Gluten
by StevieC. 09/25/18 07:55 PM
Amazon Prime delivering inside your house
by StevieC. 09/25/18 07:49 PM
2018 MB C300 M1 0W-40 3,475 Miles
by 2015_PSD. 09/25/18 06:44 PM
02-05 Silverado frame rot
by Oildudeny. 09/25/18 06:38 PM
Aftermarket Back Up Camera
by lancerplayer. 09/25/18 06:20 PM
Service champ filter CUT OPEN
by 53' Stude. 09/25/18 05:05 PM
Pressure washer pump life just 23 hours?
by HawkeyeScott. 09/25/18 05:01 PM
STP S 10590 CUT OPEN
by 53' Stude. 09/25/18 05:00 PM
2003 BMW M5-Unknown oil 2500 mi
by Audios. 09/25/18 04:54 PM
FRAM ULTRA XG 3593A CUT OPEN
by 53' Stude. 09/25/18 04:51 PM
MG 201-7, 7,500 MILES CUT OPEN
by 53' Stude. 09/25/18 04:44 PM
MG 301-1, 10,800 miles CUT OPEN
by 53' Stude. 09/25/18 04:34 PM
Anyone regret their cordless electric OPE?
by dlundblad. 09/25/18 04:21 PM
Which Performance Filter?
by rooflessVW. 09/25/18 03:33 PM
Optimal Compression Ratio for 91 Octane Fuel
by NICAT. 09/25/18 02:01 PM
Anyone used Amsoil DZF 0w40 ?
by ofelas. 09/25/18 01:33 PM
No more Turo - What now?
by dogememe. 09/25/18 01:08 PM
Military small arms ammo
by Camprunner. 09/25/18 12:03 PM
Pat_Roberts, Peppz, Jfa02, ibsfusion, Fearcat707
66070 Registered Users
96 registered members (ABomb369, 4WD, AandPDan, 2015_PSD, 92saturnsl2, 2004tdigls, 14 invisible), 1,452 guests, and 38 spiders.
Topics291,016
Posts4,854,437
Members66,070
Most Online3,590
Jan 24th, 2017
Kia Sportage vc gasket change #4648711
01/28/18 09:01 AM
01/28/18 09:01 AM
A Warm place to live in
berniedd Offline OP
berniedd  Offline OP
Kia Sportage 2007, guys. Inline 4 cylinder 2.0 liters with a weeping valve cover gasket. Is it a simple slap-it-on job or does it need gasket sealant at some specified areas and corners as my Honda requires?
Re: Kia Sportage vc gasket change [Re: berniedd] #4648749
01/28/18 09:32 AM
01/28/18 09:32 AM
NJ
Leo99 Offline
Leo99  Offline
NJ
Once you pull the vc, you should be able to tell if there was any sealant used.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 359,000 miles
2015 Camry 59,000 miles
Re: Kia Sportage vc gasket change [Re: berniedd] #4649073
01/28/18 01:57 PM
01/28/18 01:57 PM
Deep in the heart of Jersey
BigCahuna Offline
BigCahuna  Offline
This is somewhat related. My wife used to have a '00 Sportage that the vc leaked twice. Twice it developed a leak that filled the spark plug hole with oil, that cause the plug to miss fire due to being submerged in oil. The first replacement didn't have sealer on it, but the second one did. This happened at 90k and 100k,and under the valve cover was so cleaned it looked like it was put together the week before. Mobil 1 EP since 10k.,,,
Re: Kia Sportage vc gasket change [Re: berniedd] #4650734
01/30/18 04:33 AM
01/30/18 04:33 AM
berniedd Offline OP
berniedd  Offline OP
After a little digging, I found a shop manual that says to use a little sealant at "the corners of the depression of the gasket" after it is installed at the valve cover. Apparently the gasket is not all flat. It has a short section with some concavity. I will also order a set of doughnut gaskets for the spark plug tubes and, as BigCahuna chimed, make sure to apply some sealant to them too.
Re: Kia Sportage vc gasket change [Re: berniedd] #4650758
01/30/18 06:02 AM
01/30/18 06:02 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Go with the recommendation of the replacement gasket maker you choose. Of course you need something where pieces would meet each other.
The "thinking" man's friend.
