P.S: You gave me another good advice, I'll at least pull the valve cover and compare both of them and also see if I notice any issues with seals.
If you have an air compressor and a valve spring compressor you could pressurize each cyl, remove the spring retainers and check/replace the valve stem seals. Maybe some are missing with that much oil burning.
Unfortunately, I don't have a compressor
The old school trick without a compressor, is to get the piston on the cyl you are working on, just below top dead center. Feed small diameter rope through the spark plug hole until no more will feed in. Then rotate ( with a wrench on the crank nut, do not bump the starter) the piston the rest of the way up to tdc or until it stops. The valves should not drop down. Then you can compress the springs on that cylinder and check the seals. reassemble the springs and retainers , pull the rope out of the spark plug hole, and move to the next cylinder.
Make sure its one continuous piece of rope and leave plenty hanging out of the spark plug hole.
Thanks so much spasm3, you are a helpful dude
I appreciate it, yes I am researching and looking on youtube, as well as reading about it. One of the Lisle magnetic tool also seems to be very cool for this kind of job!
