Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
74 registered members (97prizm, 2010Civic, allgm59, Alfred_B, andyd, 7 invisible), 1,334 guests, and 59 spiders.
Topics286,215
Posts4,904,427
Members67,579
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Removing Wallpaper #4649799
01/29/18 07:59 AM
01/29/18 07:59 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
My wife has been on me about removing wall paper from our 2 bathrooms so we can end up painting the walls. Our house has had the same wall paper for 24 years so she has a valid point. I’ve been in “procrastination mode” for the last couple of years but I think it’s time.
Any suggestions on how to go about it?
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Re: Removing Wallpaper [Re: Gebo] #4649805
01/29/18 08:07 AM
01/29/18 08:07 AM
New England
555 Offline
555  Offline
New England
A friend of mine had the same problem and swore by a mixture of fabric softener and water in a steamer.
84 XJ6 M1
92 Mustang 5.0 Redline
99 Tahoe 2 door Castrol Edge
99 MX5 Miata Anniversary Edition M1
04 Subaru STi Motul
Re: Removing Wallpaper [Re: 555] #4649839
01/29/18 09:03 AM
01/29/18 09:03 AM
Chicago,IL,USA
pandus13 Offline
pandus13  Offline
Chicago,IL,USA
...followed PRONTO by a pushing it with a spackle (or it will just peel if you are lucky)
WASH the walls after.
The leftover glue does not get along with paint/humidity.
Source: 2.5 bathrooms. Yup, they used in some spots, the good glue.....
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: Removing Wallpaper [Re: Gebo] #4649890
01/29/18 09:44 AM
01/29/18 09:44 AM
North TEXAS
oldoak2000 Offline
oldoak2000  Offline
North TEXAS
Actually, if the wallpaper is on there real good (not loose anywhere), you can SKIP removing it IF you paint/seal it with KILZ original OIL base primer! You MUST use exactly this product (NOT water-based KILZ latex primer) or any other. This oil-based stuff will NOT wet/soften the underlying 'glue', and will dry almost instantly (leaving no time for underlying glue to soften) - just be sure to apply with roller and do NOT 'overwork' the roller on the surface. The final product (when dried) will act as a sealer, and prevent any water from texture or topcoat(latex) from penetrating underneath the kilz to soften glue. The wallpaper/glue will become just like another paper layer on gypsum wallboard!, sealed in safely with the KILZ.
I have had FABULOUS results doing exactly the above - the wallpapered/kiltz'd surface is so perfectly smooth that I was able to only very lightly texture it simply using a roller with semi-watered down joint compound, then top-coat with latex. Let joint-compound dry 2 days.
Also, if you do have just a few spots where paper is loose, use a razor blade to first remove JUST the loose paper, then apply kilz over everything and let dry before patching/touching up any areas were paper removed/uneven and let that dry before applying overall texture. For a bathroom, I'd probably apply another layer of kilz OVER the texture, just to help seal it in.
One area we did pull the wallpaper off left such an un-even surface, it didnt turn out any were as nice as the ones sealed with kilz, making me wish I knew the KILZ trick from the beginning! Again, one final warning, use ONLY the KILZ ORIGINAL oil-based primer (white&red can) - it is specially formulated for near-instant (1 hour) drying, and using anything else could end in disaster. Also, the fumes on this KILZ necessitates adequate ventilation - but it dries in 1 hour and fumes are gone just as fast IF you ventilate well.
Re: Removing Wallpaper [Re: Gebo] #4649904
01/29/18 09:55 AM
01/29/18 09:55 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Maybe new drywall (cement board) and tile instead smile Wallpaper is dead but so is the over played orange or mustard paint and Stainless appliances with granite counter tops and built-in kitchen cabinets.
Hot water soak takes it off if its not water proof vinyl. Not a dry winter job. but you could prob get the room humid enough if its small.
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Removing Wallpaper [Re: Gebo] #4649908
01/29/18 10:01 AM
01/29/18 10:01 AM
MD
ET16 Offline
ET16  Offline
MD
I got a Wagner 715 Wallpaper Steamer to strip some rooms. It worked great.
Re: Removing Wallpaper [Re: Gebo] #4649913
01/29/18 10:06 AM
01/29/18 10:06 AM
The land of USA-made Subies!
SubieRubyRoo Offline
Get a Paper Tiger as well before you spray/soak it. It rolls across the wallpaper and punches lots of tiny holes to help the water get in and soften the adhesive. Then use a putty knife to scrape off. Makes life MUCH easier.
Re: Removing Wallpaper [Re: Gebo] #4649944
01/29/18 10:41 AM
01/29/18 10:41 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Ok, you have some great ideas. Let me add a wrinkle.
The other walls in our house are done in what I have heard call "knockdown." This is the texture she wants in the bathrooms. Is there some way to cover the wallpaper with a type of sealer and then get this type of look on the walls.
In other words, this is type of look we want to end up with.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: Removing Wallpaper [Re: Gebo] #4649985
01/29/18 11:31 AM
01/29/18 11:31 AM
DFW
DBMaster Offline
DBMaster  Offline
DFW
I remodeled a bathroom for a friend who had this issue. The wallpaper was applied over the bare sheetrock several decades in the past. It was so well adhered that trying to remove it just resulted in tearing into the paper facing of the wall. I sanded the wallpaper surface, applied the texture, primed, and painted. That was almost ten years ago and it still looks great!
Re: Removing Wallpaper [Re: Gebo] #4650051
01/29/18 12:21 PM
01/29/18 12:21 PM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
Textured/embossed wallpaper that you paint after you hang it, is available.
We used it in an old farmhouse with some awful plaster walls.
The Paper Tiger gizmo is excellent for removing paper, considering that they cost so little. Use it with really hot water for best results.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Removing Wallpaper [Re: Gebo] #4650078
01/29/18 12:46 PM
01/29/18 12:46 PM
lllinois
salesrep Offline
salesrep  Offline
lllinois
High quality Specialized Lubricants pay for themselves!
Re: Removing Wallpaper [Re: Gebo] #4650080
01/29/18 12:48 PM
01/29/18 12:48 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
You will need to fix the walls after. Many people get a pro to apply a skim coat of joint compound. Skim coat is an art.
2015 Ford F250 w/Powerstroke
Re: Removing Wallpaper [Re: Gebo] #4650087
01/29/18 12:58 PM
01/29/18 12:58 PM
MA
Wolf359 Online content
Wolf359  Online Content
MA
Technically that's an awful look. It's the cheap way out of a job and lots of contractors sell it like it's a good look, but it's not. Basically you just texture the walls so you don't have to come back and sand the walls. Most people don't like it but I guess there are some out there that do. Smooth walls cost more money.
Anyway, the standard methods of removing wallpaper are basically mentioned above. One other way is to just skim coat over it. I'd advise against painting over it. Although it may look good 98% of the time, you can tell it's painted over wall paper either because of the seams or the corners or the tops/bottoms of the wallpaper will not be perfect.
Re: Removing Wallpaper [Re: salesrep] #4650302
01/29/18 03:56 PM
01/29/18 03:56 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Originally Posted By: salesrep
This picture looks like you took this at home. I am assuming you have personal experience with this?
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: Removing Wallpaper [Re: Wolf359] #4650316
01/29/18 04:05 PM
01/29/18 04:05 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Thanks for the cut down. In our area this is the most expensive way to do walls at about $7 more per sheet. Very labor intensive and many buckets of "goop." The nearest dry wallers that we have found to do it are 2 hours away. It's too time consuming for most contractors is what I have been told.
We've had people come to our house and ask to see it because they heard about it. Of course, beauty is in the eye of the beholder.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Page 1 of 3 1 2 3
