Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
72 registered members (Anduril, badduxx, bmwpowere36m3, ARCOgraphite, biodiesel, bbslider001, 8 invisible), 1,775 guests, and 55 spiders.
Topics296,775
Posts4,958,671
Members66,969
Most Online2,577
Jan 14th, 2019
Page 1 of 4 1 2 3 4
How are these Spark plugs looking? #4647936
01/27/18 11:24 AM
01/27/18 11:24 AM
MURICA
maverickfhs Offline OP
MURICA
So have an issue where 2003 Civic is consuming oil: https://bobistheoilguy.com/forums/ubbthreads.php/topics/4647478#Post4647478
Pulled all 4 spark plugs and that's how they look like. Are they normal? Air filter is clean and no CEL on the cluster:
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
Re: How are these Spark plugs looking? [Re: maverickfhs] #4647938
01/27/18 11:25 AM
01/27/18 11:25 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
The white deposits show that the oil you are consuming is being burned (not leaked).
You need to determine the source of the oil, it could be something as simple as PCV, or you may have valve seals pooping the bed, stuck oil control rings...etc.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: How are these Spark plugs looking? [Re: OVERKILL] #4647940
01/27/18 11:29 AM
01/27/18 11:29 AM
MURICA
MURICA
Thanks, PCV valve is new and have been replaced few months ago, no visible smoke at start up or during acceleration or deceleration and no leak on the driveway either. But definitely being burned and going somewhere frown
It all started after re-manufactured head cylinder head was put on. Are stuck oil control rings there in the head or bottom end? How can I check valve seals are causing this issue?
Thanks for all the help.
Re: How are these Spark plugs looking? [Re: maverickfhs] #4647951
01/27/18 11:45 AM
01/27/18 11:45 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
This is a good clue as to what the cause may be. Rings are in the block and if it wasn't burning oil before are an unlikely source of the oil burning after the head was replaced.
I would guess something along the lines of improperly installed valve seals or even a gasket issue (unlikely) like installed upside down with the oil drain back holes only partially exposed if that's even possible on this engine, I don't know.
Re: How are these Spark plugs looking? [Re: Trav] #4647953
01/27/18 11:48 AM
01/27/18 11:48 AM
MURICA
MURICA
Thanks Trav, we didn't install any seals inside the head, since head came all ready to go. We just prepared the surface, put a new valve cover gasket and spark plug seals, using my memory, I think that's about it.
Re: How are these Spark plugs looking? [Re: maverickfhs] #4647958
01/27/18 11:53 AM
01/27/18 11:53 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
As Trav indicated, if that's what was changed before this started, it is an immediate suspect. Where did the head come from?
Re: How are these Spark plugs looking? [Re: maverickfhs] #4647963
01/27/18 11:58 AM
01/27/18 11:58 AM
MURICA
MURICA
Head was bought from ebay from this seller: https://www.ebay.com/usr/world.cylinder.head.ind
Apparently he had really good reviews for re-manufactured heads and hence I bought from him.
Re: How are these Spark plugs looking? [Re: maverickfhs] #4647968
01/27/18 12:00 PM
01/27/18 12:00 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Wow, you are a brave man! LOL!
I would have had your original head reconditioned at a local machine shop of good repute. What was the cause of you needing the read re-done?
Re: How are these Spark plugs looking? [Re: OVERKILL] #4647970
01/27/18 12:03 PM
01/27/18 12:03 PM
MURICA
MURICA
LOL, I can be at times laugh
Car jumped timing while driving, it needed quite a few valves and hence went for a re-manufactured head route. I still have the old head, worst case I'll just get it re-build locally and swap it in summer.
Re: How are these Spark plugs looking? [Re: OVERKILL] #4647971
01/27/18 12:04 PM
01/27/18 12:04 PM
Chicago
bowlofturtle Offline
Chicago
+1 on that.
I dont doubt the seller's work but when you do so many heads, you are bound to have some minor issues now and then. Your head MIGHT be one of them. At this point unless you pull the head it going to be a [censored] shoot as to what the problems are.
My toys
-05 Infiniti G35x 121k
-03 Suzuki SV650N 8.5k
Maintaining
-16 Jetta 1.4T 7k
-98 Nissan Maxima 145k
-09 Toyota Camry V6 86k
Re: How are these Spark plugs looking? [Re: maverickfhs] #4647973
01/27/18 12:07 PM
01/27/18 12:07 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Did you check the pistons and cylinder walls when you had the head off? Pistons kissing valves isn't a one-sided scenario, there's the potential for some other damage from this as well.
Re: How are these Spark plugs looking? [Re: OVERKILL] #4647976
01/27/18 12:12 PM
01/27/18 12:12 PM
MURICA
MURICA
Yeah, there was no visible damage. After above comments now I am leaning towards bad valve seals or leaky valve seals causing this to happen.
Re: How are these Spark plugs looking? [Re: maverickfhs] #4647983
01/27/18 12:27 PM
01/27/18 12:27 PM
Trav Offline
Trav  Offline
Start with a compression and leak down test and look at the bores with a boroscope. Its not that common but you may be dealing with broken rings or ring land damage.
If that's the case its good night Irene, rebuild or replace time. This job could get ugly real fast any which way you want to look at it.
Re: How are these Spark plugs looking? [Re: Trav] #4647984
01/27/18 12:29 PM
01/27/18 12:29 PM
MURICA
MURICA
Makes perfect sense, thanks Trav. I'll do a compression test and see what reading I'll get.
Re: How are these Spark plugs looking? [Re: maverickfhs] #4647987
01/27/18 12:37 PM
01/27/18 12:37 PM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
How many miles on those plugs, they look worn in addition to the accumulation on them. Are they iridium plugs?
Whimsey
Page 1 of 4 1 2 3 4
