Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
23 registered members (Char Baby, avi1777, billt460, Aero540T, ctechbob, 2 invisible), 531 guests, and 59 spiders.
Topics286,171
Posts4,903,558
Members67,572
Most Online2,967
Mar 10th, 2019
Page 1 of 5 1 2 5
10w30 & low temps #4648201
01/27/18 06:02 PM
01/27/18 06:02 PM
MA.
Camprunner Offline OP
MA.
What is the lowest outside temperature you feel comfortable running a 10w30 synthetic?
Re: 10w30 & low temps [Re: Camprunner] #4648204
01/27/18 06:05 PM
01/27/18 06:05 PM
ME
eljefino Offline
eljefino  Offline
ME
Regularly or irregularly?
My F150 turned over and caught at -17'F on Nextgen green bottle, whatever that is, syn-blend?
If I were somewhere with a winter climate and HAD TO start unaided I'd go with at least a 5w30 synthetic. But the truck sits in my driveway and I fire it up only to go to the dump. If it chooses not to go there's always the next day.
Re: 10w30 & low temps [Re: Camprunner] #4648208
01/27/18 06:14 PM
01/27/18 06:14 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
All the synthetic 10w30 oils I have seen have a -30 pour point or lower. Even most conventional 10w30 has around a -30 pour point.
Heck 20w50 is rated around -20 pour point.
People forget cars use to come with straight 30 weight and would still go 100k if taken care of.
yup
Re: 10w30 & low temps [Re: Camprunner] #4648209
01/27/18 06:18 PM
01/27/18 06:18 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Acknowledging it is allowed to slip a grade in service, no lower than the CCS temp, which is -25C.
2016 Grand Cherokee SRT - Castrol Edge 0w-40, FRAM Ultra
Re: 10w30 & low temps [Re: Camprunner] #4648244
01/27/18 07:14 PM
01/27/18 07:14 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
As I've posted before, Mobil 1 5W-30 and 10W-30 flow significantly better in cold temperatures than other commonly available oils.
https://www.youtube.com/watch?v=uQ_vxdO_9nc
Re: 10w30 & low temps [Re: Camprunner] #4648249
01/27/18 07:17 PM
01/27/18 07:17 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
-35F in an '03 PathFinder, no problem starting it.
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: 10w30 & low temps [Re: Camprunner] #4648263
01/27/18 07:32 PM
01/27/18 07:32 PM
new jersey
hemitruck Offline
hemitruck  Offline
new jersey
My first car was a ,67 Cutlass. Called for 10/40 WT oil. This was in 74, so no synthetic at the time. Started fine in below 0 degrees.
Re: 10w30 & low temps [Re: Camprunner] #4648270
01/27/18 07:39 PM
01/27/18 07:39 PM
socal
barkingspider Offline
socal
In my old 02 s10, I had 10w30 (I think it was syn blend) that sat for a weekend where overnight it reached -4F. Started up and ran fine the next morning. In my vehicles, Im comfortable using 10w30 above 0 degrees F.
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: 10w30 & low temps [Re: Camprunner] #4648271
01/27/18 07:40 PM
01/27/18 07:40 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Do you have a diesel or Gas engine. No auto manufacturers have recommended 10w-30 in a gas engine in over 20 years. Use 5W-30 instead. If its a Diesel engine you are excused.
If you want the job done right......do it yourself.
Re: 10w30 & low temps [Re: barkingspider] #4648272
01/27/18 07:40 PM
01/27/18 07:40 PM
Great Lakes
Quattro Pete Offline
Great Lakes
+1
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: 10w30 & low temps [Re: Camprunner] #4648286
01/27/18 07:53 PM
01/27/18 07:53 PM
Snagglefoot Offline
Snagglefoot  Offline
The ASTM cold cranking test is done at -25 C (13 F). 10W-30 starts OK at this temp. However, why induce more cold weather wear than is necessary? Using 5W-30 is a better solution.
Re: 10w30 & low temps [Re: Snagglefoot] #4648292
01/27/18 07:56 PM
01/27/18 07:56 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
-25C equals -13F I believe. And -30C equals -22F. And at -40 they are both the exact same.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: 10w30 & low temps [Re: Quattro Pete] #4648304
01/27/18 08:13 PM
01/27/18 08:13 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
+1
+2
At 0F (-20 C) you should start with no problems with a good battery, and as many have commented, much lower is possible. But to me 0F and below would be when I would select a 5W30, above that I like the shear stability and low volatility of a 10W30.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: 10w30 & low temps [Re: Camprunner] #4648305
01/27/18 08:13 PM
01/27/18 08:13 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Re: 10w30 & low temps [Re: OVERKILL] #4648310
01/27/18 08:19 PM
01/27/18 08:19 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
Which would be -13F and still pretty darn cold.
Realistically, most of us in the lower forty eight will never see temperatures cold enough that a 10W grade oil would be a problem.
Even lower overnight temperatures won't usually matter since they typically aren't sustained long enough to chill the oil in the sump to the ambient temperature of an only briefly reached low.
There is also always the option of a sump heating pad, which makes the W grade of the oil irrelevant.
One of these would also be nice on one of our below zero mornings, since warmed oil makes for a warm engine and faster heat to demist the windows and warm the driver without a lot of idling.
You don't see these much here on gassers, but I did see the tell-tale AC hanging out on local gassers on a drive through South Dakota and Montana.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Page 1 of 5 1 2 5
