Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
104 registered members (avi1777, anndel, ArrestMeRedZ, Arminius, 2012AccentSE, albenjoseph, 12 invisible), 2,007 guests, and 52 spiders.
Topics286,149
Posts4,903,027
Members67,565
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Change trans fluid? If so, how and with what? #4651894
01/31/18 10:49 AM
01/31/18 10:49 AM
WI
HoosierJeeper Offline OP
WI
Embarrassingly enough, I haven't changed the trans fluid in my Land Rover LR3. It has a ZF6HP (I think that's the name, it's a 6 speed ZF auto). Up until recently, it was thought to be a lifetime fill, so I never thought about it. Now Land Rover and ZF have changed their tune. I have 160k miles on it and it shifts perfectly, I sense no issues with it. I have a 2000 mile round trip coming up in mid March and was wondering if I should change it, and if so, would it be too risky to change before a trip? Should I do a pan drop or full flush? I was planning on sticking with OEM fluid, but open to other ideas.
Thanks!
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Change trans fluid? If so, how and with what? [Re: HoosierJeeper] #4651907
01/31/18 10:58 AM
01/31/18 10:58 AM
Wisconsin
wallyuwl Offline
wallyuwl  Offline
Wisconsin
I just changed mine for the first time (GMC Envoy) by taking off one of the cooler lines and attaching a clear hose. You have a 5 gallon bucket to let the fluid from the hose run into, let the vehicle run until the fluid starts sputtering. Shut the vehicle off. Put in 3-4 quarts of trans fluid, start vehicle again until it starts sputtering fluid. Then you turn the vehicle on and start filling fluid into the top fill until it is nice and red coming out of the hose into the bucket. When this happens, turn the vehicle off, reattach the cooler line, and then fill to the proper fluid level.
Works a lot better with two people, so one can watch the bucket/hose and start/stop the vehicle, while the other one fills.
Re: Change trans fluid? If so, how and with what? [Re: HoosierJeeper] #4651909
01/31/18 10:59 AM
01/31/18 10:59 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
See what it takes to change the filter. Clean oil is happy oil.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Change trans fluid? If so, how and with what? [Re: HoosierJeeper] #4651912
01/31/18 10:59 AM
01/31/18 10:59 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I would do a pan drop, clean, replace filter and do a line off fluid exchange with Amsoil ATF.
2cents
Re: Change trans fluid? If so, how and with what? [Re: HoosierJeeper] #4651916
01/31/18 11:01 AM
01/31/18 11:01 AM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
At that mileage, I think a complete exchange is in order with filter replacements as well
I would imagine the ATF looks like an old 10W30 engine oil by now.
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Change trans fluid? If so, how and with what? [Re: HoosierJeeper] #4651917
01/31/18 11:02 AM
01/31/18 11:02 AM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Vote to wait until after the trip.
And then I also vote to do a series of drain and fills. No cooler line exchange.
Re: Change trans fluid? If so, how and with what? [Re: Reddy45] #4651929
01/31/18 11:07 AM
01/31/18 11:07 AM
Trav Offline
Trav  Offline
What your reasoning for this?
Re: Change trans fluid? If so, how and with what? [Re: HoosierJeeper] #4651930
01/31/18 11:07 AM
01/31/18 11:07 AM
Michigan
Little_Lebowski Offline
Michigan
Re: Change trans fluid? If so, how and with what? [Re: HoosierJeeper] #4651958
01/31/18 11:49 AM
01/31/18 11:49 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Dex VI + Lubegard Platinum.
Awesome in my ZF 6HP.
"Zed's dead baby, Zed's dead."
Re: Change trans fluid? If so, how and with what? [Re: HoosierJeeper] #4651992
01/31/18 12:37 PM
01/31/18 12:37 PM
Canada
i_hate_autofraud Offline
Canada
Look into dropping the pan and changing the filter too! ATF usually stays pink or red for life
unless something terrible is happening. ATF is not supposed to get visibly dirty like engine oil.
ATF picks up lots of super tiny wear metals that are only partially picked up by the OEM pan magnet,
so swapping out the fluid helps. In my case I put extra magnets in the pan since GM admitted in a TSB
that the OEM magnet was inadequate. Key thing is to make sure there's enough clearance.
However, I'd avoid a 'flush' since this can stir up particles that settled in the tranny, at 160K,
I would not do it. Do a google search for "ZF6HP transmission problems" and see what other people say.
Re: Change trans fluid? If so, how and with what? [Re: HoosierJeeper] #4651993
01/31/18 12:39 PM
01/31/18 12:39 PM
America
Alfred_B Offline
Alfred_B  Offline
America
Wait until after the trip.
If you really want to change it, I would recommend to drop the pan and do a filter replacement and use ZF fluid. I wouldn't use Amsoil or some other non-OEM fluid.
Re: Change trans fluid? If so, how and with what? [Re: HoosierJeeper] #4652027
01/31/18 01:08 PM
01/31/18 01:08 PM
Wisconsin
wallyuwl Offline
wallyuwl  Offline
Wisconsin
Yeah, at that mileage do a filter change, too. It will be pretty easy once you get most of the fluid out through the cooler line. I should have also suggested that.
Re: Change trans fluid? If so, how and with what? [Re: HoosierJeeper] #4652030
01/31/18 01:09 PM
01/31/18 01:09 PM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
Thanks!
A cooler line ATF exchange provides the best exchange of fluid using only a tiny bit more ATF than the transmission holds. Way to go if you use expensive ATF. Look at Amsoil. Its the only ATF I have used in many years.
If your vehicle has a filter than can be changed or wiped clean that should be done and will probably require the pan to be dropped. Not a bad idea as you can wipe the crud from the pan.
Then there is probably a transfer case and front and rear diff. They should be serviced also. But the transmission is the priority.
Do not believe any shop who says that they add a cleaner to the ATF, run it for 20 minutes and then do a flush and the process cleans the transmission filter. It does not.
2015 Ford F250 w/Powerstroke
Re: Change trans fluid? If so, how and with what? [Re: HoosierJeeper] #4652049
01/31/18 01:21 PM
01/31/18 01:21 PM
California
nthach Offline
nthach  Offline
California
A few ZF parts distributors sell a kit with 6-8 quarts of ZF LifeGuard 6(which Ford also uses as Mercon SP and cheaper too if MaxLife or Amsoil ain't your thing), a new pan/filter assembly along with the gaskets bolts and maybe a new mechatronic seal as well.
http://www.thectsc.com/products/oil-chan...yce-186-61.html
Re: Change trans fluid? If so, how and with what? [Re: HoosierJeeper] #4652071
01/31/18 01:45 PM
01/31/18 01:45 PM
WI
WI
Thanks everyone for the tips. I think I'm settled on using ZF fluid and will definitely replace the filter. I'm leaning towards doing a pan drop for now and then a full flush later. Do you think that will minimize the risk of creating an issue or do you think either way it'll be safe?
Page 1 of 3 1 2 3
