Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Need Expert TIG Welder, Toronto Area
by George7941. 03/18/19 01:44 AM
toplscuda, swrve, TomRx, Ozdave, Rod1701
67547 Registered Users
107 registered members (53' Stude, 928, addyguy, 97prizm, 2009Edge, 6 invisible), 2,257 guests, and 58 spiders.
Topics286,015
Posts4,900,757
Members67,547
Most Online2,967
Mar 10th, 2019
leak down tester : one gauge vs two #4652755
02/01/18 12:32 AM
02/01/18 12:32 AM
Washington for now
WhyMe Online content OP
WhyMe  Online Content OP
Washington for now
i have a leak down tester with a single gauge that i bought 25 years or so ago. i have only used it once and that was when i first got it. i have been learning and doing more engine stuff lately and am thinking of playing with it again
i noticed that the new ones seem to be mostly dual gauge. So is there a difference in accuracy between the two types?
Re: leak down tester : one gauge vs two [Re: WhyMe] #4652818
02/01/18 06:41 AM
02/01/18 06:41 AM
Iowa
Iowegian Offline
Iowegian  Offline
Iowa
Article here that talks a little about 1 vs 2 gauge testers.
http://www.hotrod.com/articles/cylinder-leakdown-tester/
Here is a nice article on testing 4 different leakdown testers.
https://www.google.com/amp/www.hotrod.com/articles/hrdp-1203-budget-leakdown-testers-tested/amp/
I bought this one from Amazon.
https://www.amazon.com/OTC-5609-Cylinder-Leakage-Tester/dp/B0030EVL60
2011 Equinox, 2.4l
2009 Sienna, 3.5l
Re: leak down tester : one gauge vs two [Re: WhyMe] #4652824
02/01/18 06:59 AM
02/01/18 06:59 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
always need two guages...the first one is your air supply regulator
Re: leak down tester : one gauge vs two [Re: WhyMe] #4652843
02/01/18 07:52 AM
02/01/18 07:52 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Single gauges were the norm back in the day and worked fine but you had to set the compressor regulator to the desired PSI which is basically the "first gauge" on most units today.
2 Gauges are more convenient but the results are the same. No reason to replace it, accuracy is the same.
Re: leak down tester : one gauge vs two [Re: Trav] #4653027
02/01/18 11:41 AM
02/01/18 11:41 AM
Washington for now
Washington for now
Cool. thanks for the info
