Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
104 registered members (2015_PSD, Anduril, Astro14, Avelectro, b1amgm47, ABCarr, 12 invisible), 2,186 guests, and 28 spiders.
Topics287,749
Posts4,933,778
Members67,850
Most Online2,967
Mar 10th, 2019
heat pump system question #4650969
01/30/18 10:58 AM
01/30/18 10:58 AM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
Is the condenser outside supposed to run the whole time the system is on? I've never seen mine turn on it's always the neighbors. I've always lived in houses with a gas furnace, so I'm not familiar with how an electric one works. I did read somewhere that instead of the condenser removing heat like in the summer that it reverses and puts heat back in. At first I thought the neighbor had the air conditioner on when it was like 35 degrees outside. lol
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: heat pump system question [Re: motor_oil_madman] #4650981
01/30/18 11:07 AM
01/30/18 11:07 AM
The land of USA-made Subies!
SubieRubyRoo Offline
It shouldn't run all the time, but yes, that is the method. It "moves" heat through the refrigerant into the house in the winter, and out of the house in the summer. As long as the outdoor temp is above the min temp of the system (generally 5*F, more or less), the heat pump can typically be more energy-efficient than a gas or electric furnace. It's all about the COP (coefficient of performance) at the outside temps that should drive the decision on what heat source to use.
Re: heat pump system question [Re: motor_oil_madman] #4650996
01/30/18 11:16 AM
01/30/18 11:16 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
I would hesitate to say a heat pump is more efficient(cost effective really) than a natural gas furnace.
Now vs propane.. way better.
In my experience heat pump can easily be 3:1 or more efficient than electric heating.
Heat pump is very nice for warmer climates.
Not so nice if you have to turn on aux. oil or electric heat.
Re: heat pump system question [Re: motor_oil_madman] #4651002
01/30/18 11:22 AM
01/30/18 11:22 AM
Houston, Texas
Houston, Texas
I guess it's a heat pump system. I have central ac, just thought it was weird at first when the outside ac units were running in the winter. I never really researched it.
Re: heat pump system question [Re: motor_oil_madman] #4651021
01/30/18 11:49 AM
01/30/18 11:49 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
At one time , dual fuel HP's were available that used a gas fires furnace as emergency / auxiliary heat .
This might be the best of both worlds if you have gas available .
Not sure of the cost of propane vs the cost of electric resistance heat ?
If you live in a climate where it rarely gets below , say , 25F , a HP would be worth considering .
Wyr
God bless
Re: heat pump system question [Re: motor_oil_madman] #4651025
01/30/18 11:51 AM
01/30/18 11:51 AM
Phoenix, AZ
azjake Offline
azjake  Offline
Phoenix, AZ
It depends on your system. I have a heatpump with an electric heat strip in the air handler unit so the condenser does NOT turn on for heat. My previous home did not have the heat strip so the condenser did turn on for heat.
The reason why the electric strip is better is at or below freezing the fins in the outside unit can develop frost and the unit has to go through a defrost cycle before it can function and produce heat. The tech who installed my current system said the one or two times a winter here in Phoenix when it dips below freezing they get swamped with calls from customers who complain they are not getting heat. This is why the systems they install now all have the heat strip.
2015 Nissan Murano SL
Re: heat pump system question [Re: motor_oil_madman] #4651050
01/30/18 12:20 PM
01/30/18 12:20 PM
Houston, Texas
Houston, Texas
The one thing I can't figure out is how to switch it over to a.c. mode. If that's the case I want to run the air conditioner periodically to keep everything lubed up.
Re: heat pump system question [Re: motor_oil_madman] #4651053
01/30/18 12:22 PM
01/30/18 12:22 PM
Houston, Texas
Houston, Texas
I remember times where I was younger and my dad turned the a.c. on for the first time in 6 months and it sounded like the fan motor was seized up for a moment outside.
Re: heat pump system question [Re: motor_oil_madman] #4651093
01/30/18 01:17 PM
01/30/18 01:17 PM
Peace valley, Missouri
Fitter30 Offline
Fitter30  Offline
You do not want to run as in the winter unless its above 70*. Heat pumps are ok to run in heating that's what their made for. In cooling the pressures that they run in cooling will trash the compressor unless the unit is set up for low ambient temps. On your thermostat it will have a heat, cool and emergency heat setting if it's a heat pump. Look at you tube videos under heat pump operation.
Re: heat pump system question [Re: azjake] #4651097
01/30/18 01:18 PM
01/30/18 01:18 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
The heat pumps go backwards in defrost mode (back to being an A/C) to deal with the frost. They use the electric coils to warm the air in that mode so you do not get cold air into the house during defrost.
2015 Ford F250 w/Powerstroke
Re: heat pump system question [Re: motor_oil_madman] #4651104
01/30/18 01:22 PM
01/30/18 01:22 PM
Indiana
5AcresAndAFool Offline
Indiana
It all depends on how its set up. If you have natural gas it is unlikely IMHO a heat pump is worth it since natural gas is cheaper than dirt right now. A heat pump may be more efficient than a natural gas furnace at warmer temps, say above 40, but not necessarily cheaper.
Some heat pumps are set up to lock out under a certain temperature.
Now we Have either electric or propane as our heating choices.
We have a higher efficiency heat pump, It makes sense to run ours to -10F due to the efficiency of the unit, and our use of costly electric heat strips as backup.
So if its over -10f and the thermostat is calling for heat, the outside unit is running. When the unit goes into defrost mode, the outside units fan shuts off and the compressor continues to run. (basically it reverts back to being an air conditioning unit, it will remove heat from the house to warm and defrost the outside coils).
On our unit it will not defrost when the outside temperature is over 50F because it is not needed.
Now the heat strips will kick on when the unit goes into defrost (otherwise you would have cold air blowing out of your registers) OR when the heat pump cannot keep up due to the outside temperature being lower. This is called the balance point.
Our balance point is roughly 25F. Anything lower than that supplemental heat is required. It Depends on the wind, if we have basement registers open ect.
Now you can put your thermostat in "emergency heat" mode. Basically this turns off the outside unit, no matter the conditions, and will strictly run your heat strips in the furnace, or propane/gas burner. This is intended if you have an issue with your outside unit.
Heat from a heat pump is very efficient. You are not burning any fuel to create heat when just the heat pump is running, you are just paying to move the heat indoors.
Like I tell my wife, our heat is free, we just have to pay to get it in the house.
Re: heat pump system question [Re: motor_oil_madman] #4651109
01/30/18 01:29 PM
01/30/18 01:29 PM
Canuck living in California
KrisZ Online content
KrisZ  Online Content
Unlike automotive AC systems, home AC units should not be run in winter and there is nothing to lube up. The risk to zero reword is quite great.
Heat pumps have heated compressors, that's why they can operate in winter.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: heat pump system question [Re: motor_oil_madman] #4651119
01/30/18 01:34 PM
01/30/18 01:34 PM
Indiana
Indiana
I will add that since I do not want the heat strips to kick on unless absolutely necessary, and I dont care if we get cold air during defrost mode, that I have made changes to the control scheme of the heat strips.
Not many people would do this, But I am a special kind as my wife tells me...
But she admits it has saved us alot. We ran one winter on the factory control scheme, and after my modifications, it saved us rough 25%, at the slight expense of comfort, but not really that noticeable.
Re: heat pump system question [Re: motor_oil_madman] #4651130
01/30/18 01:45 PM
01/30/18 01:45 PM
North TEXAS
oldoak2000 Offline
oldoak2000  Offline
North TEXAS
Yes, a heatpump will run loonger as temps drop.
The compressor will actually use FEWER amps at lower temps - most don't realize this.
Inside the compressor, all the moving parts are bathed in oil, so there is technically no additional wear for long run times - fan motors however will eventually wear with long run times . . .
Re: heat pump system question [Re: oldoak2000] #4651158
01/30/18 02:27 PM
01/30/18 02:27 PM
Indiana
Indiana
Yes, good point!
At 0 degrees out heatpump uses a little under 3 kwh an hour. At 55 degrees that goes up to around 4.5
The compressor does not have to work as hard as the temps cool down because your line pressure also drops.
Ours has run for weeks straight in the winter with no ill effects. Its almost 10 years old.
I LOVE our heatpump.
I was a slave to the woodstove one winter here. Never again.
I took the woodstove off our homeowners and the amount saved on insurance nearly pays for the worst month of heating costs.
