Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
112 registered members (ArrestMeRedZ, 2012AccentSE, Arminius, albenjoseph, 55Test, addyguy, 13 invisible), 2,038 guests, and 63 spiders.
Topics286,147
Posts4,903,006
Members67,565
Most Online2,967
Mar 10th, 2019
ZDDP additive calculation help required please!!! #4648601
01/28/18 05:01 AM
01/28/18 05:01 AM
United Kingdom
OilMonkey Offline OP
United Kingdom
Hi all,
I have a straight 50 mineral oil which currently has approx 800ppm Zinc and wish to increase this level to 1500ppm could one of you guys help with how much is required please to achieve the desired amount?
I have a ZDDP additive which contains the following data:
Density @ 20 Deg C : 1115
Viscosity @ 40 Deg C : 211
Viscosity @ 100 Deg C : 12.9
Zinc Characteristics by Weight : 8.0% Minimum / 9.0% Typical / 10.5% Maximum
The recommended treat rate is 0.5% to 2.1% by weight.
I would appreciate it if someone could assist in calculating how much additive I need to add to the Straight 50.
Extra Kudos for showing your workings grin
If any other info is required for the SAE50 or Additive please let me know!!
Thank you!!!!
Re: ZDDP additive calculation help required please!!! [Re: OilMonkey] #4648649
01/28/18 07:17 AM
01/28/18 07:17 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
What engine will this be used in?
Re: ZDDP additive calculation help required please!!! [Re: OilMonkey] #4648655
01/28/18 07:28 AM
01/28/18 07:28 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
OK so 100 ppm (parts per million) = 0.01 %
Your oil has 800 ppm or 0.08% ZDDP. Lets ignore for the minute if you are talking actual Phos or Zinc, they track together and are close enough for a rough calculation.
Your zinc add has, on average, 9% or 90,000 ppm ZDDP.
So mixing up 1 Litre let's use:
990ml of 800 ppm oil = 0.99 x 800 = 792 ppm
10ml of 90000 ppm add = 0.01 x 90000 = 900 ppm
Therefore total ZDDP for 1L = 792 + 900 = 1692 ppm. This is a dose of 1% by volume.
This will do me, as you are never too sure of the actual strength of the oil and zinc add anyway.
But if you want it a little closer:
992 ml of 800 ppm oil = 0.992 x 800 = 794
8 ml of 90000 ppm add = 0.008 x 90000 = 720
Total ZDDP for 1L = 794 + 720 = 1514 ppm
Scale up as required. And give the ZDDP add a good shake.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: ZDDP additive calculation help required please!!! [Re: SR5] #4650115
01/29/18 01:23 PM
01/29/18 01:23 PM
United Kingdom
United Kingdom
SR5 thank you for your time and informative reply, very much appreciated!
