New car wax score
by Marco620. 01/16/19 02:42 PM
Bought a used Cherokee Trailhawk
by Sunnyinhollister. 01/16/19 02:34 PM
Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
126 registered members (97f150, 4WD, 28oz, 53' Stude, 2004tdigls, 12 invisible), 2,241 guests, and 33 spiders.
Topics296,645
Posts4,956,557
Members66,950
Most Online2,577
Jan 14th, 2019
Trailer lug nuts not threading on by hand? #4648220
01/27/18 05:48 PM
01/27/18 05:48 PM
Houston, Texas
motor_oil_madman Online content OP
motor_oil_madman  Online Content OP
Houston, Texas
They weren't crossed threaded, at first I thought it was cause the studs were painted. Is it just a case of poor Chinese machining? I've always been able to thread lug nuts down by hand easily. I had to use the lever of the socket in my hand to get them to spin on.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Trailer lug nuts not threading on by hand? [Re: motor_oil_madman] #4648253
01/27/18 06:19 PM
01/27/18 06:19 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
You thought it was because the lugs were painted? Wasn't it?
Are the lugs clean now? Wire brush the paint off and see if it gets easier.
Re: Trailer lug nuts not threading on by hand? [Re: motor_oil_madman] #4648300
01/27/18 07:10 PM
01/27/18 07:10 PM
Houston, Texas
Houston, Texas
No they're still pretty tight.
Re: Trailer lug nuts not threading on by hand? [Re: motor_oil_madman] #4648301
01/27/18 07:10 PM
01/27/18 07:10 PM
Houston, Texas
Houston, Texas
They still torqued down good and everything, so it's whatever. I'm just curious how common this is.
Re: Trailer lug nuts not threading on by hand? [Re: motor_oil_madman] #4648307
01/27/18 07:16 PM
01/27/18 07:16 PM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
You may have caught a burr somewhere. Only a good inspection of the components will give you the answer.
Re: Trailer lug nuts not threading on by hand? [Re: motor_oil_madman] #4648313
01/27/18 07:23 PM
01/27/18 07:23 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
It is NOT common.
Something is machined wrong, either studs or nuts.
Find out which it is and have them replaced.
Re: Trailer lug nuts not threading on by hand? [Re: motor_oil_madman] #4648464
01/27/18 09:56 PM
01/27/18 09:56 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
They were over torqued at one time.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Trailer lug nuts not threading on by hand? [Re: Chris142] #4648473
01/27/18 10:18 PM
01/27/18 10:18 PM
Where the wind comes sweepin'
Reddy45 Online shocked
Reddy45  Online Shocked
Yup this. The metal deformed at some point so now the thread pitch is not what it should be.
Re: Trailer lug nuts not threading on by hand? [Re: motor_oil_madman] #4648574
01/28/18 01:27 AM
01/28/18 01:27 AM
Houston, Texas
Houston, Texas
Great. So I have 24 studs that need to be pulled out and replaced?
Re: Trailer lug nuts not threading on by hand? [Re: motor_oil_madman] #4648582
01/28/18 02:23 AM
01/28/18 02:23 AM
Wisconsin
Black_Thunder Offline
Wisconsin
are you using new lugnuts or the ones that were on it (used)
maybe just try a new nut, try threading it on the studs by hand, and if doesn't thread on then the studs are stretched.
I'd buy Callahan autoparts if I could.
Re: Trailer lug nuts not threading on by hand? [Re: Chris142] #4648677
01/28/18 07:07 AM
01/28/18 07:07 AM
northern NY
Driz Offline
Driz  Offline
northern NY
There ya go! Some meat stick with a bigass air gun hammered em one once upon a time and stretched the threads. I start all mine by fingers then snug em with setting 1 on my Aircat. Then finish that last half turn or so by hand. No more deformed threads. Just grab new ones anywhrere They pound on from the back usually.
Re: Trailer lug nuts not threading on by hand? [Re: motor_oil_madman] #4648685
01/28/18 07:21 AM
01/28/18 07:21 AM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
I assume this was your first time doing this with these lug nuts? If so, it doesn't surprise me. When I purchased snowy's for my wife's 2017 Impala last November, I found the same thing when I installed the new lug nuts that came with them as a package.
Some would spin on OK but most caused me some greive of some sort.
I wrote it off as likely being cheap, mass produced, low on quality control, Chinese junk. They were also smaller (OD) than the stockers but they did go on nonetheless.
I originally torqued them to 110 foot Lbs then rechecked after about 50-100 kms and noticed some had backed off slightly, to which I retorqued them to 115 foot Lbs.
I just checked them again last week-end and all were still good. My fear is, once spring comes and I go to remove them, the chrome on them will spin/break on me and of course I'll be in a pickle like I have experienced before.
We'll see how that goes and that will determine if I use them again next winter?
Edit: Meant to add, the studs on this car were in great shape, as they should be with only 20,000 kms on the car. No visible rust/corrosion on them that I seen.
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: Trailer lug nuts not threading on by hand? [Re: motor_oil_madman] #4648726
01/28/18 08:17 AM
01/28/18 08:17 AM
Houston, Texas
Houston, Texas
Yep. Trailer is only 6 months old. First time off.
Re: Trailer lug nuts not threading on by hand? [Re: motor_oil_madman] #4649098
01/28/18 01:13 PM
01/28/18 01:13 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Would a die move the threads back into their proper pitch ? MOM I feel your pain, It took me a weekend to remove a wheel whose studs had been over torqued. 3 studs were spinning on the the hub.
Thick oil is better grin2
Re: Trailer lug nuts not threading on by hand? [Re: motor_oil_madman] #4649716
01/29/18 02:45 AM
01/29/18 02:45 AM
Wisconsin
Wisconsin
can you get a close up picture of what the studs look like?
any kind of dirt build up or anything?
