Originally Posted by Nyogtha
Another older BITOG post about doing something besides replacing the air filter.
Originally Posted by rrounds
Blowing out a filter is a good way to kill your engine.
Here is Mann filters
https://blog.mann-hummel.com/wp-content/uploads/2014/Mythen/MF_10Mythen_EN_Ansicht_neu.pdf
And this is from CAT, they don't even want you to open the filter housing to insepct it let alone blow air or tap the filter to try to clean it. They say to go by the air filter restriction gauge, nothing else.
Page 24
https://caterpillar.scene7.com/is/content/Caterpillar/C10467200
Just because some one makes something they say is great for air filters doesn't make it great.
I can go to any heavy construction manufacturer and find the same thing on how NOT to clean them or even try to clean them.
Cris142
Don't know what "pulled down a bit" means. My S2000 pulls 0 restriction with the air box lid off but will pull 8"of H2o with the lid on, I just went 90k miles on my last air filter in that car. Doesn't your gauge give you a range of numbers like the Wix gauge? My Wix gauges start a 8 and go to 25" and I change my filters due to time(6 years) or when the restriction gets to 11" or 15" of restriction on my gas engines.
Here is the air box on a S2000, you can see my Restriction gauge on the right side of this pic
ROD
Nygotha, I was recently reading my wife's owner manual and came across this about gently tapping out her air filter. This surprised me, as noted above and in some previous threads, this wasn't recommended.
Needless to say, I was surprised to read this.
I likely won't be tapping it out anyways as when I open up the air box again, it will likely be time to change it anyway (in 2 yrs give or take) but I thought it was interesting reading this in her manual.
How to Inspect the Engine Air
Cleaner/Filter
Do not start the engine or have the
engine running with the engine air
cleaner/filter housing open. Before
removing the engine air cleaner/
filter, make sure that the engine air
cleaner/filter housing and nearby
components are free of dirt and
debris.
Remove the engine air
cleaner/filter. Lightly tap and shake
the engine air cleaner/filter (away
from the vehicle), to release loose
dust and dirt. Inspect the engine air
cleaner/filter for damage,
