Planes, smoke, pyrotechnics and lasers
by Shannow. 03/26/19 08:55 AM
Rust paint that works? Canada
by nobb. 03/26/19 07:19 AM
Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
bgm6881, machv5, freewayken, JustMatt, DCDMan
67626 Registered Users
94 registered members (addyguy, ArrestMeRedZ, Ag76, andyd, AdditiveOCD, 13 invisible), 1,890 guests, and 69 spiders.
Topics286,446
Posts4,908,489
Members67,626
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Change all oxygen sensors or not? #4652468
01/31/18 07:54 PM
01/31/18 07:54 PM
Florida
lawnguy Offline OP
lawnguy  Offline OP
Florida
I have a 2000 F150 4.6 V8 with 112k miles on it. Runs great to me overall.
Should I only change all 4 of my 02 oxygen sensors now,or wait until it throws up some code on my dashboard?
Re: Change all oxygen sensors or not? [Re: lawnguy] #4652471
01/31/18 07:58 PM
01/31/18 07:58 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
I am all for PM, but don't fix what isn't broke.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Change all oxygen sensors or not? [Re: lawnguy] #4652479
01/31/18 08:10 PM
01/31/18 08:10 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I would wait til it either throws a code or you have to replace the manifold(s) for cracks or broken studs. Don't change the rear unless they are throwing codes, a lazy but functional rear O2 is less likely to trip a P420/430 code
Re: Change all oxygen sensors or not? [Re: lawnguy] #4652483
01/31/18 08:13 PM
01/31/18 08:13 PM
out there
spasm3 Online content
spasm3  Online Content
out there
How is the fuel mileage? I have never changed rear ones, i have picked up mpg with front 02 sensors on high mileage engines. If your fuel mileage had not dropped noticably, i'd let them be.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Change all oxygen sensors or not? [Re: dlundblad] #4652490
01/31/18 08:19 PM
01/31/18 08:19 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
This! thumbsup
2004 Corolla 130035
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Change all oxygen sensors or not? [Re: lawnguy] #4652493
01/31/18 08:21 PM
01/31/18 08:21 PM
Where the wind comes sweepin'
Reddy45 Online shocked
Reddy45  Online Shocked
I had an 02 F150 and after I changed out all 4 sensors, the truck idled a LOT smoother.
Re: Change all oxygen sensors or not? [Re: lawnguy] #4652502
01/31/18 08:27 PM
01/31/18 08:27 PM
Florida
lawnguy Offline OP
lawnguy  Offline OP
Florida
If I decide to change all 4,should I stick with motorcraft or use another brand name?
Re: Change all oxygen sensors or not? [Re: Reddy45] #4652510
01/31/18 08:33 PM
01/31/18 08:33 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Work was necessary on the forward end of a friend's F-150 exhaust system.
He's still reminiscing over how the immovability of the working sensors resulted in the most severe manifold+pipe repair ever done by man.
Haven't seen it myself.
Re: Change all oxygen sensors or not? [Re: lawnguy] #4652548
01/31/18 09:13 PM
01/31/18 09:13 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
I never replace working parts. I just remove and wash with a solvent anything that is exposed to build up of crud. I "inspect" my O2s once in a blue moon, just so that they don't "rust-weld" themselves. My Heep needs that kind of attention, other cars' pipes are totally rust and crud free so I leave 'em be.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: Change all oxygen sensors or not? [Re: lawnguy] #4652553
01/31/18 09:15 PM
01/31/18 09:15 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
I replaced the uppers on my jeep @110k. Made a huge improvement in power, mpg and response. It did not throw any codes.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Change all oxygen sensors or not? [Re: lawnguy] #4652601
01/31/18 09:44 PM
01/31/18 09:44 PM
Trav Offline
Trav  Offline
Front ones on these can be a real PITA depending on how stuck they are. I may be mistaken but IIRC these are the ones I had to use a 7/8 6pt wrench on and drop the pipe because I couldn't get a socket on. Check first before buying parts.
Re: Change all oxygen sensors or not? [Re: lawnguy] #4652602
01/31/18 09:45 PM
01/31/18 09:45 PM
WA
DeafBrad Offline
DeafBrad  Offline
WA
There is a way to test the sensors. Me thinks if they test ok you will not see benefits to replacing them.
Re: Change all oxygen sensors or not? [Re: Chris142] #4652623
01/31/18 10:02 PM
01/31/18 10:02 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
Some engine types have just one upstream and one downstream.
I got an upstream for $25 off eBay and it was an ACDelco too.
Re: Is this stupid or smart? [Re: lawnguy] #4652627
01/31/18 10:05 PM
01/31/18 10:05 PM
Lakeside, CA
Blkstanger Offline
Blkstanger  Offline
Lakeside, CA
I have over 180k on the ones in my Jeep. Still working fine. Average 19mpg.
99 Jeep WJ 4.7 197,000 Maxlife 10w30, Fram Ultra.
Re: Is this stupid or smart? [Re: lawnguy] #4652629
01/31/18 10:06 PM
01/31/18 10:06 PM
NY, NY
NYEngineer Offline
NYEngineer  Offline
NY, NY
When my Suburban hit about 120,000 miles, it threw an 02 sensor code. I changed all four of them and noticed an immediate improvement in the way the truck ran, slight mileage increase and more throttle response.
Separate note, recently, I had to replace mt drive by wire throttle body because it kept putting on the CEL with a TPS code. Again, the truck runs a little nicer.
I've always wondered if sensors got lazy with age, like they're not throwing a code but they're not as sharp as when they are new. It certainly seems that way to me.
Page 1 of 3 1 2 3
