Miata Aisin 6 speed question
by 10ecfarmer. 09/23/18 12:36 PM
Shortest time you owned a car?
by Corollaman. 09/23/18 12:21 PM
Winter tires pinned for studs, but without studs
by Corollaman. 09/23/18 12:12 PM
03 Accord V6 "needs" iridium plugs?
by columnshift. 09/23/18 11:40 AM
03 Accord V6 'brake' light on after brake work...
by columnshift. 09/23/18 11:29 AM
Why does Redline Motor oil quiet lifter noise
by Onetor. 09/23/18 11:11 AM
2017 Hyundai Tucson burning oil (Help!)
by carviewsonic. 09/23/18 11:09 AM
Never waxed ???
by SilverGt. 09/23/18 10:55 AM
Plumbing drain question
by wormwood1978. 09/23/18 10:38 AM
Post your euro cars high mileage
by Serge. 09/23/18 09:08 AM
Post your cars high mileage
by Serge. 09/23/18 09:01 AM
Post your latest mileage achievement
by Snagglefoot. 09/23/18 08:23 AM
Field repair by the Mississippi!
by Number_35. 09/23/18 08:18 AM
F150 5.0 Lost power
by hatt. 09/23/18 08:15 AM
Mobil @ Bomgaars sale
by Duffyjr. 09/23/18 04:45 AM
More California BS!
by dogememe. 09/23/18 04:04 AM
Optimum No Rinse Wash and Wax or Shine?
by anndel. 09/23/18 03:44 AM
Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
90 registered members (10ecfarmer, 4WD, 08z06, 1nighttrain, 16HC, AndyB, 11 invisible), 1,854 guests, and 41 spiders.
Topics290,887
Posts4,851,891
Members66,047
Most Online3,590
Jan 24th, 2017
Motorcraft Syn Blend 5w20, 3500km, 03 F150 4.6L #4649553
01/28/18 09:53 PM
01/28/18 09:53 PM
Ontario, Canada
heyleescomet Offline OP
Ontario, Canada
Hi guys, longtime reader of the forums, just thought I would join and share my first report on my truck I bought early last year. It has
the 5 speed manual (M5OD-R2 i think). Motorcraft oil filter.
About 200km of highway and the rest of the 3500km is city, in 8 months time. Just short 5-10 minute trips to work/uptown everyday. Fairly gentle on it with maybe half a dozen times I let her breathe deep through a gear or two
2 months of well below freezing temperatures (10-20 below).
If anyone wants to share any thoughts please do. Kinda interested in what your thoughts are. Im not loyal to any brand, Had a Canadian Tire gift card so its currently filled with Pennzoil Platinum, and with a Napa Gold oil filter
After I got it road ready (new windshield,fluids, brakes, had no running lights except for headlights, found a corroded spot in a wire under the fuse panel where a mouse had made a home and chewed on a few wires, haha, easy fix. Got some more modern headlight housings, really helps the look I think,)
2003 F-150 4.6L, 5 speed, PP 5w30
1962 Mercury Comet 200ci, Shell 15w40
Re: Motorcraft Syn Blend 5w20, 3500km, 03 F150 4.6L [Re: heyleescomet] #4649568
01/28/18 10:07 PM
01/28/18 10:07 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
This report is a perfect example why Ford moved from 5W/20 to 5W/30.
Re: Motorcraft Syn Blend 5w20, 3500km, 03 F150 4.6L [Re: heyleescomet] #4649583
01/28/18 10:17 PM
01/28/18 10:17 PM
US
JLTD Online shocked
JLTD  Online Shocked
US
+1; I'd definitely move to 5w30, or maybe even 0w30 for the winter.
I'm a thickie; but a 20 has its place.
I use AMSOIL
Hers: 2008 Jeep Liberty 138k, SS 5w30/Amsoil
His: 2015 4Runner 41k, OE 5w20/Wix
Re: Motorcraft Syn Blend 5w20, 3500km, 03 F150 4.6L [Re: das_peikko] #4649621
01/28/18 10:55 PM
01/28/18 10:55 PM
Maricopa, AZ
dave1251 Offline
dave1251  Offline
Maricopa, AZ
Ford does recommend 5W30 in this engines successor. Nothing like spouting off about nothing factual.
don't use.
Re: Motorcraft Syn Blend 5w20, 3500km, 03 F150 4.6L [Re: heyleescomet] #4649633
01/28/18 11:08 PM
01/28/18 11:08 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Another item is all the cold starts. Might get better with a warming trend. Was it stored outside at your place and where you work? Im just guessing here. Nice truck.
SF
If you want the job done right......do it yourself.
Re: Motorcraft Syn Blend 5w20, 3500km, 03 F150 4.6L [Re: heyleescomet] #4649638
01/28/18 11:27 PM
01/28/18 11:27 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
I would attribute the Fe and Cu ppm mainly to low temperature corrosion wear instead of low viscosity grade.
I may be wrong though.
Re: Motorcraft Syn Blend 5w20, 3500km, 03 F150 4.6L [Re: heyleescomet] #4649646
01/28/18 11:49 PM
01/28/18 11:49 PM
Snagglefoot Offline
Snagglefoot  Offline
I dont want to get into the middle of things but the 2018 owners manual calls for 5W-20 for the 5.0 in the F-150.
Re: Motorcraft Syn Blend 5w20, 3500km, 03 F150 4.6L [Re: Snagglefoot] #4649650
01/28/18 11:54 PM
01/28/18 11:54 PM
Ontario, Canada
Ontario, Canada
Thank and Yep, always parked outside, I would use the block heater at home on the days it was at or below -20C. We'll see with warmer weather
how the 5w20 pennzoil plat report looks. May step up to 5w30 since I think you guys feel that would help. I almost did but thought I'll see how this report or two looks like.
Truck also sat for a few months before I bought it. I changed the oil shortly after I got it, wasnt sure if that will have any effect on these numbers or not.
Re: Motorcraft Syn Blend 5w20, 3500km, 03 F150 4.6L [Re: heyleescomet] #4649674
01/29/18 12:41 AM
01/29/18 12:41 AM
Ontario, Canada
Ontario, Canada
Took a bit, but now its easy to do this format that I guess is preferred here. To immortalize the data I think. Anyway thought Id stab this is here, redundant but it felt good to figure out the rather simple way to do it
Code:
OIL             Motorcraft
                SynBlend 5w20
KM IN USE       3.5k
KM              155k
SAMPLE TAKEN    01/13/18
ALUMINUM        7
CHROMIUM        3
IRON            25
COPPER          5
LEAD            0
TIN             0
MOLYBDENUM      18
NICKEL          1
MANGANESE       1
SILVER          0
TITANIUM        0
POTASSIUM       0
BORON           96
SILICON         17
SODIUM          40
CALCIUM         1618
MAGNESIUM       11
PHOSPHORUS      650
ZINC            723
BARIUM          0
INSOLUBLES      0.3
WATER           0
FLASHPOINT F   370
SUS VIS 210F   50.2
cSt @ 212F     7.33
Re: Motorcraft Syn Blend 5w20, 3500km, 03 F150 4.6L [Re: heyleescomet] #4649699
01/29/18 02:13 AM
01/29/18 02:13 AM
Maryland USA
rubberchicken Offline
Maryland USA
+1 that you moved up to a higher quality oil.
Re: Motorcraft Syn Blend 5w20, 3500km, 03 F150 4.6L [Re: heyleescomet] #4649703
01/29/18 02:43 AM
01/29/18 02:43 AM
Texas
FZ1 Offline
FZ1  Offline
Texas
The pp may just doing some cleaning re the numbers. Vis has thinned. Like the headlights. Handsome truck.
Re: Motorcraft Syn Blend 5w20, 3500km, 03 F150 4.6L [Re: heyleescomet] #4649808
01/29/18 08:08 AM
01/29/18 08:08 AM
Snagglefoot Offline
Snagglefoot  Offline
For what its worth -20 C is when I plug in as well.
SF
Re: Motorcraft Syn Blend 5w20, 3500km, 03 F150 4.6L [Re: heyleescomet] #4649813
01/29/18 08:16 AM
01/29/18 08:16 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
3500km is akin to 2200 miles. You have a definite concern for wear here. 25ppm in 2200 miles is more than 11ppm/1k miles; that is a VERY HIGH wear rate for the 4.6L engines.
I presume you don't know much of the history of the truck, or you'd already have mentioned it.
I would take another UOA again at 3500km. If the Fe is still that high, I'd say you have a distinct issue.
The 4.6L mod motors generally run quite well on about any vis out there (5w-20, 10w-30, 10w-40); it really does not matter. This is NOT vis related wear; that's ignorance coming from bench racers here. Your wear is not normal; something is amiss.
It's not time to panic; it's time to keep on looking for the cause. Run another 3500km and then do another UOA. Quit swapping oil brands; that only causes another input to deal with; pick a lube and stick with it during the diagnosis of this issue.
Report back upon next UOA.
For reference; check out my UOAs
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4389122/3
At or less than 1ppm/1k miles.
I ran alternating trials with both dino and syn lubes; both 5w-20.
Look at macro wear data here; note the 4.6L section:
https://bobistheoilguy.com/used-oil-analysis-how-to-decide-what-is-normal/
My UOAs are at or a slight bit better than "normal". Your wear rate is 10x (Ten Times) greater than mine, and well above "normal" averages.
Something is not right; your challenge is to find out what it is.
It is always possible it could be a lab error, or other input that skewed the data. That is why it's important to see another successive UOA.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Motorcraft Syn Blend 5w20, 3500km, 03 F150 4.6L [Re: heyleescomet] #4650000
01/29/18 11:47 AM
01/29/18 11:47 AM
The Garden State
Whimsey Online content
Whimsey  Online Content
The Garden State
Real nice looking truck. I had a 2002 F-150 with the same engine and transmission. I really enjoyed it but sadly it rotted away courtesy of our road departments here in NJ and their use of liquid salt brine in the winter mad. With iron that high in such few km's there is something going on. Is the engine generally quiet because the high iron could be coming from the timing chain slapping around due to worn plastic chain tensioners. It is quite a long chain on these engines.
Whimsey
Re: Motorcraft Syn Blend 5w20, 3500km, 03 F150 4.6L [Re: heyleescomet] #4650003
01/29/18 11:48 AM
01/29/18 11:48 AM
MN
oil_film_movies Online content
oil_film_movies  Online Content
MN
Low (none) potassium, so its not anti-freeze radiator coolant contaminating and causing extra wear.
Normal silicon, so its not a bad air box and/or filter leaks.
I would certainly not use Motorcraft oil filters since they have a reputation for getting holes in their media. They are made by Purolator who also has that reputation. Your choice of NAPA Gold oil filter is good, although a Fram Ultra is slightly better than those. Might get your insolubles of 0.3 down to 0.1.
Some of the excess wear can certainly be caused by rough cold weather. Not all of it can be blamed on that.
Wow. Here is what I'd do. Put in Valvoline full-syn with MaxLife (high mileage oil) 0w20 for those cold starts and a very good additive package, as its a dexos1 high-rated oil. Fram Ultra oil filter for the best cleaning ability. 1 bottle of LiquiMoly Ceratec to get some hex-boron and moly in there filling surface asperities.
On older engines that begin wearing a lot at your kilometers, I suspect the original surface hardening of the steel internal parts might not have been deep enough, which means you could have worn through the original low-depth layer. This could have been a process control issue in the timing chain or cam lobes or other iron parts. Pure speculation on my part. Occasionally some new parts have their lives shortened by improper original surface hardening, and there are shades of gray in how bad it could be.
