Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
06/23/18 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
06/23/18 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
06/23/18 04:30 PM
mobil 1 rebate check
by Fitter30
06/23/18 03:52 PM
Cab mount failure
by ram_man
06/23/18 03:31 PM
02 Saab aero oil?
by Newuser
06/23/18 03:00 PM
Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
13 Ford Escape
by RedOak
06/23/18 01:10 PM
New washer pump leaking fluid
by llmercll
06/23/18 12:17 PM
Fuel dilution and CCS/MRV viscosity
by doyall
06/23/18 12:10 PM
Door Hinges
by Scrum67
06/23/18 11:59 AM
PBS, TV channels in different countries
by onetwoothreee
06/23/18 11:29 AM
Break in filter cut open/ Filtermag
by UncleDave
06/23/18 10:36 AM
Changed coil pack, now throwing cat code
by llmercll
06/23/18 10:36 AM
07 V6 Mustang oil leak.
by aquariuscsm
06/23/18 10:33 AM
Windows 10 Update, version 1803
by Sayjac
06/23/18 09:55 AM
Super Tech Euro Spec Synthetic
by Snagglefoot
06/23/18 09:48 AM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
90 registered (71Chevyguy, 2015_PSD, 928, 1JZ_E46, 14Accent, 9 invisible), 1589 Guests and 41 Spiders online.
65303 Members
67 Forums
285861 Topics
#4651630 - 01/30/18 10:38 PM Valvoline Modern Engine PDS now up.
PimTac Offline
Loc: Soviet State of Washington
Valvoline has updated their website to show the PDS for VME. A few days ago they put up the info for VAS.
https://sharena21.springcm.com/Public/Do...12-ac162d889bd1
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
#4651650 - 01/30/18 11:36 PM Re: Valvoline Modern Engine PDS now up. [Re: PimTac]
bbhero Offline
Loc: Virginia
Good find my friend.
I like the NOACK of 11 percent. Interesting how both Zn and phos are 850 and 800. Kinematic viscosity is within range but the low end of it for a 30 grade at 9.8. Hey the 5w20 is at 9... Interesting. Wonder what the HTHS is?? I'd bet it's right at 3.0. Which is fine obviously. Just hope this stuff stays strong and in grade throughout an entire run. I would bet it does.
Though I just got some Valvoline white bottle for my next run. However, I also have 5 qts of the Valvoline Modern Engine 5w30 as well after that.
Nissan Altima 3.5 Coupe Valvoline Advanced Full Synthetic 5w30 Federated Auto 4612ex
"Treat your family like your friends and treat your friends like your family."
#4651660 - 01/31/18 12:06 AM Re: Valvoline Modern Engine PDS now up. [Re: PimTac]
wemay Offline
Loc: Southeast Florida
Thank PimTac
For the price. I'd just stick with VFS.
2017 Hyundai Sonata Sport 2.4L
2013 Hyundai Santa Fe Sport 2.0T
Valvoline
#4651663 - 01/31/18 12:27 AM Re: Valvoline Modern Engine PDS now up. [Re: PimTac]
PimTac Offline
I am already planning to run VAS for the remainder of this year but if I see a good price on VME I will consider it. Valvoline is a bit weak on their marketing here. They difference between these two oils is not clearly defined. That will not stop me from using it either.
Im glad to see that their conventional oil is still in a white bottle although the name is now Daily Protection which really makes no sense whatsoever. Still a good oil.
#4651671 - 01/31/18 12:46 AM Re: Valvoline Modern Engine PDS now up. [Re: wemay]
bbhero Offline
Loc: Virginia
Ya know Wemay AZ has both Valvoline Advanced full synthetic and Valvoline Modern Engine for $26.99 with the STP XL filter. Fairly decent deal there. The Valvoline Modern Engine is $44.97 vs $37.97 for the Valvoline Advanced full synthetic. But they both are the same for that $26.99 deal. Makes me wonder if and when it shows up in Wally World what the price will be?? I'm guessing $29.97 for 5 qt container.
PimTac I think Valvoline took the overseas name for VWB and brought it here to the US. But I can't say for sure. I do like a simple oil like this has well. No need to shot for the stars all the time smile
#4651698 - 01/31/18 03:20 AM Re: Valvoline Modern Engine PDS now up. [Re: PimTac]
wemay Offline
If that were the price here, I'd be all over it. But i passed by Advanced and AZ today and it was still $44 with no filter. But I'm sure it will vomr fown a bit. I wonder if it may show up at Wal-Mart too.
Valvoline
#4651711 - 01/31/18 04:27 AM Re: Valvoline Modern Engine PDS now up. [Re: PimTac]
peejaycruiser Offline
Loc: NSW Australia
Just been looking at the PDS for the aussie supplied Synpower 5W-40 that I'm currently running and it's changed. The PDS from 2013 has changed from
FM Effective 1-04-2013
Performance Levels/Approvals
API SN /CF
ACEA A3/B4
Meets requirements of:
BMW LL-01
MB 229.3
GM-LL-B-025
VW 502.00, 505.00
Renault RN700, RN710
SynPower 5W-40
SAE Viscosity Grade 5W-40
Viscosity @ 100 C, mm2/s, ASTM D445 13.6
Viscosity @ 40 C, mm2/s, ASTM D445 81
Viscosity Index, ASTM D2270 173
CCS Viscosity @ -30 C, mPa.s, ASTM D5293 5400
Density @ 15C, kg/L, ASTM D4052 0.853
Flash Point (COC), C, ASTM D92 236
Pour Point, C, ASTM D5950 -42
TBN, mg KOH/g, ASTM D2896 10.5
Noack, %mass, ASTM D5800 11.4
to
FM Effective 03--07-2017
SynpowerTM SAE 5W-40*
SAE 5W-40
API SN/CF
ACEA A3/B4
MB 229.3
GM-LL-B-025
VW 502.00/ 505.00
Renault RN710, RN700
SynPowerTM SAE 5W-40 Typical
Viscosity @ 100 C, mm2/s, ASTM D445 14.2
Viscosity @ 40 C, mm2/s, ASTM D445 85.0
Total Base Number, mg KOH/g, ASTM D2896 10.0
CCS Viscosity, mPa.s @ 30C, ASTM D5293 5700
Flash Point (COC), C, ASTM D92 226
Pour Point, C, ASTM D5950 -39
It's now 0.6 thicker at 100c TBN has dropped 0.5 and pour point dropped 3 dg and lost LL-01. Seems to be a case of swings and roundabouts as far as whether it's now better or worse. I don't know whether we will get a rename or will stay as Synpower.
02 Subaru Liberty RX 2.5 Synpower 5W-40 OEM Filter
96 Toyota 80 Series 1HZ Sakura C-1112 Nulon High Torque 15w-40
#4652263 - 01/31/18 03:50 PM Re: Valvoline Modern Engine PDS now up. [Re: wemay]
car51 Online   content
Loc: Southwest PA
Originally Posted By: wemay
Thank PimTac
Wemay: couldn't have stated it any better smile
2009 Toyota Camry LE
#4652559 - 01/31/18 08:18 PM Re: Valvoline Modern Engine PDS now up. [Re: PimTac]
benjy Offline
Loc: pa
didn't think a noack above 10 was so great + with Pennzoils typical lack of HTHS me thinks they are hiding a lesser spec!!
#4652615 - 01/31/18 08:56 PM Re: Valvoline Modern Engine PDS now up. [Re: benjy]
Garak Offline
Loc: Regina, Saskatchewan, Canada
ILSAC 30 grades aren't exactly hiding HTHS. You can guess the HTHS within 0.1 99% of the time. With a 40 grade European, you're not going to find a huge variation above or below 3.7, either.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
