DTD/DT Independence Day Promos
by Sayjac
06/25/18 08:39 AM
It's AMSOIL®, not Amsoil
by Rat407
06/25/18 06:39 AM
VW Passat 2007
by madRiver
06/25/18 06:18 AM
Review: CVJ Remanufactured CV Axles
by The Critic
06/25/18 03:40 AM
Towing without 85w140?
by OilFilters
06/25/18 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
06/24/18 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
06/24/18 09:10 PM
SAE 90 v 85/140
by Knuckle078
06/24/18 09:10 PM
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
06/24/18 08:45 PM
Schaeffer's oil reviews on Amazon
by zfasts03
06/24/18 07:41 PM
Decent MP3 player
by Ed_T
06/24/18 07:08 PM
Letgo
by Donald
06/24/18 06:52 PM
Tire buying advice
by supton
06/24/18 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
06/24/18 06:21 PM
No older cars in New York State?
by Oldtom
06/24/18 06:19 PM
2009 Taurus strut mount noise
by terry274
06/24/18 04:38 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
103 registered (2009Edge, 2004tdigls, 1JZ_E46, 2002 Maxima SE, andyd, alcyon, 13 invisible), 1495 Guests and 62 Spiders online.
65319 Members
67 Forums
285960 Topics
Page 1 of 2 1 2 >
#4648520 - 01/27/18 11:06 PM Oil for lifter tick/noise
Nissan101 Offline
Loc: Caribbean
Good night,
Can i get a good recommendation for an oil, that you all had good result with reducing the tapping noise.
Nissan n16 sunny.
Oil currently is Valvoline.
No oil consumption. Should i go thicker? to reduce the lifter noise?
Edited by Nissan101 (01/27/18 11:08 PM)
Nissan N16 -10w30
Nissan S13 -20w50
Royal Purple HPS smile
#4648530 - 01/27/18 11:19 PM Re: Oil for lifter tick/noise [Re: Nissan101]
Pajero Offline
Loc: Rio Rancho, NM
Normally thicker oil does help quiet the noise. But, only if your owner's manual allows this. My Montero runs better on a 40 weight oil. The OM is from 5w30 to 20W50, so I have a lot of options, depending on weather conditions.
Respectfully,
Pajero!
Always remember "Planned obsolescence."
1994 Montero SR 3.5 DOHC, 133,xxx
Fram Ultra/ Snorkel with Pre-filter
K-9-Co-pilot
#4648558 - 01/28/18 12:21 AM Re: Oil for lifter tick/noise [Re: Nissan101]
Vladiator Offline
Loc: NC
Go thicker on the operating temperature rating, and thinner on start up rating. Pennzoil/Castrol/Mobil 0w-40 will do nicely.
Thicker oils give protection for severe operations such as driving in mountains, pulling a boat, dusty conditions, short trips, high rpm, overloading, overheating and overcooling. Thin oils give MPG.
#4648593 - 01/28/18 03:18 AM Re: Oil for lifter tick/noise [Re: Nissan101]
jj51702 Offline
Loc: California
Jamaican castor oil mon'
#4648598 - 01/28/18 03:37 AM Re: Oil for lifter tick/noise [Re: Nissan101]
SR5 Offline
Loc: Down Under
Sometimes a low restriction filter can reduce lifter tick, especially on start up.
Penrite Vantage 10W40 SN & A3/B4 + Wesfil-Cooper Z154
#4648599 - 01/28/18 03:45 AM Re: Oil for lifter tick/noise [Re: Nissan101]
Silk Offline
Loc: New Zealand
Coming from a thick oil country, I've found going thinner helps with lifter noise in the morning.
1987 BMW R65 - Penrite V Twin 20/50
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
#4648617 - 01/28/18 05:14 AM Re: Oil for lifter tick/noise [Re: Nissan101]
knerml Offline
Loc: NE Ohio
I would also try an Nissan OEM filter the next oil change, the see if that helps.
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W20 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport 2.0T GDI Castrol Edge 5W40 & OEM/Mann W811/80 Filter
#4648646 - 01/28/18 06:16 AM Re: Oil for lifter tick/noise [Re: Nissan101]
Linctex Offline
Loc: Waco, TX
I had one engine that drove me nuts with it's intermittent ticking.
I tried several different oils, thick to thin. Flushes also.
What finally worked (or unless it was "just it's time") was neodymium magnets on the oil filter.
#4648674 - 01/28/18 07:01 AM Re: Oil for lifter tick/noise [Re: Nissan101]
Driz Offline
Loc: northern NY
Could the valves need adjustment? If they’re solids and a bit loose that will cure it. Otherwise here’s my advice , are you ready, Turn up the radio! Oh slam I always get [censored] for that one when some guy complains about his 5.3 GM pistons slapping away . Sometimes when there’s nothing to realistically be done that’s the best method,........just sayin.
Put a stethoscope on there and make sure that’s whT it really is If in doubt and make sure.
#4648743 - 01/28/18 08:29 AM Re: Oil for lifter tick/noise [Re: Nissan101]
ZZman Offline
Loc: Michigan
Depends on why it is ticking. Might try a motor flush first and then a good high detergent oil.
2003 Mercury Grand Marquis. Rotella T6 Multi-Vehicle oil
2008 Sebring Hardtop convertible. Rotella T6 Multi-Vehicle oil
2006 Kawasaki Vulcan 900 LT. Amsoil Metric 10w-40
#4648808 - 01/28/18 09:26 AM Re: Oil for lifter tick/noise [Re: Nissan101]
SuzukiGoat Offline
Loc: Louisiana
Whenever I got a used high mileage ticking Suzuki, Nissan, or Toyota, I always run 0w40 in it until the start up noise gets louder. Then rinse and repeat. The Suzuki and Nissan would destroy the oil in 5k and need changing. The Toyota would give no hint that anything was changing u til I got bored around 10-12k miles.
It did eventually eliminate the issue.
2003 Nissan Xterra 4x4 M1 HM 10w40
2001 Toyota 4runner 4x4 M1 0w40
2016 Yamaha YXZ1000R VR1 20w50
#4648960 - 01/28/18 11:34 AM Re: Oil for lifter tick/noise [Re: SuzukiGoat]
Kira Offline
Loc: Champlain/Hudson Valley
From the recommendations mentioned I like the 0W-40 one and the OEM filter.
Anybody would be hard pressed to locate a "low resistance" oil filter.
A cleaner system may allow for faster lifter pump up so MAYBE a chemical flush might help IF the engine is dirty.
I bought cases of "Formula Shell" in 10W-30 on clearance.
It went into many different engines and everybody including me noticed it was a quieting oil.
I think zinc is the component in the adpack that makes 'em quiet.
#4649007 - 01/28/18 12:13 PM Re: Oil for lifter tick/noise [Re: Nissan101]
Tobygot Offline
Loc: Arizona
I had an '07 Silverado that I always used AMSOIL in. Around 70k it started having a ticking even when warm. After about 5k miles of ticking I put 5 or 6 ounces of MMO down my oil fill and a little oil to flush it down and the tick went away. Until I sold the truck 40k miles later I would put 5 or 6 ounces of MMO in with every oil change. The tick never came back. It's cheap. Try it.
#4649319 - 01/28/18 04:49 PM Re: Oil for lifter tick/noise [Re: Kira]
Silk Offline
Loc: New Zealand
Pro-ma MBL8 was the stuff to stop lifter noise. Full of copper and lead - that sure quietens them down. Unfortunatly I have used it often...and unfortunatly it does work.
[img]https://www.pro-masystems.co.nz/Assets/I...;maxheight=1000[/img]
Check it out...got the one arm bandit to prove how good it is. Can't dispute that can we, proof right before our eyes.
https://www.pro-masystems.co.nz/ProductMoreInfo.aspx?PID=50083&MenuID=128
#4649332 - 01/28/18 05:04 PM Re: Oil for lifter tick/noise [Re: Nissan101]
Triple_Se7en Offline
Loc: 1/2 hr. north of Detroit
The MBL8 Concentrated Oil Additive I found was $41 for 250ml.
Page 1 of 2 1 2 >
