Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
67 registered members (AndyB, Astro_Guy, avi1777, alarmguy, 69Torino, 2015_PSD, 5 invisible), 793 guests, and 53 spiders.
Topics286,105
Posts4,902,667
Members67,563
Most Online2,967
Mar 10th, 2019
'88 GMC from some guy's backyard #4651469
01/30/18 07:44 PM
01/30/18 07:44 PM
South Carolina
eyeofthetiger Offline OP
South Carolina
It was almost exactly one year ago that I got this barely running pile of truck out of some guy's backyard. I actually drove it 30 miles home, despite having no TV cable, a broken accessory drive bracket, no exhaust system, and an engine that would idle fine but wouldn't do much else other than smoke.
The original window sticker was folded up with the owner's manual. It suggests that it has lived its entire life in and around this town. Old registrations show that the first owner was a paper comapny for at least the first ten years of its life. The odometer reads 109K, and I almost believe it, but it doesn't really matter.
It passed to at least two other owners before I got it, and they negleted it pretty badly.
For example, these are the U-bolts that were holding the rear axle on:
I have worked on it nearly every weekend, and it is finally what I would say is mechanically sound and reliable. The major components were okay, but nearly every sensor, electrical circuit, and fluid needed attention. Everything on the TBI unit, the fuel pump, and the entire steering linkage was bad.
Now that it is reliable, I have finally been able to work on other things, such as throwing a mini-spool in the rear end and painting it red (very important). I also threw on some 1.5" lift blocks when I replaced the scary U-bolts, and leveled the front torsion bars to match. Nothing crazy here.
It is a truck for the woods. I have several acres of wooded land that need work, and this is the land truck. I need it to be reliable and not get stuck in the mud out there. Next on the list is finishing the exhaust system with a complete tailpipe, a new set of mud tires on a second set of freshly painted steel wheels, and a new tool box for the bed. Believe it or not, I even did an R134a conversion and had the A/C working, but then it all leaked out the front compressor seal. So it will get a new compressor before this summer. Land truck. cool
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: '88 GMC from some guy's backyard [Re: eyeofthetiger] #4651475
01/30/18 07:51 PM
01/30/18 07:51 PM
WI
HoosierJeeper Offline
WI
That's awesome! That's a real truck. Glad to see it get another lease on life, keep posting pics please!
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: '88 GMC from some guy's backyard [Re: eyeofthetiger] #4651491
01/30/18 08:08 PM
01/30/18 08:08 PM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
That body style is a future classic. Very clean. Love the short bed and 4WD.
Perfect candidate for a junkyard LS/LQ swap... wink
Re: '88 GMC from some guy's backyard [Re: eyeofthetiger] #4651565
01/30/18 09:42 PM
01/30/18 09:42 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Tall skinny tires that can dig down through a mud layer to find traction laugh Naturals on that truck (16" rims right?).
Now that you have three wheeled drive any time you want it, it should not get stuck (much) ... Mud is afraid of red dif covers laugh
I like tool boxes along the sides over the wheel wells. Easy to load the heavy stuff like cables and chains in the rear of the box where they do the most to help keep going smile
Also like good D rings on both bumpers and plenty of hitch options. I like Hidden Hitch brand receivers because they are tucked in pretty well and don't get hung up on as much laugh smile
Re: '88 GMC from some guy's backyard [Re: Bottom_Feeder] #4651571
01/30/18 09:47 PM
01/30/18 09:47 PM
South Carolina
South Carolina
If the 4.3 ever gives up, of course it will be replaced by a V8. But which one? Anything could happen. Junkyard LS motors are pretty cheap these days. grin
Re: '88 GMC from some guy's backyard [Re: BrocLuno] #4651575
01/30/18 09:51 PM
01/30/18 09:51 PM
South Carolina
South Carolina
I already got the tool box. It's a big jobsite box, so not easy to get into from the ground. I was playing around with the idea of building a flatbed, but that is a long way off. I'll wait until at least one more bed mount rots off.
Bumpers? It only has a front bumper. Were rear bumpers optional in '88? It's not on the window sticker. But it has a good rear hitch receiver.
As for tires, I was considering LT235/85R16. Tall and skinny.
Re: '88 GMC from some guy's backyard [Re: eyeofthetiger] #4651655
01/31/18 12:56 AM
01/31/18 12:56 AM
Michigan
daves87rs Offline
daves87rs  Offline
Michigan
Very cool!
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
Re: '88 GMC from some guy's backyard [Re: eyeofthetiger] #4651658
01/31/18 01:00 AM
01/31/18 01:00 AM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Originally Posted By: eyeofthetiger
Bumpers? It only has a front bumper. Were rear bumpers optional in '88? It's not on the window sticker. But it has a good rear hitch receiver. .
Lol you're joking right?
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: '88 GMC from some guy's backyard [Re: eyeofthetiger] #4651659
01/31/18 01:01 AM
01/31/18 01:01 AM
WA state, USA
NothingNew Offline
NothingNew  Offline
WA state, USA
The rear bumper was optional in 1988 if it's the same as the Chevrolet pickup. Kind of interesting: https://www.gmheritagecenter.com/docs/gm...rolet-Truck.pdf
Re: '88 GMC from some guy's backyard [Re: Nick1994] #4651679
01/31/18 02:47 AM
01/31/18 02:47 AM
Elizabeth. Colorado
c502cid Offline
c502cid  Offline
Elizabeth. Colorado
Yes they were optional until the late 80's. I sold rear aftermarket step bumpers for pickups from 1985-1989 and thought I was a pretty good salesman until all the manufacturers came out with the steering wheel, tires, and rear bumper package. I wasn't such a good salesman after that...lol
16 Ford F150 2.7 Ecoboost 4x4
15 Chev Trax AWD
02 GMC 3500 8.1/Allison Dually 4x4
00 Blazer 4.3 4x4
97/98 Honda Civics
84 Chev K30 454EFI/T400/NP205 Dually 4x4
71 GMC Jimmy 502 RamJet/T400/NP205 4x4
Re: '88 GMC from some guy's backyard [Re: eyeofthetiger] #4651696
01/31/18 04:14 AM
01/31/18 04:14 AM
Colorado
Chris B. Offline
Chris B.  Offline
Colorado
Awesome truck!!! If you take car of them(which you obviously do) they last forever. Here is mine which is a few years newer and has 85,000 total miles:
Re: '88 GMC from some guy's backyard [Re: Chris B.] #4651756
01/31/18 08:18 AM
01/31/18 08:18 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
The parking ramp in the OP's first photo is what kept that truck alive, I'm told. Parking on bare earth would've prompted rust.
LOVE the $14,000 sticker total.
REALLY LOVE the blue truck's color. Nice stuff both.
Re: '88 GMC from some guy's backyard [Re: eyeofthetiger] #4651846
01/31/18 10:13 AM
01/31/18 10:13 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Just replace the seal yourself .
Wyr
God bless
Re: '88 GMC from some guy's backyard [Re: Chris B.] #4651925
01/31/18 11:05 AM
01/31/18 11:05 AM
South Carolina
South Carolina
I don't know if mine will ever look that clean again, but I will at least keep it running well.
Re: '88 GMC from some guy's backyard [Re: WyrTwister] #4651938
01/31/18 11:13 AM
01/31/18 11:13 AM
South Carolina
South Carolina
The compressor seal? Well, that's not the only thing wrong with it. The clutch is sticky and the pulley bearing is rough. If I get that deep into it, I'll probably end up tearing the whole thing apart. Maybe I can save it and do a rebuild on it later, but a new compressor is about $150.
