Originally Posted By: panthermike
Doesn't that TSB say to use 10w40 IIRC? I might even use 5w30 in my brother's 5.4 F150 now since it's out of warranty. It consumes some oil on 5w20 and has a slight cam phaser noise. I figure it's worth a try. Plus, we live in Phoenix, climate isn't as much of a factor here.
Yep, it recommends 10W-40 to address cam phaser noise.
As far as 10W-30 causing cam phaser problems, would FORD recommend 10W-40 IF it caused "problems" with the cam phasers? I don't think so.
The Modulars just aren't that sensitive to oil, all statements that say 5W-20 MUST be used or you will experience problems are simply wrong.
10W-30 is also recommended for use in 3V Modulars in some markets outside of the US, I guess everywhere this happens we can expect all 3Vs to self destruct due to the manufacturer viscosity recommendation.
