift with this cam.
So the cam isn't wildly aggressive, but moderately so (with regard to cam intensity, not duration). The springs aren't "bone crushing" but they are quite a bit more than stock.
What should I be looking at for oil? I'd like to stay with a 5w30 because this is a winter rig, so that makes it harder.
From what I've found, 800ppm is inadequate for these spring pressures. But I don't need a race oil with 2000ppm either.
Any ideas where I need to be for ZDDP?
Too many cars using too many different oils to list in 150 characters.
Re: How much ZDDP do I need? [Re: meborder] #4652950
02/01/18 09:30 AM
02/01/18 09:30 AM
Balearic Islands , Spain
FordCapriDriver Offline
A well worn flat tappet doesn't need huge amounts of Zddp, but a little extra won't hurt anyway.
Probably the best choice for it is Shell Rotella 10W-30, it's gasoline rated, and being a HDEO it has a healthy dose of Zddp, well above 1000ppm, in the 1200-1400ppm range iirc.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort Mk4 Xr3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Finnish expat in Spain.
Re: How much ZDDP do I need? [Re: meborder] #4652954
02/01/18 09:31 AM
02/01/18 09:31 AM
Or if you want something that flows better when cold Rotella T6 5W-40 and it's a full synthetic again with plenty Zddp.
Re: How much ZDDP do I need? [Re: FordCapriDriver] #4652990
02/01/18 10:11 AM
02/01/18 10:11 AM
wv
krismoriah72 Offline
wv
Didnt those engines produce about 150hp? I had a 77 pickup with the 305..no comment.
Not sure how fresh the rest of your engine is.. the 5w40 is plenty for your needs.. otherwise look at these high mileage oils.
http://www.pqiamerica.com/June%202014/consolidated%20highmileage2014.html
Re: How much ZDDP do I need? [Re: meborder] #4653004
02/01/18 10:21 AM
02/01/18 10:21 AM
Western NY state
Truckedup Offline
Truckedup  Offline
Western NY state
5-40 may be a light for an older Chevy V-8.. Even if rebuilt the bearing clearance are looser than modern stuff.. Of course it depends how cold it gets where you are .....As mentioned ,less is required once it well broken in, but Chevy Gen 1 engines were never known for long cam life so .generally speaking, 1200 on ZDDP is safe.. I use Rotella 10-30 T4 in my older 4.0 flat tappet Jeeps.. Low temps here are about zero F...cranks over just fine...
World's second fastest vintage Triumph 650, 133 MPH
Re: How much ZDDP do I need? [Re: meborder] #4653074
02/01/18 11:26 AM
02/01/18 11:26 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Moly not zddp.
If you want both, a co in L.A. used to blend synthetic oil for snowblowers that had lots of moly and zddp. Ran that in a Toyota in the mid 2000's and it was steller!
Summer? 25w40 Marine oil or 4T motorbike oil - equivalent and better than API SH in what you need.
2014 Nissan Rogue S CVT, OC#10 47272mi-QSUD10W30+5w20 Toughguard Filter; '17 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: How much ZDDP do I need? [Re: meborder] #4653083
02/01/18 11:33 AM
02/01/18 11:33 AM
WA
fuzzysig Offline
fuzzysig  Offline
WA
does zddp protect anything else besides cams and rockers?
Re: How much ZDDP do I need? [Re: meborder] #4653108
02/01/18 11:55 AM
02/01/18 11:55 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I am guessing you DID NOT follow the advice of the cam manufacturer when you chose those springs....
That cam is MILD, stock springs are fine!
Why did you go with such ridiculous springs?
Re: How much ZDDP do I need? [Re: meborder] #4653136
02/01/18 12:26 PM
02/01/18 12:26 PM
missouri
ragtoplvr Offline
ragtoplvr  Offline
missouri
you can get a 10W30 Motorcycle oil, they will have plenty of additives for flat tappets.
Rod
Re: How much ZDDP do I need? [Re: Linctex] #4653159
02/01/18 12:50 PM
02/01/18 12:50 PM
SD - South Dakota
meborder Offline OP
meborder  Offline OP
SD - South Dakota
It is a summit cam and I used the springs they recommended. It wasn't until well after I had them installed that I realized they were a lot more spring than really needed. I just went with what they said and didn't even question it.
The actual over the nose pressure is 277 lbs at .427 as calculated.
The engine is a 1990 and had about 36,000 miles on it. Was spotless inside when I opened it up. 150hp is about right. This cam has about 20 degrees more duration and almost .050 more lift on the intake side compared to the stock cam. That's why changed it. Just needed a little more everything everywhere.
I found some amsoil diesel graded 5w30 which has about 1300 ppm of zinc, which I feel pretty good about, but it's not cheap so looking for alternative.
Re: How much ZDDP do I need? [Re: meborder] #4653200
02/01/18 01:41 PM
02/01/18 01:41 PM
Western NY state
Truckedup Offline
Truckedup  Offline
Western NY state
From my past experience,220 pounds open, 100 pounds on the seat is fine...it's a few hours of work to change them without pulling the heads....I think in the long run you'll be better off....
Re: How much ZDDP do I need? [Re: fuzzysig] #4653224
02/01/18 02:00 PM
02/01/18 02:00 PM
It does not do anything to the rockers.
ZDDP ( Zincdialkyldithiophosphate = Zinc and Phosphorous ) is designed to react chemically to high friction areas which produce heat and creating a film between those parts, specially to keep the followers and cam lobs from tearing eachother apart when in boundary lubrication ( low revs idling ).
Flat tappet camshafts in overhead valve Vee engines are just prone to wear, the camshaft in these engines is not pressure fed, all the oil it gets is the oil that the crankshaft throws around the crankcase.
That is why when breaking in a flat tappet cam you are advised to immediately bring the revs up to 2000-4000 rpm, the higher the engine speed the more oil the camshaft recieves.
Re: How much ZDDP do I need? [Re: meborder] #4653254
02/01/18 02:53 PM
02/01/18 02:53 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
That would be AMSoil HDD, which is a good oil.
Or AMSoil Z-Rod is one that has high zddp, but I'm not sure it's available in 5w30.
Redline 5w30.
Valvoline VR1 10w30 is a conventional oil with high zddp, so it will be cheaper than the boutique synthetics.
I'd shy away from Rotella T5. It's not high zddp.
I think you need 1200 ppm of Phosphorous as a safe starting point.
Did you use any kind of assembly lube with high zddp when you installed the cam?
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: How much ZDDP do I need? [Re: A_Harman] #4653292
02/01/18 03:44 PM
02/01/18 03:44 PM
SD - South Dakota
meborder Offline OP
meborder  Offline OP
SD - South Dakota
Redline 5w30.
I did. I used the zinc-rich assembly paste on the lobes and lifters face during assembly. I also broke it in at high idle for 15 min with amsoil break in oil which is 2000+ppm zddp. I still have the break in oil in the sump. It probably has 30-45 min of run time on the motor, most of which is at a very fast idle.
Re: How much ZDDP do I need? [Re: meborder] #4653317
02/01/18 04:07 PM
02/01/18 04:07 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
The Euro oils often have more ZDDP than typical ILSAC oils which are often 800 ppm or less.
M1 0W40 is listed at 1100 ppm zinc. That's a good step up in ZDDP and with ample winter cold starting ability. It's right at the thin end of the 40 grade oils in terms of viscosity, close to a thick 30 grade.
Just another option for you.
BTW I'm using semi-synthetic Penrite oil with 1200ppm zinc right now, just because....
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Page 1 of 3 1 2 3
