So I have a little 283 project in the shop. Was topped with 601 heads at nigh on to 10:1, but that's too steep for local pump gas, and not conducive to maybe going into a CJ ...
So I have some bigger chamber vortec heads that will drop the CR nicely and create swirl
But I also have some nice old school "Chevrolet" stamped steel valve covers w/o fill holes. etc.
I want to pull the freeze plug from the old block port for the road draft tube and insert a piece so I can fit the PCV there. I can put a fill tube into the intake with a cap. Make it look 1960's period correct.
So does anyone know of a road draft plug kit with a PCV port for an early SBC?
