Planes, smoke, pyrotechnics and lasers
by Shannow. 03/26/19 08:55 AM
Rust paint that works? Canada
by nobb. 03/26/19 07:19 AM
Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
bgm6881, machv5, freewayken, JustMatt, DCDMan
67626 Registered Users
88 registered members (aquariuscsm, AdditiveOCD, 2015_PSD, 209paulc, 64bawagon, Alfred_B, 10 invisible), 1,629 guests, and 66 spiders.
Topics286,445
Posts4,908,419
Members67,626
Most Online2,967
Mar 10th, 2019
Running the same Brand type weight oil consitantly #4651998
01/31/18 12:45 PM
01/31/18 12:45 PM
Georgia
jgscott Offline OP
jgscott  Offline OP
Georgia
So I have always felt that I wanted to stay with the same Oil (same brand, type, weight) throughout the life of the car, if it is continually made. For example my 02 Lincoln LS Sport V8 has only had Ford Motorcraft sys blend 5w-20 all 258k miles with Zero engine problems to date.
Without any tested scientific proof just had the feeling that the wear would be consistent, and the fact that Advanced and Auto Zone normally had it on sale about $22 including the Ford Motorcraft filter.
I noticed lots here switch oils alot and also recommend whatever is on sale or best price. I have at times over the last 2 years thought about switching to a full sys oil in the Lincoln that Lincoln specifies a blend in knowing it wouldn't hurt, but thought at this point that Motorcraft Blend did its job. Over last 3 years I have changed it myself every 3500 - 4000 miles, beings its only $22 incl the ord filter.
With that what are the thoughts about any advantage in using the same good oil entire life of car, on any car? Thanks
*13'Lex ES350 92k/Fram US & Pennzoil Ul HM 0w-20
*06'Honda Civ Cpe 230k/Honda & Honda 5w-20 Blend
*02 Linc LS Sport V8 241k/Ford & Ford 5w-20 Blend
Re: Running the same Brand type weight oil consitantly [Re: jgscott] #4652018
01/31/18 01:02 PM
01/31/18 01:02 PM
East Tennessee
Starman2112 Offline
Starman2112  Offline
East Tennessee
You’ll get differing opinions on this but here’s mine. I always stick with the viscosity and specs recommended by the manufacturer for the life of the vehicle. However, I’ve had no issues with switching between brands and dino/syn-blend/full synthetic oils.
2018 Toyota Tacoma SR5 / Mobil 1 AFE 0W-20 / OEM filter
2010 Toyota Camry LE / Mobil 1 AFE 0W-20 / OEM filter
1998 Nissan Frontier XE / Castrol GTX HM 5W-30 / M1 filter
Re: Running the same Brand type weight oil consitantly [Re: Starman2112] #4652033
01/31/18 01:11 PM
01/31/18 01:11 PM
Cali
Malo83 Offline
Malo83  Offline
Cali
I have used nothing but Pennzoil in all my cars for the last 45 yrs, whatever the mfg recommends is what i put in, i have no need to impulse buy whatever oil is on sale or mix various oil weights thinking i'm gonna get that magic blend. cheers
Re: Running the same Brand type weight oil consitantly [Re: jgscott] #4652034
01/31/18 01:12 PM
01/31/18 01:12 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
I had a 2001 Ford Taurus that I got over 215k on. The torque converter went bad and I didn't feel like fixing it as the car wasn't worth it. The engine was fine though. Used all different sorts of oils over the 12 years that I had it. Motorcraft, Mobil, Shell, whatever Jiffy Lube had, and whatever oil was on sale. Even did some 5w30 sometime as it was on sale/free after rebate. I normally did 5k oil changes, but occasionally let it go to 8k. As long as you change the oil on a regular basis and use oil that meets spec, it doesn't matter what oil you use. Sticking to one type is somewhat OCD.
Re: Running the same Brand type weight oil consitantly [Re: jgscott] #4652042
01/31/18 01:17 PM
01/31/18 01:17 PM
PimTac Offline
PimTac  Offline
I have pretty much stuck with one brand throughout the life of my cars. The idea of buying the cheapest oil on sale at the moment is fine but it’s actually easier for me to stay with one brand and focus on sales of that brand when they happen.
It’s the same theory as going to one store for all your shopping vs going to one store for cheaper produce and another for their meat and so on.
Cannot see signatures any longer so it doesn’t matter.
Re: Running the same Brand type weight oil consitantly [Re: jgscott] #4652045
01/31/18 01:19 PM
01/31/18 01:19 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
A lot of opinions will follow.
Mine, well, so long as you are using an oil with the correct spec's for the vehicle and changing on a regular basis, brand really will make no difference.
Your Lincoln, while having only Motorcraft branded oil has had several different oils run through it, since you started on SL (possibly SJ oil) and are now on SN. Really different oil than what you started on.
Some talk of additive clash, but I have not seen any hard evidence of issues with it.
I am a "use what is cheapest" oil guy. Why spend $22 on an oil change when you can get it for $10 (or less).
The last oil change I did I was paid $1 ($9 clearance QSUD jug, had a $10 rebate, had a filter given to me).
Using a different oil (or same oil) each oil change really will make no difference. It may make you feel good inside, but your engine won't care.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: Running the same Brand type weight oil consitantly [Re: jgscott] #4652053
01/31/18 01:24 PM
01/31/18 01:24 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
I purposefully change it up every single oil change, just for the heck of it. For the most part, IMO, oil is oil, I figured I might as well keep it interesting and try something new each time. I only use clearance oil and have a decent stash so it isnt hard to come up with a new combo.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Running the same Brand type weight oil consitantly [Re: jgscott] #4652066
01/31/18 01:40 PM
01/31/18 01:40 PM
Indiana
Indydriver Offline
Indydriver  Offline
Indiana
Despite the endless hours of discussion here, experience teaches that as long as you’ve got something on the dipstick, your street car will live a long life.
2014 Camaro 2SS/RS LS3 Vert 14,000 M1
2012 Sienna 85,000 M1
2007 Tahoe 155,000 M1
Re: Running the same Brand type weight oil consitantly [Re: jgscott] #4652073
01/31/18 01:48 PM
01/31/18 01:48 PM
Guilford, CT
exranger06 Offline
exranger06  Offline
Guilford, CT
Oil formulations change. New API specs are introduced every few years, etc. So even if you use the same brand/type of oil for years, that oil probably isn't the same oil it was 6 or 7 years ago.
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: Running the same Brand type weight oil consitantly [Re: jgscott] #4652178
01/31/18 03:39 PM
01/31/18 03:39 PM
Oklahoma
Schmoe Offline
Schmoe  Offline
Oklahoma
After a few years of oil sampling, I've stayed with one brand that has always given me the best results and didn't look back, that is all things M1 EP. Run all my cars out to about 14K and then change it. Even my smaller engines and boat motor gets M1. Got burned out reading about this oil does that, this oil does this....just use M1 for everything. Heck, I even put it on my door hinges in the house if they start squeaking!!! Good for 15k open and shuts!!!!
01 Supercrew Lariat 4X4
06 Accord EX-L V6
14 CRV EX-L (RIP) 2018 CRV EX-L
Re: Running the same Brand type weight oil consitantly [Re: PimTac] #4652273
01/31/18 04:58 PM
01/31/18 04:58 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
People that switch brands are probably looking to save a few bucks.
If you're Happy with one brand of oil, that's fine too.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Running the same Brand type weight oil consitantly [Re: jgscott] #4652304
01/31/18 05:21 PM
01/31/18 05:21 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Oil is oil but I would keep on what works well for you.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Running the same Brand type weight oil consitantly [Re: jgscott] #4652316
01/31/18 05:32 PM
01/31/18 05:32 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
You've reached 258,000 miles. What is your ultimate goal? I'd stick with the syn blend and use this as a shining example that everyone is too OCD about their oil. Not only are you not using a full synthetic oil, you are using a 5W-20 which is blasphemy to the high vis guys. Notice how OCD (Obsessive Compulsive Disorder) and OCI (Oil Change Interval) have almost the same letters.
I am cheering for you. Take it to 500,000 miles and send us a note!
SF
If you want the job done right......do it yourself.
Re: Running the same Brand type weight oil consitantly [Re: jgscott] #4652329
01/31/18 05:46 PM
01/31/18 05:46 PM
MA.
Camprunner Offline
Camprunner  Offline
MA.
Many years ago when I was selling office equipment I was selling the owner of a rather large construction company that owned lots of heavy equipment from dozers, backhoes, dump trucks, etc inc a fleet of Chevy pick up trucks. I asked him what oil do you use in all the equipment? He told me it's interesting you should ask we just finished with a five year study on motor oil testing sending many samples for oil analysis over a long time. He said long story short we noticed little wear difference in the group of vehicles that we switched oil brands with and little difference between running synthetic vs conventional oil. He did say that one set of vehicles that showed the lowest wear after tear down was running one specific oil its entire life..... However he said the difference in wear was never significant. He said think of it this way picture an Olympic size swimming pool now throw in a cup of red dye has the water changed in color much? No! Nothing you could notice. That's what the wear difference amounted to it is just insignificant.
Re: Running the same Brand type weight oil consitantly [Re: jgscott] #4652343
01/31/18 06:14 PM
01/31/18 06:14 PM
SD
zrxkawboy Offline
zrxkawboy  Offline
SD
Thanks for sharing this story again Camprunner! As I read this thread earlier, I remembered your story (in general), but couldn't remember enough of the details. I'm glad you filled in the details for me.
"Think of all the Ford owners who will someday want an automobile." John Dodge
