SKF grease with graphite
by PreludeDenarius. 05/24/19 03:42 AM
Quaker State Ultimate Durability 5W-30: $17.97 at WM
by The Critic. 05/24/19 01:31 AM
AT-205 Re-Seal for 1968 VW Bus?
by ZraHamilton. 05/24/19 01:22 AM
Can 5W-30 be Thicker than 10W-30?
by John344. 05/23/19 10:33 PM
Fastenal new policy-unhappy
by rekit. 05/23/19 10:23 PM
0w30 Showdown of European Oils
by Marco620. 05/23/19 10:12 PM
amazon basics 5-40 not as good
by benjy. 05/23/19 09:28 PM
Cost to Repair a Honda V6 Engine that Jumps Time
by The Critic. 05/23/19 09:18 PM
Youtube demonitisation of conspiracy sites ?
by Shannow. 05/23/19 09:15 PM
03 Subaru WRX Valvoline VR1 10/30 196K miles
by TurboJW. 05/23/19 08:43 PM
TT time
by benjy. 05/23/19 08:29 PM
Castrol Nexcel
by JunkdrawerDog. 05/23/19 08:25 PM
1st gen ford focus
by WhyMe. 05/23/19 08:21 PM
Coca-Cola 600
by kstanf150. 05/23/19 07:49 PM
New cell phones and company
by spk2000. 05/23/19 07:24 PM
Swivel Elbow for Garden hose reel
by JC1. 05/23/19 06:57 PM
Garage floor coating
by Eddie. 05/23/19 06:43 PM
Tina70, tongboy1, PersonaPriusDad, MetricMike, Harps
68195 Registered Users
36 registered members (CB900F2, Char Baby, 4WD, 2015_PSD, ctechbob, carviewsonic, 4 invisible), 635 guests, and 21 spiders.
Topics289,326
Posts4,967,019
Members68,195
Most Online2,967
Mar 10th, 2019
02 Chevy Silverado 5.3L heater hoses #4650858
01/30/18 09:05 AM
01/30/18 09:05 AM
CA
Gito Offline OP
Gito  Offline OP
CA
Own a 2002 Chevy Silverado 5.3L (LT) with 345k and need to replace the heater hoses that come off the firewall and travel into the water pump housing area.
Trying to get the part numbers for these two hoses. Called the dealer and they gave me some parts numbers (15792821 and 15763368).
The dealer used my vin but when I try to populate the hoses suing the GMpartcenter website, the part shows a different hose and it shows that it doesn't fit my car. So either the dealer gave me the wrong part number or I wrote the part number incorrectly.
Vin# ends with 21132497
Any advice is greatly appreciated
Re: 02 Chevy Silverado 5.3L heater hoses [Re: Gito] #4650869
01/30/18 09:21 AM
01/30/18 09:21 AM
hawthorne, Ca.
46Harry Offline
46Harry  Offline
hawthorne, Ca.
I would recommend buying the hoses from the dealer as you are reasonably assured of getting the correct parts the first time. The dealer will be more expensive, but how often to the hoses get replaced?
Re: 02 Chevy Silverado 5.3L heater hoses [Re: Gito] #4650870
01/30/18 09:22 AM
01/30/18 09:22 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Are they molded or straight? If you go to Gates web site, they list all your hoses.
The "thinking" man's friend.
Re: 02 Chevy Silverado 5.3L heater hoses [Re: Gito] #4650871
01/30/18 09:25 AM
01/30/18 09:25 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
345,000 miles? Tell us a bit about your motor oil. ( and + 1 on 46Harry’s comments).
If you want the job done right......do it yourself.
Re: 02 Chevy Silverado 5.3L heater hoses [Re: Snagglefoot] #4650874
01/30/18 09:37 AM
01/30/18 09:37 AM
wv
krismoriah72 Offline
wv
Rock Auto lists AC Delco, Gates, Dayco and Continental molded hoses for your application.
If you dont like to order online just get the Gates numbers and take them to NAPA.
Re: 02 Chevy Silverado 5.3L heater hoses [Re: Gito] #4650906
01/30/18 10:01 AM
01/30/18 10:01 AM
VA
Rhymingmechanic Offline
VA
I did this on a 2001 5.3 Silverado with Gates hoses, 18914 and 22554.
I also planned to replace the plastic quick-connect fittings at the firewall with Dorman #800-409. I don't know if the originals are different sizes or one of my new parts was faulty, but I could only get one of the new connectors to fit. After most of an afternoon, I gave up and reused one original. I got a little plastic tool from NAPA to remove the fittings.
Re: 02 Chevy Silverado 5.3L heater hoses [Re: Rhymingmechanic] #4650931
01/30/18 10:23 AM
01/30/18 10:23 AM
North Carolina
Rat407 Offline
Rat407  Offline
North Carolina
I replaced mine on my 02 Silverado and got the hoses from Rock Auto. All fit just fine and I also replace the plastic quick connect fittings. I basically changed all my hoses at one time.
2002 Silverado 5.3 0w-20 AMSOIL®
Re: 02 Chevy Silverado 5.3L heater hoses [Re: Snagglefoot] #4650967
01/30/18 10:57 AM
01/30/18 10:57 AM
CA
Gito Offline OP
Gito  Offline OP
CA
Have used Valvoline and Castrol 5w-30 for most of its life. Religiously changed the oil every 3k. Replaced or repaired everything myself. This forum has helped me when I had to tackle something I had never done. Since I replaced the intake manifold the cold misfires when away. Going thru some slow start issues now where it might be pointing towards a new starter. Extremely reliable trucks. We are the original owners and the engine is original meaning it hasn't been opened up.
Re: 02 Chevy Silverado 5.3L heater hoses [Re: Gito] #4651142
01/30/18 01:54 PM
01/30/18 01:54 PM
Specific Ocean
Kibitoshin Offline
Kibitoshin  Offline
Specific Ocean
The WP to heater core hose is just a straight piece of 5/8" heater hose.
The heater core return Y reservoir to water pump can be bought at NAPA which are made by Gates.
You will need new quick disconnect fittings for both the new hoses. I used Dorman QD fittings which is no different than any other black plastic fitting.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: 02 Chevy Silverado 5.3L heater hoses [Re: Kibitoshin] #4651223
01/30/18 03:30 PM
01/30/18 03:30 PM
CA
Gito Offline OP
Gito  Offline OP
CA
Do the dealer hoses come with the quick disconnect fittings?
Re: 02 Chevy Silverado 5.3L heater hoses [Re: Gito] #4651386
01/30/18 05:30 PM
01/30/18 05:30 PM
Specific Ocean
Kibitoshin Offline
Kibitoshin  Offline
Specific Ocean
Haven't checked the dealer when I bought my heater hoses since NAPA carried Gates which are the OEM supplier. Googling the 2 part numbers in the first post shows the dealer parts having the QD fittings.
This is what I did with the NAPA Gates hoses. Hoses don't come preinstalled with the fittings so they need to be bought separately.
Bought everything from NAPA:
Re: 02 Chevy Silverado 5.3L heater hoses [Re: Kibitoshin] #4651985
01/31/18 12:26 PM
01/31/18 12:26 PM
Texas
GMBoy Offline
GMBoy  Offline
Texas
Exactly what I just did last month on my 2006 Sierra Denali. One of the firewall connectors was weeping so it was time and I did both hoses and new Quick connects. All from Rock Auto.
Re: 02 Chevy Silverado 5.3L heater hoses [Re: Gito] #4652666
01/31/18 10:42 PM
01/31/18 10:42 PM
Birmingham, AL
01rangerxl Offline
01rangerxl  Offline
Birmingham, AL
I meant to look up your truck with the catalog at work today but forgot. The part numbers your local dealer gave you look like typical heater hoses for that truck though based on Google image results.
What is the link to the website?
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 229K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 201K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 248K miles
Re: 02 Chevy Silverado 5.3L heater hoses [Re: Gito] #4652735
02/01/18 12:01 AM
02/01/18 12:01 AM
socal
barkingspider Offline
socal
I replaced these hoses on my Escalade. I got oem from a local GM dealer. Later I checked a local pep boys and they had the Gates brand for significantly less expensive. Oh well, no use in crying over spilled milk. The plastic connectors are separate
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: 02 Chevy Silverado 5.3L heater hoses [Re: Gito] #4652765
02/01/18 12:46 AM
02/01/18 12:46 AM
PR CA, USA
2strokeNorthstar Offline
PR CA, USA
Lucky. My BMW 328i heater hose blew @ about 150k.
2001 F150 5.4L 140k miles
2013 Nissan Juke Nismo 80k
2000 Honda S2000 183k
1998 BMW 328i 170k
