2006 Caravan... how to remove window Regulator
by DeafBrad - 01/28/20 11:10 PM
Ford oil spec for 2015 F150 w/ 2.7L EcoBoost?
by RonRonnster - 01/28/20 09:51 PM
Fun spark plug discussion
by 14Accent - 01/28/20 09:12 PM
Camry vrs Sonata
by tblt44 - 01/28/20 07:50 PM
Parasitic battery draw.
by wtd - 01/28/20 07:49 PM
AAP clearance 2020
by GMguy84 - 01/28/20 07:34 PM
2017-2019 GLA 250 4-Matic vs BMW X-1
by HangFire - 01/28/20 07:20 PM
Good news for .300blk shooters
by The_Eric - 01/28/20 06:43 PM
‘16 Lexus GS350 vs ‘16 Lexus RX350
by miden851 - 01/28/20 06:19 PM
Stone guard removal
by dawgn86 - 01/28/20 06:09 PM
Craigslist is like a petty HOA now
by eljefino - 01/28/20 05:06 PM
Shoretel PABX - any experience?
by stockrex - 01/28/20 04:44 PM
Around Australia record in the 1970's
by sanoptic - 01/28/20 03:21 PM
Oil mixing...does density matter?
by LotI - 01/28/20 02:02 PM
Uh Oh. Subaru Front Halfshaft CV Going Bad
by ARCOgraphite - 01/28/20 01:25 PM
Help choosing the right oil
by CAJ1966 - 01/28/20 12:33 PM
Which cooler line is return?
by LeakySeals - 01/28/20 11:39 AM
New Havoline ProDS 0w20 boosted Moly?
by jayjr1105 - 01/28/20 10:59 AM
Diesel fuel pump, pump synthetic 40 weight?
by H20ham - 01/28/20 10:54 AM
Review: 2019 VW Passat Wolfsburg 2.0T
by wemay - 01/28/20 10:16 AM
indigo2020, Towkid, denor, Jubaxtreme, CAJ1966
70551 Registered Users
42 registered members (carlprop, 01rangerxl, 1WildPig, 90Notch, BlakeB, BusyLittleShop, 3 invisible), 2,253 guests, and 18 spiders.
Topics300,685
Posts5,181,155
Members70,551
Page 1 of 3 1 2 3
Can Marvel Mystery Oil be used reliability? #4648036 01/27/18 02:05 PM
G
GSLex Offline OP
G
Hi there,
I just bought myself a Lexus LS430 after 3 years of search with only 100.000km and every possible option. I am happy as a child!
The LS is from 12-2004 and had 7700km a year. My idea was to preventive use this MMO to clean the carbon and all the other lubrications.
And what is in fact, very very important to me, is that I want to be 100% sure that this additive cant Absolutely do no harm by any chance?
I always have very expensive problems with cars and again, I must be 1000%!!!
If you have any other suggestions please let me know. I would really appreciate that.
Re: Can Marvel Mystery Oil be used reliability? [Re: GSLex] #4648040 01/27/18 02:10 PM
T
Trav Offline
T
At 100K Km (60K miles) I wouldn't even think of it. Change the oil on schedule and forget it. Don't kill the thing with kindness.
Re: Can Marvel Mystery Oil be used reliability? [Re: GSLex] #4648059 01/27/18 02:26 PM
A
aquariuscsm Offline
A
NO additives. Only use oem spec motor oil.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: Can Marvel Mystery Oil be used reliability? [Re: GSLex] #4648103 01/27/18 03:15 PM
Donald Offline
The only mystery about MMO is why people still use it. Snake oil.
Use quality synthetic oil and a PEA based fuel injection cleaner as per directions.
Avoid additives.
Nothing is 100%. You do the best you can.
2015 Ford F-250 w/Powerstroke
Re: Can Marvel Mystery Oil be used reliability? [Re: GSLex] #4648115 01/27/18 03:32 PM
L
Leo99 Offline
L
Why are you worrying about a problem that has a very low probability?
Post some pictures and enjoy your new car.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: Can Marvel Mystery Oil be used reliability? [Re: GSLex] #4648120 01/27/18 03:39 PM
V
Vladiator Offline
V
MMO is 1000% safe in proper amounts. No more than 20% of full oil capacity, and no more than 1qt/10gallons of gas in the fuel. If you keep it around these numbers - MMO will do some cleaning, I have experienced it first hand on many vehicles and am very satisfied. The MMO will burn off in the oil after a couple hundred miles, so check your oil level and keep it at proper level by refilling with MMO or motor oil.
Good luck with the vehicle! It is a great one, best car ever made.
Re: Can Marvel Mystery Oil be used reliability? [Re: GSLex] #4648126 01/27/18 03:50 PM
W
Wolf359 Offline
W
Yeah, I wouldn't use any snake oils. What should be telling is that no manufacturer recommends it. Just change the oil on a regular schedule and do scheduled maintenance like transmission fluid changes, coolant flushes etc on time and you should be fine.
Re: Can Marvel Mystery Oil be used reliability? [Re: GSLex] #4648129 01/27/18 03:52 PM
J
JC1 Offline
J
Why do you have expensive problems? I would use quality a and filter and leave the additives out of the motor.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Can Marvel Mystery Oil be used reliability? [Re: GSLex] #4648130 01/27/18 03:53 PM
demarpaint Offline
IF the engine needs cleaning it will work quite well and do no harm.
God Bless Our Troops
Re: Can Marvel Mystery Oil be used reliability? [Re: GSLex] #4648151 01/27/18 04:14 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
MMO? Don't see much of a reason/need.
What I personally would do, given that I'd be doing the oil changes, is to do 2-3 short duration OCIs to get any old oil pilot, help clean if needed, and just to get on a fresh page. Ditto for ATF, diff oil and coolant. Id swap brake fluid too.
That way I'd personally know the status and composition of all fluids. It would be peace of mind, not much else.
Re: Can Marvel Mystery Oil be used reliability? [Re: GSLex] #4648154 01/27/18 04:16 PM
J
jj51702 Offline
J
Great thread title
Re: Can Marvel Mystery Oil be used reliability? [Re: Vladiator] #4648181 01/27/18 04:43 PM
B
BrocLuno Offline
B
+1 smile
Been using MMO for close to 50 years for some things. It does help some situations. It is safe. But a Lexus with only 60,000 miles ... Unless badly abused by previous owner, not needed. Run premium oil and by 100,000 miles it'll be clean as a pin smile
Re: Can Marvel Mystery Oil be used reliability? [Re: GSLex] #4648205 01/27/18 05:06 PM
CharlieBauer Offline
Firstly, congratulations on the car. It sounds like a car that you want to keep running for ever.
Change all the fluids with quality products and stay away from additives to those fluids. The fluids contain everything needed.
If the new oil gets dirty quickly, then change it at a conservative interval and observe and record how dirty and when it gets that dirty the first, second, third time. You could do a used oil analysis if you want to be sure about things. I would.
I'd be tempted to get an analysis for transmission fluid as well. Again, it's about ruling out any problems and understanding the situation to help you plan your maintenance.
Brake fluid is something that may benefit from a second flush a few weeks or months after the first one.
You should aim to exchange all fluids completely including power steering and coolant.
Look at the maintenance schedule for other things such as spark plugs.
Find a PEA fuel system cleaner (not a non PEA cleaner and not a fuel injector cleaner). Use it once now and if there is an improvement, do it again just before an oil change. Then go by feel for subsequent usage.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Can Marvel Mystery Oil be used reliability? [Re: GSLex] #4648246 01/27/18 06:16 PM
Z
ZZman Offline
Z
It won't hurt anything. But if cleaning us your main goal but a oil with alot of detergents.
2007 Hyundai Santa Fe AWD.
2005 Toyota Avalon XLS
Re: Can Marvel Mystery Oil be used reliability? [Re: GSLex] #4648258 01/27/18 06:26 PM
F
fdcg27 Offline
F
Given your user name, do you have a GS as well, or have you had one?
What grade of oil does Toyota recommend for these engines in Europe?
A 0W-40?
I wouldn't use MMO in any decent engine personally although there are those here who aren't fools who would beg to differ.
If your car had good maintenance over its working life, it shouldn't need any engine cleaning anyway.
If you really do feel that some internal cleanup is needed, it's more likely carbon in the combustion chambers and maybe some minor deposits around the fuel injector nozzles.
This can be fixed, if it's even there, with a dose of a PEA fuel system cleaner run through a tank of fuel.
This car probably has ample fuel capacity, so a dose in half a tank might be advisable.
It sounds as though you got a very nice example of Toyota's best car.
I hope that you enjoy it and use it as it was intended to be used.
These cars have the power as well as the poise to be seriously fast runners where that's allowed.
18 Accord Hybrid 20K HGMO 0W-20
17 Forester 30K VME 0W-20
12 Accord LX 115K SSO 0W-20
09 Forester 119K M1HM 5W-30
96 Accord LX 104K T5 10W-30
95 318i
Page 1 of 3 1 2 3
